Old 02-01-2003, 04:21 PM   #5176
JLMG1971's Avatar
I just finished building my XXX-S G+, it looks like a great car, though there are a couple of things that were a bit dissapointing:
1. The spur gear is warped, and it rubs against the belt tensioner
2. The front right 4* block carrier has a bit more than 4*, in fact it is quite different than the left one.
I'll try to email Losi to see what they'll say about it, it is my first Losi so I don't know about their after sell service....
JLMG1971 is offline   Reply With Quote
Old 02-01-2003, 09:10 PM   #5177
Simon K's Avatar
Originally posted by Axiom5B
Hmm...that's interesting...I've had some pretty darn hard hits w/ a 9 turn on a tight course...no snapped shock shafts. I've tore both front arms off the car but nothing else broke. LOL, both times i snapped the arm i barely touched the pipe on the inside of a sweeper...interesting that it looked like i slammed a brick wall....
Simon K,
You didn't use a 4-40 tap or at least that little tapping screw they provided?? Doh! That's probably why it took you 8 hours to build, mine took like 5.
I did use the tap.
However, I didn't receive the wrench I ordered so had to use the nasty little allen key in the kit. My soft little sausage fingers can only take so much
Also have to make sure the rest of the assembly is up to my standard too
Got to the track today, ran 2 and a bit laps and pulled the car to check the diffs.
Then it rained...........ARGHHHH!!!!
Those two laps showed some potential though, very easy car to drive fast. Yay. 10 double for now with a 9 single on the way...
Simon K is offline   Reply With Quote
Old 02-01-2003, 11:30 PM   #5178
jjmudd's Avatar
jlmg1971,
Make sure the bearing in the tensioner pully is fully seated. This could be what is causing your problem.
jjmudd is offline   Reply With Quote
Old 02-02-2003, 06:39 AM   #5179
JLMG1971's Avatar
Originally posted by jjmudd
jlmg1971,
Thanks for the advise, I have check everything there, you can really see the spur is warped.....
Old 02-02-2003, 11:22 AM   #5180
JLMG1971's Avatar
Anyone know the P/N of the 128 tooth blue 64 pitch gear/pulley, I've looked through the Losi website but I cann't find it.
Also does anyone know if the A-Arms (front and rear) for the XXX-S are interchangeabla with the XXX-S G+? I'd like to buy spare A-arms for my G+ but prefer to buy plastic ones...
Something else, where can I find the Alum shock collars?
Old 02-02-2003, 11:34 AM   #5181
NeO-pRo-3's Avatar
JLMG I know the pinion gear for the BLUE spur 128th 64 pitch. I use that spur gear myself. The pinionis 36 th 64pitch. It's really fast on stock motors. A local Pro Driver gave me that information. (Brian Kinwald)
NeO-pRo-3 is offline   Reply With Quote
Old 02-02-2003, 12:11 PM   #5182
JLMG, I'm not sure on the part number... the first blue spur I bought was warped very bad also.
I think the front arms should be the same, but the rears are different. The G+ rear arms have 2 holes for the outer hinge pin (inner hole is for the new offset rear, outer for the old standard rear hubs). The original xxxs arms will only work if you use the older rear hubs.
JeffC is offline   Reply With Quote
Old 02-02-2003, 07:17 PM   #5183
Send a message via AIM to ZER01
Originally posted by tufferwilde
Proudwinner - the first time the shaft broke... yes, nothing else broke... not even a scuff on the new body - but this wasn't the case for the last one - I managed to tear the left front clean off of the car.... 9 dub through a chicane a little tight will do that I guess, so that one was deserving!!
Later
Wilde
tufferwilde, I just built my new G+ but I didn't grab the top of the threads of the shock shaft with some wire cutters to thread on the shock ends like the manual says. I grabbed the very top of the shaft where the piston goes with some pliers to thread on the shock ends. This cannot hurt any performance of the shock and I didn't weaken the threads by cutting into the shaft to hold the shaft to thread on the shock ends, I beleive this is why you are snapping shock shafts right above the threads-that is if you're grabbing the top of threads with some wire cutters to thread on the shock ends, I don't know, I let you know how mine go.
ZER01 is offline   Reply With Quote
Old 02-02-2003, 07:23 PM   #5184
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
In two litterally mirror-image hits.. exactly the same.. I broke the shock eyelet on two different cars in the same day. The shock shaft itself is fine, but the A-arm on the one car, Castor block on the other, and both car's shock eyelet's were destroyed. They were both heck-uva hits.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 02-02-2003, 08:47 PM   #5185
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Default Losi Alpha & Setup Questions
I finally got to use my losi alpha last sunday and today and have some questions. Do any of you think it causes the car to be to twitchy with exesive steering response or have a lack of rear downforce? I switched to this body from the stock stratus and had a really hard time, today especially,getting rear traction on a smooth, untreated assphalt track. If you had the same impressions and switched to another body, what do you recomend?
Also, as I said, today I ran on a smooth sealed surface with lots of 180 switchbacks and had a problem all day with rear traction. The track temp was 88-100 and I tried everything from a Sorex 24-32 and when I pulled the car off the track the tires never showed any signs of heating up! It was like they just skated over the top the whole time. I ended up with this set up:
Full graphite car with diffs(not g+, stock roll center)
Front
60 weight (started with 50)
purple springs (started with greens)
thinest swaybar (started with none)
Rear
50 weight
silver springs
Shocks all the way in on the tower
Everything else is stock including Camber links except for the rear inner link I am on the number 2 hole.
Still could not get the car to hook up in the back, even tried traction compound (Wd40 and Paragon) which I never use. The car was so loose it looked and fealt like I was driving on ice. All the Tc3's were so hooked up in the back that I even saw some of them bouncing around turns. I didnt even think to try going up from the 0 degree rear hubs until after the race, would that have helped a lot?
Thanks, Blake.
Blakesrc is offline   Reply With Quote
Old 02-02-2003, 09:37 PM   #5186
I've been switching between the Losi Alfa, and the Protoform Stratus. The Alfa definately has more steering, feels a bit twitchy too. I really like the Alfa with rubber tires, car felt much more hooked up. With foam tires, I just went back to the Stratus. The car feels much smoother, and is easier to drive. The Alfa seems about half a tenth to 1 tenth a lap faster, but I'm much more consistant with the Stratus.
Old 02-03-2003, 05:22 AM   #5187
ausracer's Avatar
is the losi alfa body ifmar legal. when we have the bigger competitions they seem to check the body more then anything. and that rear wing seems awfully high even when trimed.
ausracer is offline   Reply With Quote
Old 02-03-2003, 08:12 AM   #5188
tufferwilde's Avatar
Default Alfa Vs Stratus...
Gotta give the edge to the Alfa so far - I have tried MANY different styles of stratii - Protoform original stratus, 2.0, Trinity Aspahlt and Carpet stratus, Yokomo versions, Andy's versions - and even an HPI thrown in for the fun of it.
The Losi Alfa does seem to exibit a ton of steering... but to me - that is just fine!! The fact that the car is completely stable at high speeds is what sold me on the body. None of the wiggle that you get from a neutral body like the stratus.
Proudwinner -
Well, considering that I have built the Losi shocks using the side cutters to hold the shafts since I started running Losi's and have never broken a shaft on any car like the two on the G+ --> I am going to continue to blame a run of poor materials on the broken shafts. The fact of the matter is that the pressure required to hold the shaft sith a sie cutter doesn't even scratch the surface means that there's no possible way that method could damage the shafts.... Since the originals were replaced - none broken either!
Anyway - thats just my .02 on the issue!
Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 02-03-2003, 08:19 AM   #5189
rayhuang's Avatar
Default Shock shaft
Just to revisit this old story-at my track we broke another shock shaft and also two more shock ball ends. All on good-A-main drivers. Not hacks in other words!!
One driver just replaced both front shock shafts with TC3 equipment since no one had Losi shafts!!. Its slightly smaller in diameter, but negligable. 0.001" ???
Old 02-03-2003, 09:32 AM   #5190
racecar850's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to racecar850 Send a message via Yahoo to racecar850 Send a message via Skype™ to racecar850
Default Re: Shock shaft
i`m in that "hack" group of drivers, ( hoping to be an A-main drive one day) maybe i`ve been lucky but hav`nt broke any shock shafts (plenty of other parts though). When i assembled my shocks i wrapped the nose of my pliers with electrical tape and held onto the shaft itself.
Mugen MTX-4 :tire:
T-MAXX 3.3 :deathstar
MacBook...got fed up with pc :confused:
DRIVING...An inconvenient way of getting from A to B
racecar850 is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
