Losi XXX-S
#5626
Aluminum Pivot Blocks
Is anyone here using aluminum pivot blocks and inner mounts (Speedtech RC's to be specific) for their XXX-S? If so, did it fix the rear toe mismatch?
Thanks.
Thanks.
#5627
I run the SpeedTech blocks and my car is fine with the rear toe. But then again, it was fine with the stock blocks too.
#5628
Ride height
STLNLST - Thanks - the AE clips did the job!!
#5629
I know that when I set my car up with the Hudy setup system I get a rear-toe reading of 1.5 for the left and 2.5 for the right. That is with using the Losi blocks.
#5630
Location: Time to put down the Golf clubs and poker chips and GO RACIN!
What are ae clips? the piece that goes on the bottom of the spring?
#5631
TSR6 - If that is the case, then definately pick up the kit version! It allows the racer to have the needed knowledge for rebuild/repair if and when needed!
out - Wilde
out - Wilde
#5632
Here's a quote from Todd Hodge on the problem
" agree with you on that one. I thought it was a optical illusion at first until I measured it on the hudy setup board. Mine was off about 1/4 degree on one side. Here is what I do when tightening down my rear pivots which helps alot. As I put the rear end together I loosen the pivot blocks that mount to the chassis. I then put the arms on and the rear pivot that captures the hinge pin to the diff cover. I screw that down all the way and then go back and tighten the pivots that are mounted to the chassis. This helps everything center."
As suggested earlier on this thread this may work for some... But some of us are just stuck running a staggered hubs..
When I ran my TC3 I also had the same problem. But it was due to stretching the plastic.. Not the case with my XXX-S
#5633
#5634
Thanks fellas
I was thinking of getting either a GT7 or a Quantum comp, and race in stock.
#5635
Very nice racecar850
tufferwilde, I've swapped from blue+60wt oil to red+40wt oil all round and I'll let you know how it works.
#5636
LouisB
Thanks hommie
Hometown.... Southend, Essex
#5637
ChrisO the gt7 is probably your best choice, but you cant go wrong with either one! And if you will race stock, look into a p2k2 motor or a MonsterStockHorsepower motor. The type of motor really depends on your track!
And a servo wont be needed right away, it can be upgraded later. But it is one of the best ways to upgrade your car, so it wouldnt be a bad idea to have a good servo and a good ESC to go with a good car.
It all really depends on how experienced you are and how much money you are willing to spend
#5638
One guy I race with ran an LRP and was very fast and then he switcehd to a GT7 and I'll be darned if he is not going faster then he already was. So I would definetly get the GT7, I will be upgrading my TC2 to a GT7 very soon.
Later
Later
#5640
I first noticed the toe-in problem at the Snowbirds race. I bought the G+ arms and hubs to put on my original xxx-s. I actually had too much toe-in on the left side after I installed the new parts. I was using MF LRC blocks at the time. Loosening the blocks, changing rears hubs....none of this solved my problem. BUT buying a new set of rear arms solved the problem. I'm not saying this is the solution to everyone else's problem, but it solved mine. After searching and hunting for the cause, changing out multiple parts and then buying new arms as a last resort.....I was pissed to say the least!!
