Old 01-25-2003, 08:49 AM   #5071
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
STNLST - Yes! The new bearings are much better than the old bearings. I only sprayed and removed the inside shields for the diff bearings, and fully de-shielded the spur bearings, and my car already rolls just as well, if not better than my old xxx-s, with all inner shields removed.
I didn't even spray out or deshield the bearings in the hubs!
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 01-25-2003, 09:00 AM   #5072
STLNLST's Avatar
Trader Rating: 19 (100%+)
TSR6- Hey you forgot one "L" in my name.....lol I'm thinking of taking the shields off but it seems to be just fine right now. I may spray them out closer to a big race but for the club level racing I'm going to leave them alone....on the other hand it couldn't hurt to just do the one's you did. The car is already apart for my monthly cleaning. Any other suggestion before I put it back together later on tonight??????
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-25-2003, 12:54 PM   #5073
RCTech Member #2
TSR6's Avatar
Whoops!
Nothing that I can think of for you. I also just took apart about 1/2 the car for cleaning and re-lubing. I re-did all the bearings.. but after one club race, and the Novak USTC champs, they were all perfect.
Troy
RCTech Member #2
Old 01-25-2003, 01:09 PM   #5074
Oasis's Avatar
Trader Rating: 36 (100%+)
STLNLST,The only suggestion I have is...get a Yokomo,like matt did.
Oasis is offline   Reply With Quote
Old 01-25-2003, 07:48 PM   #5075
STLNLST's Avatar
Matt hasn't finished a race with that Yok either
The Losi's are coming to your track very soon.
Old 01-25-2003, 07:49 PM   #5076
STLNLST's Avatar
TSR6- thanks!
Old 01-25-2003, 09:23 PM   #5077
Matt Howard's Avatar
Stlnlst- correction, I haven't finished a main yet and it wasn't the cars fault. I only ran it the one weekend in stockton and if I remember right I was in the A both races with a car I've never run before that, where were you?
Matt Howard is offline   Reply With Quote
Old 01-25-2003, 09:24 PM   #5078
Oasis's Avatar
From what I heard he likes his yokomo..I like my xxxs but I do break it(rear hubs)I'm trying to get it to work.
Old 01-25-2003, 09:27 PM   #5079
jjmudd's Avatar
Is there a servo saver for the XXXs other than the the stock Losi bit? I think the 414 II will work but it is the same style as the Losi.
jjmudd is offline   Reply With Quote
Old 01-25-2003, 09:47 PM   #5080
ijnek's Avatar
Send a message via ICQ to ijnek
get a kimbrough 1...they r pretty gd...
ijnek is offline   Reply With Quote
Old 01-25-2003, 09:54 PM   #5081
jjmudd's Avatar
The ones I've seen are either too large or do not have enough tension for the digital servo.
Old 01-25-2003, 10:04 PM   #5082
RCTech Member #2
TSR6's Avatar
I haven't had a problem with the stock servo saver. You just need to make sure you have all 3 springs in the saver, and have the outside washer on it. Those are the two msot common mistakes I've done ( ) / seen.
Troy
RCTech Member #2
Old 01-25-2003, 10:28 PM   #5083
jjmudd's Avatar
I found that one of the silver springs leading edges were bent up and they caught on the lip of the saver. I swaped the two silver springs but there seems to be a little bit of play in the saver??
Old 01-25-2003, 10:50 PM   #5084
RCTech Member #2
TSR6's Avatar
3 springs.
2 silver, and one gold if i remember right.
Only using two gives it too much play. I had mine setup with 2 when i originally built my first x-s ..
Troy
RCTech Member #2
Old 01-25-2003, 10:59 PM   #5085
jjmudd's Avatar
I'm using all three...just noticed that one of the silver springs leading edges were bent up and were catching. When I swaped the two silvers it fixed the catching problem but even with all three springs it is a little sloppy. Maybe taking them on and off a couple of hudred times trying to figure out what was binding stretched them a bit!! LOL I did try to pinch them tighter!!
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
