Old 03-04-2003, 07:42 AM   #5581
rayhuang's Avatar
I stand corrected!!! I'll update my personal spring rate chart!!!
but-I gotta say-by my spring dynomometer (my thumb and finger), the Congo Blues feel lighter than the Losi Blacks to me. And the Congo Blues feel ever so close to the Losi Purples-so close I cant really tell them apart with my eyes closed.
Old 03-04-2003, 08:44 AM   #5582
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Harshguy, we have been ordering chassis for awhile now and they have always been the G+ kit chassis's. Unfortunately they are out of stock from the distributor right now. The part numbers are the same so who knows what is happening.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 03-04-2003, 08:45 AM   #5583
OK I got one for everyone........
I was setting up my G+ for the race this weekend and just out of habit I checked rear toe on my integy set-up station and the RR is a perfect 1deg. However the LR is 2 1/4 degs.!!!!!! I changed out new hub carriers and still the same result. I also check to make sure I didn't bend the hingepin while building and it's perfect. Then i checked to makle sure everything was tight..... agian no dice!
The only thing I can't verify is the front mount...... Has anyone else had this experience, my car is brand new I bought it a month ago, built it, and has never been driven.....
I know I can just use the 1 deg hub in reverse on the left side, but that really isn't fixing the situation....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 03-04-2003, 08:52 AM   #5584
Super Moderator
Kraig's Avatar
Before you put the rear of the car back together loosen your rear roll center blocks. Then put the rear pivot block on and tighten down. Then you can tighten down blocks. If it is still off then maybe the blocks have been stretched to some extent.
Give that a try and let us know how it works out.
Old 03-04-2003, 08:52 AM   #5585
Send a message via AIM to munrath
Impactplayr,
Loosen the rear roll center blocks and the rear pivot block. Then adjust and tighten.
Mark
I must be a slow typer
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 03-04-2003, 09:11 AM   #5586
Send a message via Yahoo to miniman
blue shocks?
Do you guys know of any blue. threaded shocks that will fit the xxx-s? I`ve tried my TC3 shocks, but they were too long in the front. Do you know if the Yokomo shocks are shorter?
miniman is offline   Reply With Quote
Old 03-04-2003, 10:41 AM   #5587
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
The only time you run into this problem is when running the 0 degree offsets. For some reason the drilling gives you a 2deg left and a 1 deg right. Since I want to run 2 degree rear toe I put a 1 dgree offset on the right and leave the 0 on the left. This fixed the problem. I don't seem to have the mismatch when running the 1/2's. Since I spent hours moving the blocks around with no fix, I think this is all you can do.
ChristopherKee is offline   Reply With Quote
Old 03-04-2003, 10:51 AM   #5588
CRASH's Avatar
Trader Rating: 26 (100%+)
miniman,
Why would you want to put Associated/Yokomo shocks on your XXX-S. Losi shocks are some of the smoothest and easiest to build. Where as Associated shocks are some of the hardest to build correctly.
CRASH is offline   Reply With Quote
Old 03-04-2003, 11:07 AM   #5589
racecar850's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to racecar850 Send a message via Yahoo to racecar850 Send a message via Skype™ to racecar850
Associated shocks.....caps & little rubber things...messy
Mugen MTX-4 :tire:
T-MAXX 3.3 :deathstar
MacBook...got fed up with pc :confused:
DRIVING...An inconvenient way of getting from A to B
racecar850 is offline   Reply With Quote
Old 03-04-2003, 11:32 AM   #5590
From what I've been told about the congo springs, is that blue is close to 30lbs, purple is close to 35lbs, and yellow is close to 40lbs. None of them are exactly those weights. Also, over the years the spring rates have changed. (maybe one of the very first purples was 36lbs, newest is 34lbs)
Personally, I'd just use the Losi springs, yellow is 40, orange 35, white 30.
JeffC is offline   Reply With Quote
Old 03-04-2003, 01:41 PM   #5591
well, I just like the blue colour And, I recently bought a 70$(in norway) Xray spring set that won`t fit the losi shocks.
Old 03-04-2003, 02:26 PM   #5592
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Yeah color is cool and all, but wouldn't you rather have performance and ease of maintinance? BTW the associated shocks aren't much narrower than the losi ones, but hte spring retainers are different, you could see if associated retainers fit on your losi shocks.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 03-04-2003, 02:53 PM   #5593
thank you Axiom,5B
I hadn`t thought of that. They just went over the shock body without rubbing enough to bind.. Do you know if the threaded Losi shocks are wider than the non-threaded?
But, if anyone knew, I would still like to know about those yokomo shocks(I`ve been using TC3 shocks on all my touring cars, and have gotten used to building/rebuilding them).
Old 03-04-2003, 03:38 PM   #5594
Christopher- thanks, I wonder what causes this? I even double checked the RC blocks by switching them left to right and still get 2 deg on the right........
but why would the 1/2 deg blocks work fine....am I to assume that I can't use the 1 deg. blocks by them selves?????
Old 03-04-2003, 04:06 PM   #5595
The yokomo shocks are very similar to tc3 shocks. And the losi threaded and non threaded i think are the same diameter. I have owned a tc3, schumacher mission, and a losi and the losi shocks are by far the easiest to build, with the schumacher's in second. You could also try and get xray retainers and try to fit those. Now let me ask you a question, why did you get Xray springs for a losi car? All losi's springs are very good and they have a lot of rates to choose from.
USVTA Member #211
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
