Old 03-05-2003, 02:12 PM   #5611
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Rayhuang, there's an easier way to build perfect losi shocks
Fill the oil up to the 1st thread. Fully extend the piston (so that all the shock shaft that will be inside the shock is showing). Slowly insert the piston/cartridge and screw all the way down. Oil will bleed out as you do this, and when you're done you can compress it the full way and it will suck back in slightly. Cycle your shocks up and down a few times or until you can hear no squeaking to get rid of all the air bubbles left. You then have a perfect losi shock . This is how i build my shocks anyway, seems to work great for me.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 03-05-2003, 02:44 PM   #5612
KevanB's Avatar
When should i tighten or losen the differential? Im kind of new to the asjustable diff thing, and ALL the setups and tuning options of the xxx-s . O so many things you can do to the car!!!
KevanB is offline   Reply With Quote
Old 03-05-2003, 02:49 PM   #5613
Nope not the arm... replaced them and still no dice, besides the arms are symmetrical so there would be problems on both sides...... I am going t check to see if the raised RC blocks have the same ssues and if they don't will probably cut them down.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 03-05-2003, 03:47 PM   #5614
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Default Re: Rear toe
Originally posted by stumper1
If the rear toe problem is also happening with the standard offset hubs is this possibly a problem with the new rear arms? I have an older xxx-s with full graphite - I run the O degree graphite hubs and they work perfect. Or is it just a problem with the new hubs themselves ( both standard AND offset )?
This was a while ago when I read this, and I'm not 100% positive it was for the rear toe or not, as I said, It's been a while.
Todd posted something to the effect of loosening the pivot blocks a little, and tightening them back down on Tech talk. ( the two on the chassis, not the one on the diff cover. )
Try that, and then put the car back on the setup blocks. Let me know what happens.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 03-05-2003, 04:02 PM   #5615
Been there.... I even tried pulling on the arm to force the block and then tightening...... no dice......
I spoke with Losi today and they said they never heard of the problem???? They also told me to try that..... and if it didn't work to send it to them for inspection.....
There are a few Losi drivers at the local track so I will ask them to look at it, or I will wait until the orion race and get other Losi guys to take a gander.....
Old 03-05-2003, 07:36 PM   #5616
Regional Moderator
Had the same problem of not having enough down travel. Moved to using the outer holes in the A arm. When using the inner holes it's not the shock thats limiting travel, its the cvd! At least is on my G+. This cured the problem. Hope this works for your
volav is offline   Reply With Quote
Old 03-05-2003, 07:55 PM   #5617
STLNLST's Avatar
Trader Rating: 17 (100%+)
the only fix to the rear toe in problem is to stagger your rear blocks if the loosening of the roll center blocks doesn't solve the problem.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-05-2003, 08:44 PM   #5618
ChrisO's Avatar
Send a message via AIM to ChrisO Send a message via Yahoo to ChrisO
what radio is included in the RTR xxx-s? i know its a jr one buy not what model, like xr2 or xr3?
ChrisO is offline   Reply With Quote
Old 03-05-2003, 08:52 PM   #5619
xr2
USVTA Member #211
Old 03-05-2003, 11:21 PM   #5620
ChrisO's Avatar
Originally posted by Axiom5B
xr2
Thanks.
Is the rtr worth it, or shoudl i just buy the standard xxx-s and get better gear, iv already got a lynx 3d that i can use
Old 03-06-2003, 12:27 AM   #5621
stumper1's Avatar
Default Rear toe..and other stuff...
I rebuilt the rear end today and used standard offset O degree hubs and the toe is PERFECT!! The only thing I did differently was swap the RC blocks ( put the left on the right - right on the left). I will have to try the offset blocks again to see if they work now(?).
I used Hodge's Cleveland set-up and ran into another problem. With the 2R hinge pin mount I am running out of threads on my shocks to get the 5mm ride height. Should I just get some of the older 1.15 in. springs or am I missing something?
Thanks for all the input!
stumper1 is offline   Reply With Quote
Old 03-06-2003, 05:49 AM   #5622
STLNLST's Avatar
AE shock clips will solve the ride height problem
Old 03-06-2003, 06:40 AM   #5623
KevanB's Avatar
ChrisO IMHO i would go with your Hitec Lynx 3d, and a standard option xxx-s. That way you can purchase a high end stock or mod motor(this is a must), high end ESC (definately need this), and a high end servo(dont need right away, but a great upgrade), which you will all need to race competetively.
Do you have any batteries? If not, consider looking into some high end battereis also, because you cant race if you dont have battereies. The newest thing is the 3300 gold peak batteries, those will last you a long time in a race.
The XR2 will seem like nothing compared to you Lynx3d.
Hope this helps you!
Old 03-06-2003, 08:35 AM   #5624
tufferwilde's Avatar
ChrisO - yes, the radio that comes with the RTR XXXS will do just fine!! In fact, the features that the radio comes with are very similar to those on many more expensive radios... dual rate, end point adjustments... etc. The radio in fact has the exact same features as the XR3 - just isn't FM and has only 2 model memories.
Are there far better radios out there??absoutely... but taking into consideration that the RTR XXXS sells for roughly $270 most places, I would stick with what it comes with... I disagree with KevanB on this one - no need to purchase a 190-260 dollar radio to just get into the hobby... and the same will go for batteries... if you are looking to race the car and compete at the highest levels, then yes, I would purchase high end matched packs... but for most people - that simply isn't needed, in fact, the added power of a race pack might be just the opposite of what a beginner would need...
The car that comes in the XXXS RTR kit is exactly the same that comes with the standard kit... just some of the materials (such as the arms) are formed out of a softer plastic... and can always be replaced with standard parts or even upgraded to the full graphite kit...
basically - save the money for a high end radio and high end batteries (unless you need to have the very best! In which case, I would pick up the M8, not the hitec radio...) and put some quality practice time in... the good batteries and radio can always be purchased after the fact!
just my .02
Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 03-06-2003, 08:40 AM   #5625
RCTech Member #2
TSR6's Avatar
tuffer - He already has the Lynx 3D.
I reccomend buying the kit, building it yourself, and putting in electronics that you want. But, the RTR is still a good option. Some LHS's will make a deal with you if you don't want the radio, and worst comes to worst, You could always sell the XR2.
Troy
RCTech Member #2
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
