Old 01-30-2003, 02:12 PM   #5146
Trader Rating: 71 (100%+)
Nitro TC3 castor clips work great on the arm spacers.....
RCAmerica - Xray - Hudy - ProLevelRC - R1Wurks - BSR Racing Tires
RBLove is offline   Reply With Quote
Old 01-30-2003, 02:29 PM   #5147
tufferwilde's Avatar
Jeff C - The Yokomo wheel hex's work just fine, but the hole for the axle has to be reamed out a little bit for the US spec axle to fit (vs. metric). Another thing to watch out for is the fact that the Yokomo Drive pin is quite a bit fatter than that of the Losi...creating slop and backlash in the axle - which I am sure will not aid in longevity of the axle!
Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 01-30-2003, 03:00 PM   #5148
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
RPM makes some clips for both the Associated shocks and the Losi shocks. I don't know if they will fit for suspension pins though. It does sound like the ntc3 clips are the way to go though.
futureal, you always pay too much.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-30-2003, 03:07 PM   #5149
Regional Moderator
R/C Tech Charter Subscriber
thanks for the info rob i got your old xxxs graphite car and noticed them on it and wanted some for my GP. very nice that you can move the arm forward or back with out taking it apart
Ko Racer is offline   Reply With Quote
Old 01-30-2003, 03:16 PM   #5150
R/C Tech Founder
Is that what I get for shopping at KT Hobbies?
I was just guessing on that $11 figure anyway, I seem recall that's the MSRP on those collars...
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 01-30-2003, 03:24 PM   #5151
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Ok the reason I posted what I said was b/c guys were talking about when they use foam tires they rub on the shock. So the reason to get more throw is with the 28mm foam tires they rub on your shocks at not even full throw. I have a gold washer glued on my steering knuckles to reduce throw but the foam tires still rub so what I was suggesting before was for the use with foam tires that are 28mm wide.
And for the remark of this being hack tuning.....umm yeah
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 01-30-2003, 03:27 PM   #5152
Super Moderator
Kraig's Avatar
I guess I deserve that. The red ones sell for $6.99.
Old 01-30-2003, 04:07 PM   #5153
KevinK - yeah, I knew what you were saying - but sitting in an office all day long puts me in an argumentative mood sometimes... that and dealing with idiots (at work)
If you are still hitting the shock retainers - try like .090 limiter glued to the spindle (I think that is what I have on my carpet car)
Wilde
Old 01-30-2003, 04:23 PM   #5154
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
I have an easy fix. You know how the spring retainer has the slot where you slide the shaft through? Just make sure that's facing outside, so when you go crank the wheels all the way, the tire doesn't hit anything, i've tried it.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 01-30-2003, 05:00 PM   #5155
but once again - we are asking the question why that much steering throw would be needed - the drivetrain simply becomes bound up when the wheels are turned that far!
Old 01-30-2003, 05:50 PM   #5156
STLNLST's Avatar
Trader Rating: 19 (100%+)
how easy is it to change the clips? I'm already going to get some but I just thought I'd ask
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-30-2003, 06:34 PM   #5157
Kevin K's Avatar
Ok Im not sure how you setup or drive your car but I drive my car most times lock to lock meaning I use the full range of my wheel travel and if I have to reduce my turning radius b/c of tire rubbage why not work on whats rubbing and still keep the same amount of travel.....dual rate is "hack tuning". When you use foam tires and the bigger the tire the better and they will rub in the front with out being very far into your tire sweep. Also if your track is on the tighter side like lanes that are say 6 to 8 ft wide you should be able to turn a 4 foot circle so you can turn around in the lane with out getting stuck on the other side.....most carpet tracks are this way...well up here they are they are not super speedways like outdoor tracks that have gas tanks racing on them. Yes I know that when you turn the wheels more it binds up the car and Im not driving my car at max throw in "EVERY" corner but at some slower speed corners you need more throw to get through them faster and if your tires are rubbing its more of a binding problem.
Old 01-30-2003, 06:43 PM   #5158
Kevin did you get my post about the spring retainer? I'll show you this weekend what i mean, they dont hit!
USVTA Member #211
Old 01-30-2003, 06:54 PM   #5159
Recently built a graphite kit. Turned aluminum screws, taped batteries, radiused chassis edges, and drilled motor mount and my car was 3lb 2oz with transponder. This was with stock motore and Sanyo 3300's. The new car is MUCH lighter.
How about posting picture on what you have done ?
ongbenghui is offline   Reply With Quote
Old 01-30-2003, 07:09 PM   #5160
Kevin K's Avatar
Yeah I know what you are talking about but that leaves a small window for error and thats just one more thing to check everytime the car is run.........dont forget your shock should rotate left to right so that opening is not going to be in the exact same place everytime.....what I talked about before its not a problem.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
