Old 02-19-2003, 09:26 PM   #5416
Send a message via Yahoo to hicheef
Default Stocking up (Springs)
Whats up gang, stocking up the pit box for the G+ and the time has come to start picking up springs. Couple questions though
1. The rule is 1.0" in the front 1.15" in the rear only??? Can I put 1.15's all around?? Would I ever want to?
2. Planning to race some asphalt some carpet are there any Spring colors that are a "must have"? Front/ Rear
Guess that was more that a couple questions/Sorry!!!
Input is much appreciated!!!!
hicheef is offline   Reply With Quote
Old 02-19-2003, 09:30 PM   #5417
it really depends on what tires you use. Foams, you run pretty stiff. On carpet I'd say you'd want springs, 20-40lbs with foam. Rubber, the only rubber tires I've used were the TakeOff CS27 handouts for the US TC Championships. Ran pretty soft I think guys ran from 10-20lb springs.
I'm not sure about asphalt
JeffC is offline   Reply With Quote
Old 02-19-2003, 09:33 PM   #5418
oh, I don't think it matters much about the spring lengths. I beleive all the springs that are being made now are the 1", kind of a running change. I could be wrong though... you could run into problems with getting the right ride height and droop settings if you use too tall or short of a spring.
Old 02-20-2003, 08:38 AM   #5419
tufferwilde's Avatar
hicheef -
As for the different size springs, yes either one can be mounted on the front or rear... but with the shorter shocks up front the 1.15" springs will make you thread the collars nearly to the top... but they will fit.
I agree with Jeff on the spring choices for carpet, as I am currently running the white 30lb springs on the car in stock and the black 25lb springs on my mod car on carpet...
As for asphalt choices - I tend to mainly use the springs in the pink-green range on my car, depending on track layout, traction, etc.... but the ones I use the most are the pink, red, and blues for the couple of tracks that I run at... your best bet would be to check out what the local fast guys are running on their cars and go from there... but since the Losi springs are relatively inexpensive, there's no problem with havng all of em...
regards,
Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 02-20-2003, 09:35 AM   #5420
Default Springs
Thanks Guys, Much appreciate the input!!!!!!!
Kevin
Old 02-20-2003, 10:39 AM   #5421
racecar850's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to racecar850 Send a message via Yahoo to racecar850 Send a message via Skype™ to racecar850
Default springs
tufferwilde
can you pass on some other details of your setup with the 30lb springs
I`m using green on front with blue on rear with 60wt oil are these too soft
advice would be appreciated
Mugen MTX-4 :tire:
T-MAXX 3.3 :deathstar
MacBook...got fed up with pc :confused:
DRIVING...An inconvenient way of getting from A to B
racecar850 is offline   Reply With Quote
Old 02-20-2003, 12:53 PM   #5422
Racecar850 -
Here's the basic setup that I am running (unfortunately I do not have the camber links and the shock positions since the car isn't in front of me)
Front
White springs
60wt AE oil
60 piston
OF pivot block
Low roll center shimmed up .070
4 degree blocks
Plaid tires - 28mm - had to use AE hex for spacing
0.080 sway bar
Rear
White springs
60wt AE oil
55 piston
0R pivot block
Low roll center
off set arms, w/ 1/2 degree hubs on backwards (improved rotation)
TRC purple rears
Ackerman forward - belcranks standard direction
Battery forward
Losi Alfa body
I think that's about it...
Regards,
Wilde
Old 02-20-2003, 02:46 PM   #5423
Send a message via AIM to BlackFlagRacing
anyone know who makes low profile (8/32) wheel nuts. I'm having problems with breaking front and rear carriers and I think it is due to the fact the wheel nut stick out further than the wheel. please include a part # if you can.
I'm running the MF set-up(not overdriven though) from the losi web page. this set-up works really well for me. the Andrew Grey set-up is also very good. Rob
BlackFlagRacing is offline   Reply With Quote
Old 02-20-2003, 03:07 PM   #5424
racecar850's Avatar
Thumbs up tufferwilde
Thanks for the info
A much different set up to what i`m using, mine is a lot softer
Mugen MTX-4 :tire:
Old 02-20-2003, 03:11 PM   #5425
LouisB's Avatar
I've got Team Trinity blue low profile nuts on my car, but I can't find the part#
I like running my car overdriven, the rear follows the front and this makes it much easier to get around the track. I've just finished painting my Acura RSX body, pics up soon(ish)
LouisB is offline   Reply With Quote
Old 02-20-2003, 04:30 PM   #5426
Default add me to the list
Well, I have to admit, when i first saw all the talk of sheared shock shafts i thought wow??? How??? I'll be damned, today running stock on carpet, sure enough what i thought was a fairly innocent hit sheared my shock shaft right at the end of the threads!!! What really sucked is i went to the parts counter to buy the replacements and they were all out. Guy noted it was strange that they would run out of those and I remarked to him about it turning up on the message board. I saw one mod for a fix, if anyone else comes up with one please post cause it's a bear to lose a day of running for an innocent hit like that!!!!!
Kevin
Old 02-20-2003, 04:36 PM   #5427
LouisB's Avatar
Sorry they aren't very good (combination of camera and lighting) but you can just about see them. I haven't got an airbrush (that works) so I did a little bit with a paint brush.
That's the Audioslave logo on top.
Old 02-20-2003, 04:44 PM   #5428
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
I have a good mod, use the trinity bumper brace. It doesn't crunch back like the stock losi one.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-20-2003, 04:53 PM   #5429
melnyk's Avatar
From what i have read on this forum is the best way to free up your losi is to take the sheilds of your bearing if iam correct however when you do that won't the bearings become more prone to attracting dirt
melnyk is offline   Reply With Quote
Old 02-20-2003, 05:06 PM   #5430
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
melnyk.....Oil attracts dirt but with out the sheilds and oil to keep the bearings lubed you will get more dirt and grit into the bearing....thats why some guys only take off the inside shields so they dont attract dirt as easily and the bearing is free.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
