Old 09-25-2001, 11:19 AM   #526
Regional Moderator
Addict sa RC's Avatar
Default Power Cap Placement ???
To those who are using Novak C2/TC2 ESC's, where did you put the humongous power cap on the chassis? Thanks.
Addict sa RC is offline   Reply With Quote
Old 09-25-2001, 12:41 PM   #527
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I shoeGoo'ed it to the back of the Speedo case. It sits between the chassis tub & the speedo. It is there...and isnt going to move.
Make sure there is enough space between the motor and the speedo too. I have mine mounted so that the CAP has just enough space to sit on the top of the chassis "rail" and the speedo case.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 09-25-2001, 12:50 PM   #528
on top of the lexan spur gear cover: first take all the cover screws out. then clean the lexan and the top of the chassis tunnel with motor spray. then place a piece of servo tape (losi tape is the best: the thin stuff) where the 2 screws used to go covering the holes(you won't need them). then put the lexan back where it used to be(pressing firmly). then place another piece of servo tape on top of the lexan going back to the rear tower. put the power cap on the front most part of the servo tape to keep it in place. now you have a hinged servo cover and a home for your power cap.
holy ear guy is offline   Reply With Quote
Old 09-25-2001, 01:36 PM   #529
mike_Webb's Avatar
Send a message via AIM to mike_Webb
If you have it on your gear cover then are you soldering the cap to the Battery wires or did you extend the wire from the cap to connect to your speed controller? My wires on the cap are very short. and if I did that I would have to find really small wire to run it to my lrp quantum. I am glad I don't have to use it because I run stock. I do however want to rig the cap up so that I can have like a male and female small cennector so that when I race stock I can unplug the connector from the speed controller to the cap and when I run mod I can plug them together.
Mike Webb
mike_Webb is offline   Reply With Quote
Old 09-25-2001, 08:13 PM   #530
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
if you look back on the tread a ways, you will find the conversation on that topic...with pics...
Matt M. is offline   Reply With Quote
Old 09-25-2001, 09:23 PM   #531
Trader Rating: 23 (100%+)
this is how I mounted my CAP.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 09-26-2001, 01:07 PM   #532
Regional Moderator
Thanks Guys!
MDawson, so that's what those holes on the side of the TC2 are for.
Old 09-26-2001, 01:26 PM   #533
mike_Webb's Avatar
Losi has some new partsa for us.....
Old 09-26-2001, 05:28 PM   #534
Ty
Ty's Avatar
Trader Rating: 29 (100%+)
Anyone:
I race indoors on carpet with foams. I need to know how much to trim the shock shafts up front and the plastic shock end??
Also I will get the Losi threaded shock bodies for the rear of the car, but should I wait for the short shock bodies for the front or will it not make a difference compared to the regular threaded bodies?
Anyone know the part number for the Trinity blue shock collars?
MDawson: what is the part number for that heatsink?
What bodies are you guys running indoors? I have a Vauxhal Opel now but I also might get a Protoform Stratus or Andy's carpet Stratus.
Can you run the belt all the way loose in stock without it slipping?
Thanks everyone.
Ty is offline   Reply With Quote
Old 09-26-2001, 05:30 PM   #535
has anyone put the threaded shock bodies on yet?
how about the short shock shafts for the front shocks?
Old 09-26-2001, 05:34 PM   #536
Check the post on talk-tech. I bought the heatsink for my old SW.
As far as the belt, you can get away with 3-5mm of sag between the rear diff and spur.
TEAMORCA.SHOP
Old 09-26-2001, 05:36 PM   #537
Been running them since I got the car. A must have for fine-tuning.
As far as the shock shafts, cutting the threads is a definate improvement in getting good dampening.
TEAMORCA.SHOP
Old 09-26-2001, 06:10 PM   #538
RCTech Member #2
TSR6's Avatar
Trinity TK3028
Troy
RCTech Member #2
Old 09-26-2001, 08:09 PM   #539
Ty
Ty's Avatar
What is the part number for the Trinity collars for the Losi threaded shocks and how much should I trim the front shock shaft and also the plastic shock end? Thanks everyone.
Old 09-26-2001, 08:38 PM   #540
Ty,
The Cyrul shock shafts are .100 shorter than the Losi shafts. The shock bodies are .080 shorter. Do nothing with the lower shock mount.
TEAMORCA.SHOP
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
