Old 01-27-2003, 10:25 PM   #5116
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
kraig: thanks. i actually went to your site the other day already but the screw kits were listed as out of stock. glad to hear you're supplies have been replenished. Thanks! A friend of mine will be ordering soon.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 01-27-2003, 10:33 PM   #5117
Send a message via AIM to ZER01
Thanks Ben.
ZER01 is offline   Reply With Quote
Old 01-28-2003, 04:55 PM   #5118
Da4head's Avatar
Default Traction roll
I noticed alot of foam carpet setups uses the low roll centers. Since the low roll center allows the weight transfer to travel further, does this bring on a traction roll condition. I would have thought a high roll center would be more suitable in this application. Can anyone explain.
Da4head is offline   Reply With Quote
Old 01-28-2003, 06:17 PM   #5119
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Low roll centers allow the car to roll more in corners and thus, makes it less likely to traction roll. People just use swaybars to counter the roll effects.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 01-28-2003, 06:32 PM   #5120
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Team AE.....A spool is going to give you more exit steering not less....a spool will give you less turn in steering.....and your corner speed should be up because you can get on the gas sooner through the corner to pull the car through it.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 01-28-2003, 06:53 PM   #5121
On tight tracks with lots of close switchbacks, i recommend keeping a diff in. The spool will give you more exit steering, but if you don't have lightning reflexes you will turn too much on exit and make your laps slower. Spools are good for tracks with flowing turns and big sweepers, like TCHR.
USVTA Member #211
Old 01-28-2003, 11:22 PM   #5122
Da4head's Avatar
Default Tire width
With the AE hex, a wider tire can be used on the XXXS. What tire width works the best and is this width consistence front and back.
Mixing different width example 26mm front and 28mm rear seems to make the car feel somewhat twitchy.
Old 01-28-2003, 11:59 PM   #5123
jjmudd's Avatar
Are you sure that at your advanced age your hand isn't just shaking??!!
jjmudd is offline   Reply With Quote
Old 01-29-2003, 08:46 AM   #5124
Da4head's Avatar
Mudface
Causing quite a stir, we'll have to settle this on the track
Old 01-29-2003, 08:51 AM   #5125
tufferwilde's Avatar
Kevin K - I agree with you on the spool... exactly the same results I had last weekend. The track I was testing the spool on didn't have too many sweeping turns - mostly 180's and chicanes... so suffice it to say, the spool wasn't the hot setup for me.
Da4head - So far I have liked 25mm up front and 28mm in the rear running mod on Ozite, and 28mm all around for stock... and yes, with the AE hex's you can run the 28's up front, but at full throw, you are still going to hit the shock retaining clip on the bottom...
out - wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 01-29-2003, 12:47 PM   #5126
JLMG1971's Avatar
Hi
I am getting friday a new XXX-S GP, I'd like to know what spur the car comes with, I want to buy the pinions at the same time I pick up my kit from my LHS. Also an tips about building this car? I have driven a TC3 for the past two years so this is my first experience with Losi
JLMG1971 is offline   Reply With Quote
Old 01-29-2003, 01:03 PM   #5127
JLMG - The G+ comes with the 90 tooth 48 pitch spur....
Tips - make sure to tap all holes on the car before putting the screws in ... Take all sharp edges off of the chassis with a file...
Wilde
Old 01-29-2003, 01:25 PM   #5128
JLMG1971, I've just finished building it last night. You have a great car. For tapping, I've used a screw that came in a tool bag, I think instruction will tell you to use it.
My shock collar(black plastic) was bit too tight so I am getting a aluminum ones. Other than that, it was easy and I've build it in no time.
Enjoy!
KK
DoCoMo is offline   Reply With Quote
Old 01-29-2003, 03:22 PM   #5129
Default HELP WITH CERAMICS BEARINGS
Hi Guys,
I am thinking of buying a set of ceramic bearings from Acer racing for my XXX-S GP.
1. Do you think that i will understand the ceramics bearing in the track?? ( i mean i will notice a better rolling or a better accelaration, or a better eficiency on the battery???).
2. Do you think that i will save some grams from the total weight of the car??
3. Do you think that it worth buying these kind of bearings or go for the teflon ones???
Thanks a lot guys
Harris
harris is offline   Reply With Quote
Old 01-29-2003, 03:46 PM   #5130
JLMG, do yourself a favor and pick up the 128 tooth 64 pitch gear/pulley (it's the blue one).
USVTA Member #211
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
