Old 02-21-2003, 09:58 PM   #5446
Team R's Avatar
Default Almost lost and confused
Hello all-
I have a few of questions to ask and I would imagine that they have all been asked before, but I haven't been on the R/C Tech website for sometime now.
I've updated my XXX-S with the rear shock tower, arms and off set hubs off of the G+. I was using the Todd Hodge setup sheet off of the Losi website to setup my car and I came across a term that is new to me. What is, and what happens when I move the Ackerman from forward to back.
Also let me know if I understand how the Off Set Hubs work. On the Todd Hodge setup sheet (So Cal Grand Prix Asphalt Setup), he has 2 degrees of toe in on his car. So I will want to use the 0 degree hubs to have the same as him and if I used the 1/2 degree hubs, I would have 3 degrees of toe in, and so on if I used the 1 degree. Do I have it right or am I lost and confused.
Also, has anybody tried using the Monster Diff Adjustment Screw Set (part #A-2910) in their diff.? How dose the spring work instead of the washers for the adjustment on the diff?
Thanks for all replays sent my way
Team R is offline   Reply With Quote
Old 02-22-2003, 07:31 AM   #5447
STLNLST's Avatar
Trader Rating: 21 (100%+)
TeamR- On the rear hubs are you adding both 1/2 degree's to come up a total of 3 for the rear toe? With the 1/2 degree hubs the rear toe would be 2 1/2. People have different ways of looking at things so I just want to be sure we're on the same page so that we can get you the correct answers that you're looking for.
If you have the new chassis with the two ackerman positions this is what I've found when testing them. The foward one made the car a bit too aggressive for my liking. The rear position calmed it down a bit. It might be the way to go a very tight track. I did do my testing with a oneway though so maybe I'll try it again with a diff and see how that works. Let us know how if feels to you if you try it out.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-22-2003, 07:53 AM   #5448
Regional Moderator
R/C Tech Charter Subscriber
here are a few updated pic after a few goodies added
tell you what guys i like this xxx-s G+ i wish i would had jumped on board along time ago
Ko Racer is offline   Reply With Quote
Old 02-22-2003, 07:54 AM   #5449
Regional Moderator
the rear
Old 02-22-2003, 07:55 AM   #5450
Regional Moderator
last shot
Old 02-22-2003, 08:10 AM   #5451
LouisB's Avatar
Ko Racer, looks good I have some Tamiya blue wheels too, they look sweet with the right paint job (and are great on the track)
I like the yellow wires, I always stick with red/black/blue because I know I'll plug it in the wrong way eventually
LouisB is offline   Reply With Quote
Old 02-22-2003, 08:37 AM   #5452
Team R's Avatar
STLNLST- I was going off of the instructions that came in the package with the hubs, which is how I came up with the 3 degrees of rear toe in. After looking at the instructions (again) and your post, I think that the instructions are adding the total degrees of toe in (both sides) to get their 3 degrees, where you are going by just one side for you 2 Ĺ total. What do you have on your car, and what type of surface are you running on?
Iím using the old graphite chassis, so I donít have the Ackerman adjustment. I was just looking at the exploded view on the Losi website. Do you make the Ackerman adjustment by moving the steering post forward and back?
Old 02-22-2003, 10:21 AM   #5453
Regional Moderator
Team R,
The rear arms themselves provide 2į of toe-in the .5į is added to it.
petzl is offline   Reply With Quote
Old 02-22-2003, 03:13 PM   #5454
racecar850's Avatar
Send a message via MSN to racecar850 Send a message via Yahoo to racecar850 Send a message via Skype™ to racecar850
SHOCK LIMITERS
Has anybody experimented with shock limiters
Mugen MTX-4 :tire:
T-MAXX 3.3 :deathstar
MacBook...got fed up with pc :confused:
DRIVING...An inconvenient way of getting from A to B
racecar850 is offline   Reply With Quote
Old 02-22-2003, 03:30 PM   #5455
LouisB's Avatar
Default Re: SHOCK LIMITERS
Don't droop screws do the same job? only without the mess
The only cars I use shock limiters on are ones without droop screws.
Old 02-22-2003, 04:05 PM   #5456
racecar850's Avatar
SHOCK LIMITERS
my boo boo
i was asking about external limiters
who uses droop screws anyway
Mugen MTX-4 :tire:
Old 02-22-2003, 04:18 PM   #5457
Regional Moderator
thanks louis B...yeah i like the blue and the pink wheels from tamiya.
Old 02-22-2003, 04:29 PM   #5458
racecar850's Avatar
Angry STLNLST........REAR TOE IN
I redrilled my rear pivot block to produce 0 deg of rear toe (just experimenting). The car was slightly less tail happy & very easy to drive
Now run with only 2 deg total rear toe in....more forward speed
Mugen MTX-4 :tire:
Old 02-22-2003, 08:10 PM   #5459
mo
mo's Avatar
This is STLNLST not MO...........
.......I have 2 1/2 on my car right now and I have run this on carpet and asphalt. I may go back to 2 degrees of toe in the rear end. I was so use to the instant traction that carpet gave that the car felt a little loose today so I'm going to lock the rear end up some. As far as the ackerman goes....moving the posts forwards and backwards does change it. I don't think that it's an adjustment that I'll use all that often but I did have to try it out once.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 02-22-2003, 11:06 PM   #5460
Erik R.'s Avatar
Default Chassis Drilling
I've had my XXX-S G+ for almost 2 months and I'm really happy with the car. A lot of guys at my track have drilled out their XXX-S's and wanted some info on drilling. Can someone tell me what they've used to cut their chassis or what pages this info might be on? I've heard that people are using dremels, but what type of bit works best?
Thanks,
Erik Rodriguez
Erik R. is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
