Old 09-26-2001, 09:15 PM   #541
Trader Rating: 19 (100%+)
Originally posted by futureal
If anybody wants to start a separate FAQ thread, go for it. I think that would be a great idea. It is stuff like that that I can post up on the home page under the "Articles" section, and give all of you credit who submit stuff.
Actually, I just had a great idea for a new forum. Vehicle FAQs! The first post in each thread can be a "running post" to keep all of the information, and be continuously updated by the creator. Everybody else can respond to the thread with any information they might have, and the first poster (the "keeper") can add the information to the first post.
Good idea!
I will start a FAQ complied from TT and other sources. Will post it once it starts to form. I will add a link to the FAQ from my signature in my posts.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 09-26-2001, 09:21 PM   #542
Trips's Avatar
Trader Rating: 16 (100%+)
Originally posted by Ty
What is the part number for the Trinity collars for the Losi threaded shocks and how much should I trim the front shock shaft and also the plastic shock end? Thanks everyone.
The Trinity collars are part number TRITK3048
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 09-26-2001, 10:51 PM   #543
R/C Tech Founder
R/C Tech Charter Subscriber
Is there any chance I could mirror a copy of your FAQ on here? (Giving you full credit, of course...)
I am looking for content to put on here, I'd make a bunch myself but I just don't have the time to work on it...
futureal is offline   Reply With Quote
Old 09-26-2001, 10:56 PM   #544
The Faq can be found in my signature area - feel free to mirror the file.
The credit however should go to all the folks that want to see the car and its drivers do well.
TEAMORCA.SHOP
Old 09-26-2001, 11:37 PM   #545
R/C Tech Founder
If I mirrored it though, I would like to convert it to look like an rctech page (like the ones on the home page).
Guess we'll see... I might be able to keep the format you have and use an IFRAME to it to appear within the rctech page borders... hmm... (entering web development mode)
Old 09-27-2001, 09:14 AM   #546
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
Black Losi springs are 25lb. You could add them to your chart.
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 09-27-2001, 09:42 AM   #547
gotcha - it has been added.
TEAMORCA.SHOP
Old 09-27-2001, 11:04 AM   #548
Ty
Ty's Avatar
Trader Rating: 29 (100%+)
Thanks to everyone who helped before, especially Troy and Mark. I want to know if it would be beneficial to run the Trinity heatsink that MDawson has on the car. I run stock so it will cover up the vent holes. Should I still get it? Or will a narrow TC3 clip on heatsink from Team Associated do the same thing? Thanks guys.
Ty is offline   Reply With Quote
Old 09-27-2001, 11:17 AM   #549
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Ty - No problem.
I ran the heatsink for the first time last sunday. It doesnt cover the whole vent hole. If you place it just right, it covers about 1/4 of each vent. I also run stock.
My only dislikes of the heatsink are thats it's blue ( no biggie ) and that it moves the motor out very slightly... Maybe not enough to notice, but it does move it out slightly...
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 09-27-2001, 11:24 AM   #550
Trader Rating: 87 (100%+)
Does anyone have the info on the trinity congo's Yellow, Blue & Purple??? The spring rates are what i need Thanks!
Great job with the XXX-S FAQ link!
dan-o is offline   Reply With Quote
Old 09-27-2001, 07:55 PM   #551
Trader Rating: 30 (100%+)
MDawson:I'd like to comment about the outer hinge pin retaining set screws so that you may add to your excellent FAQ page.
I've found that if you remove that little wall of plastic at the bottom of the screw hole that you'll have very little trouble securing the hinge pin.A small drill bit works very well at removing the wall that protects the hinge pin.I know that Losi says this was intentional as to prevent the possiblity of gailing up the hinge pin but I've never seen this happen to the point where the pin was unusable.
Lowrance is offline   Reply With Quote
Old 09-27-2001, 07:58 PM   #552
Lowrance
I will add that to the listing.
TEAMORCA.SHOP
Old 09-27-2001, 08:03 PM   #553
RCTech Member #2
TSR6's Avatar
I havent had a problem with striping out the castor block. I don't see what the problem is. I just went slow and took my time threading.... then slowly snuged it down untill i couldnt move the pin.
Troy
RCTech Member #2
Old 09-28-2001, 05:20 AM   #554
HarshGuy's Avatar
After realizing that the castor block could be stripped I've been doing that slow thing like TSR6, but as a double secure measure I've also been putting 3/32" e-clips on the ends of the hingepins.
HarshGuy is offline   Reply With Quote
Old 09-28-2001, 08:54 AM   #555
RCTech Member #2
TSR6's Avatar
Just snug it down, then wiggle the pin... tighten untill it doesnt move back and forth, then tighten it an extra 1/4 turn. That should keep it pretty snug and tight
Troy
RCTech Member #2
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
