Old 09-24-2001, 11:53 AM   #511
Trader Rating: 19 (100%+)
Originally posted by stefan
Mr.Losi,
yes, bearings do blow, but I wouldn't expect it at the very first race with a stock motor.
To be quite honest, the car has a few issues I don't like:
1.) The issue with the front shock shafts being too long
2.) The shock eyelets pop off REALLY easy
3.) The set screws are a joke, because of the way too soft plastic they are threated into. They don't hold their settings during a race.
4.) The spur gear bearings
5.) ALL screws and turnbuckles started rusting before I even had a chance to run the car for the first time. This doen't affect performance, but heck, the car looks older than my 2 year old Yokomo.
Well,maybe I'm just spoiled by my Yokomo, but I think Losi needs to fix this stuff to live up to their reputation.
I can give you a bigger list of things that were issues with my Yokomo Special. Every car has its vices.
-cut your shafts.
-place washers on the outside of the eyelets.
-change to graphite carriers
-first I have heard of with the spur bearings, were they over tightened?
-rusting?? again, first I have heard of.
MDawson is offline   Reply With Quote
Old 09-24-2001, 12:45 PM   #512
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Jam - $50? good deal..
Get the graphite chassis.. It is about $50 too.
The reason some of the stuff rusts is you can do stainless or you can go with the hardend. The stainless bends... The hardend really doesnt. The hardend Hinge pins have this problem if left stored it "damp" places...
As for the brearings.. They fail.. But there i susually a cause.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 09-24-2001, 01:52 PM   #513
Regional Moderator
Darkseid's Avatar
I have heard of a few people at my local track that have had problems with the bearings on the XXXS.
I have had trouble with the bearings on my Corally too. I think the companies may be slacking a little in this department.
TLR 22...Tamiya F104...
Old 09-24-2001, 03:35 PM   #514
R/C Tech Founder
R/C Tech Charter Subscriber
In the Losi instruction manual it mentions that there is some belt skip with low-wind motors or other unusually "torque-y" configurations. It says it is normal and will not affect performance. However, I have not actually observed this on my own car or any of the others I've seen. Playing with the belt tension is about all I can think of.
stefan: If the screws on your car are rusting, you must be storing it under some strange conditions. I keep mine in my living room on the mantle (heh heh) so that might not be a big problem for me, but if you're storing it in, say, a damp garage or basement, you might consider moving it indoors or storing it in some sort of airtight container.
futureal is offline   Reply With Quote
Old 09-24-2001, 03:39 PM   #515
RCTech Member #2
TSR6's Avatar
Proud - They have said it is normal for it to click about 2 times under hard braking.... The belt is supose to be able to handle that. Read through previous posts in this thread, and you will see other people experiance this too.
Troy
RCTech Member #2
Old 09-24-2001, 03:47 PM   #516
Suspended
Cool So it's worth it ?
Yeah troy, I really could not believe it myself, so I will get the graphite chassis, And some of the steel stuff on this car is kinda rusty too. He must have been storing it in the bathtub,LOL
Anyway thanks for the tips and I'll let you all know how it compares with my trusty TC3.
Jamracing 1 is offline   Reply With Quote
Old 09-24-2001, 03:58 PM   #517
RCTech Member #2
TSR6's Avatar
The only part on my car that is showing any rust is the rear hinge pins. They had a very slight bit of rust on them... and i just took a cloth & polished them. They look great now...
Troy
RCTech Member #2
Old 09-24-2001, 04:37 PM   #518
Moderator
Speedo's Avatar
Troy, I use a product called brasso, stick the pin in the drill/dremel and polish them up, almost good as new.
Speedo is offline   Reply With Quote
Old 09-24-2001, 05:30 PM   #519
RCTech Member #2
TSR6's Avatar
Speedo - They didn't need polish... They didnt rust very bad... jsut had a very little ammount on them. You wouldnt even notice untill you look at it close.
I have other stuff i can use also. Mother's Polish & then some stuff i have used that is like a fabric with the solution built in...you rip a piece off then put it back in the can if its still good.
Troy
RCTech Member #2
Old 09-24-2001, 07:32 PM   #520
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Found a place that has Titanium Screws. I worte down all the screws that the XXX-S has and tomorrow I am going to call them and see how much the set cost for all the screws. Here is a link to their site.
http://mdmetric.com/
Mike Webb
mike_Webb is offline   Reply With Quote
Old 09-24-2001, 07:59 PM   #521
Mike Webb
It looks as though they only sell Metric ti-screws. Let us know if they do have Standard 4-40.
Old 09-24-2001, 09:21 PM   #522
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
let me start by saying i have raced most of the popular touring cars on the market...and yes i am a "losi guy"..i really liked my street weapon, i then went to a 414x, which tought me to drive fast...then i got a tc3, which was great on carpet but i could not get a handle on pavement....my losi is great....let me say if you have problems with this car or any other, do not bitch and complain about it...all the things you mentioned are very small problems, and can be fixed quite easly...you are splitting hairs...if you dont like it, sellit and get something different...period....i have raced my xxxs on pavement exclusivly for a couple months...and the only parts i have broken are ae spindles....
Matt M. is offline   Reply With Quote
Old 09-24-2001, 09:34 PM   #523
I would have to agree. I have ran SW to TC3 to YokSpec and back to Losi. This is the best all around car that I have had and recent success has shown that.
I am for helping those to want to be helped and share setups but not interested in listening people slam things they dont understand. There are easy things to look out for. At some point we should put a FAQ together regarding this info to help the new guys get it together.
Old 09-24-2001, 09:49 PM   #524
R/C Tech Founder
If anybody wants to start a separate FAQ thread, go for it. I think that would be a great idea. It is stuff like that that I can post up on the home page under the "Articles" section, and give all of you credit who submit stuff.
Actually, I just had a great idea for a new forum. Vehicle FAQs! The first post in each thread can be a "running post" to keep all of the information, and be continuously updated by the creator. Everybody else can respond to the thread with any information they might have, and the first poster (the "keeper") can add the information to the first post.
Good idea!
Old 09-25-2001, 05:28 AM   #525
Trader Rating: 35 (100%+)
Post
As an outsider (I haven't bought the XXX-S, yet), I appreciate both the positive and negative comments about this or any other kit/product that I'm thinking of buying. The internet being what it is (free and open to anyone that has a Library Card), I feel that I'm able to "filter" the constructive criticism from the "Haters".
Geppetto is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
