Old 02-16-2003, 04:28 PM   #5356
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Looks good KO.. I got the clamp off eBay.. serpent vector has them (not at the moment)
You should do the shock mount mod when you get a chance.. you'll love how it makes it easy to do shock work.
ChristopherKee is offline   Reply With Quote
Old 02-16-2003, 05:00 PM   #5357
Christopher--- do you have a good starting point set-up for GBurg' (Mimi's) and maybe one for RCO?????
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 02-16-2003, 06:44 PM   #5358
Send a message via AIM to BlackFlagRacing
impact, i did try the seach first, I searched "roll out" and the results were inconclusive. thanks for posting it for me. rob
BlackFlagRacing is offline   Reply With Quote
Old 02-16-2003, 06:49 PM   #5359
Regional Moderator
R/C Tech Charter Subscriber
yeah yeah the shock mount where do i get it
Ko Racer is offline   Reply With Quote
Old 02-16-2003, 09:39 PM   #5360
Ryan C's Avatar
BlackFlagRacing impact, i did try the seach first, I searched "roll out" and the results were inconclusive. thanks for posting it for me. rob
hey try this site for your roll out info
http://www.rcracing.com/Gear_Ratio_Program_1100.cfm
It should help you.
Ryan
Ryan C is offline   Reply With Quote
Old 02-17-2003, 07:44 AM   #5361
rayhuang's Avatar
Oh well-I guess my mods werent enough as i snapped another shock shaft yesterday. I was running Mod (I never run Mod) and clipped a board and snapped it clean off at the top of the threads. not a huge hit-even for mod-but broke it anyways!! Darn!!!
Old 02-17-2003, 09:29 AM   #5362
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Yeah I had the same thing happen to me. My suggestion, get teh trinity bumper brace (the matt francis one) but not the red matt francis foam bumper. Then take the stock brace off and put it there in its place, use the swaybar holes to mount it. The trinity brace has a smaller area but its much stiffer, keeps teh bumper from folding back, and doesn't hit the shock shafts
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-17-2003, 09:46 AM   #5363
rayhuang's Avatar
Axiom5B-Luckily I still have those upper bumper braces!!! _That bummed me out as it also broke the bottom spring perch and no one had a spare. We hardly ever have a Mod class so I was really looking forward to it. So I just raced my TC3 in stock class.
Old 02-17-2003, 10:05 AM   #5364
Default rear diff slop
I just built a new G+ and find that I have about .040 side to side slop in the rear diff housing. Anybody else noticed this and should I try to shim it to take some of it out?
Also, how much weight can be saved by replacing stock steel screws with alum or ti screws?
timc is offline   Reply With Quote
Old 02-17-2003, 10:43 AM   #5365
CRASH's Avatar
Trader Rating: 26 (100%+)
Post Diff Movement
Originally posted by Dave Kurschner
Crash - it is normal to have some play on the diff bearings. Usually, there is much more play front to back than there is up and down. I have been running mine this way for several months with no found ill effects on performance, diff wear, or anything else. It is better to have a little play than for the diff housing to be molded so closely that some would squeee the bearing and cause binding along with other problems. This space is left also if you desire to shim the bearings to center the belt on the pulleys. You can use very thin brass or even electrical tape. Only shim on the chassis side. This of course is a very fine adjustment but can give you even further drivetrain efficiency. Make sure to leave a small amount of play even if you do shim. But as I've said, I've run mine without any shimming and my car rolls very free.
Hope this helps.
CRASH is offline   Reply With Quote
Old 02-17-2003, 10:47 AM   #5366
timc,
The diff slop you feel is fine. When the car is running the diffs center themselves because the belt is driving them. The play you feel is not enough to ruin anything and is not detrimental at all. You wouldn't want the diffs pressed right up against the housings to create drag now would you?
USVTA Member #211
Old 02-17-2003, 10:57 AM   #5367
Regional Moderator
Lets see some more photo's of the xxx-s and GP I like pic's
Old 02-17-2003, 11:11 AM   #5368
CRASH / AXIOM,
Thanks for thereplies, guys.
Still wondering if anyone knows the weight savings on going with ti screws.
Old 02-17-2003, 11:37 AM   #5369
I just put a TiR screw kit in my car, I think it was about .5-1oz lighter than the stock screws. I don't really remember my car's weight with the stock screws(was somewhere around 52.5) but with the TiR screws I'm only 51.8oz
JeffC is offline   Reply With Quote
Old 02-17-2003, 11:44 AM   #5370
Thanks, Jeff.
Where did you get the screw kit and how much was it?
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
