Losi XXX-S
#5431
I cut a piece of tough plastic that i had lying around into a upper brace and it's never broken, even though I've tried my best to do so.
#5432
HAHA, does anyone thinks that if the G+ is on my stock bumper brace it would reduce flex at the bumper area?
#5433
hey.. someones using my avatar.... I might have to start getting crazy - go - nuts!!!!!
With the Matt Francis setup, do you shim the LOSI low roll centre mounts up 0.060 to get the same height as the MF mounts ? or does it mean that the mf mounts are shimmed up 0.060 and the Losi mounts will actually have to be shimmed more ? What about the rears ? is there a difference between the MF and the Losi mounts there ?
Also, I don't have Blue congo springs at the moment, which would be a better replacement, Purple congo or Black losi ?
#5434
Also, do you still put the 4f block in the bottom diff cover holes or the top ?
#5437
Trader Rating: 32 (100%+)
Blue is close to 30lbs and purple is close to 35lbs....the bules vary depending on how old they are the same with the purples....I have some Congo Blues, Purple and Yellows from my Street weapon days and they are stiffer then whats out there now....plus I have a two kinds of yellows from back then that are not even close to whats out there today. I would just get the new Losi springs and not worry about the congos b/c they have varried so much over the years. And what a Team guy has is more then likely older so its not close to whats out there now.
#5439
No the bules are not around any more...what I have is old and some of the more receint blues that I have seen are even different from what I have.
#5440
I spent 5 minutes looking for a good picture of strongbad on google images, for a possible future project... and saw this, put it on my avatar.
#5441
Originally posted by Axiom5B
Losi blacks are a better choice to replace congo blues, but you might as well get new Losi whites, even closer to congo blues. The place where you mount the block depends on if you're running high or low roll center. Low for low, high for high.
Put simply how do you achieve the Francis standard carpet setup without the MF blocks ?
#5442
Sleek....the MF low RC is lower then the Losi Low RC. If you take the MF low RC and shim it up .075 then its the same as the Losi Low RC. The Losi low RC is like a mid RC b/c its not as low as the MF low RC. I dont know who to acheive his setup b/c I have never looked at it but what I told you should get you going in the right direction.
#5445
has anyone ever tried bushings in the diff's instead of bearings-i know the tc3 lightweight diff's have bushings in them and billy easton told a friend not to use bearings that the bushings are lighter so i was told. just wondering if anyone has tried it in this car?
