Old 09-28-2001, 09:44 AM   #556
hey guys got a ?, in the fax section the term diffing the suspension, can someone discribe what that is, thanks
rcspeed is offline   Reply With Quote
Old 09-28-2001, 11:57 AM   #557
Dragon Slayer's Avatar
Send a message via Yahoo to Dragon Slayer
Good question...what is "diffing" the suspension????......Also....can anybody give me a good setup for a really loose track???thanks
Dragon Slayer is offline   Reply With Quote
Old 09-28-2001, 03:01 PM   #558
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Stupid question about 3000SMH Cells. I just got around to putting the packs together and amd charging them right now on my T35 and Millenium Chargers. They got done charging and the volts are at 8.83. Is this about normal? I hit start again on both chargers and they have been charging again for now 685 seconds. I would have thought they would have got done charging quicker since both chargers said they were peaked. Usually with my 2400 packs when I start the charge after they are done peaking they go for about 60seconds before saying they are done again.
Mike Webb
mike_Webb is offline   Reply With Quote
Old 09-28-2001, 04:49 PM   #559
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
RC & Dragon-
"Diffing" can mean two things. One meaning is when the diff slips under acceleration, and makes a chirping of barking noise.
Another meaning of diffing is when the car suffers a great deal of body roll, and actually pics one of the inside tires up off the ground, this will actually unload the diff, and allow the inside tire that is off the ground to spin the opposite direction.
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 09-28-2001, 04:54 PM   #560
Mike-
Your cells will come around. They have been sitting on a shelf for awhile most likely. Give them a few cycles. You should see peak values of around 9.10v +/- .1v.
Later...
Tim Davis
Old 09-28-2001, 05:06 PM   #561
mike_Webb's Avatar
Thanks for that number. I let them all sit for 2 hours and then re-peaked them on my T35. All of them are 9.3+ V. 2 at 9.32, 1 at 9.36 and 1 at 9.39. I can't wait to run these tonight.
Mike
Old 09-28-2001, 05:36 PM   #562
Trader Rating: 19 (100%+)
Mike Webb
Be sure the charger is set for 3mv cutoff and that the batteries register a charge greater than 3000mah rather than looking at the final voltage. The packs will get better.
MDawson is offline   Reply With Quote
Old 09-28-2001, 06:20 PM   #563
Jared Kirkwood's Avatar
Send a message via AIM to Jared Kirkwood
Speaking of 3000s any of you guys Zapping them?
Jared Kirkwood is offline   Reply With Quote
Old 09-28-2001, 06:27 PM   #564
I have zapped older Panasonics 3000s after their voltage seem to tail off but will only use the packs now for practice. They had great RT but the voltage was softening a bit. Zapping woke the cells.
Old 09-28-2001, 06:41 PM   #565
STLNLST's Avatar
Mike Webb- Since the T35 doesn't use mv like the novak caharger set the cout off to .02 for 3000's. I would also turn on the long lock out.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 09-28-2001, 08:19 PM   #566
I got some I'm bring down now to zap. I cycled them last week and they where only 7.05v@.90cutoff at 20 amps. I'll see what it does after I put a 50v to them. Maybe it will wake them back up and get the IR down. Probably need to wake up some older 2400s too.
Old 09-29-2001, 07:21 PM   #567
Trader Rating: 87 (100%+)
Has anyone got the one-way yet?? if so , your opinions.....
Dan
dan-o is offline   Reply With Quote
Old 09-29-2001, 10:00 PM   #568
I dont think the one-ways are out yet.
Old 09-30-2001, 01:54 AM   #569
STLNLST's Avatar
First night out with the car and I TQed and won the mod class. The car has great corner speed and is very stable. I was running Matt Francis' set up from the Roar nats. The only change that I made was to come in one more hole on the front shock tower. the car pretty much drive's itself.
Old 09-30-2001, 07:28 AM   #570
Finally saw one race yesterday on carpet. Fast, and the quietest car I've (never) heard. Impressive.
coolrcdad is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
