Old 01-23-2003, 09:11 AM   #5041
rayhuang's Avatar
Default Shock help
GUys,
I need a hot tip here!! This is my third XXXS-all with threaded shocsk, etc!!! I cannot build the shocks so they dont squeek or feel a bit less damped by the next day. When I build them, they feel good-dont squeek, can compress all the way-you know everything their supposed to do. AFter they sit for hours, all 4 feel a bit less damped, all squeek. Its crazy-what can I do different-or do I just live with the squeek!!! Thse are brand new shocks this time. Noneshow any sign of leakage and tops are tight!!! HELP!!!
Ray
Old 01-23-2003, 09:27 AM   #5042
Ray- do you prelube the seals?? If you don't they may feel fine when first built and then after setting for a few hours with out being compressed they kinda "bind-up" making that squeeking sound.....
I usually use a q-tip soaked in heavy weight shock oil (100 weight)
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 01-23-2003, 10:43 AM   #5043
rayhuang's Avatar
IMPACTPLAYER-I pre-soaked the seals with a big drop of shock oil about 30 minutes prior to doing the shocks and I dipped the shock shafts in shock oil prior to inserting.
So you build a squeek free Losi shock-hmmmm... back to the drawing board for me then. I was hoping everyone has squeeky shocks!!
IMPACTPLAYER-Thanks for the tip!!!
Old 01-23-2003, 11:21 AM   #5044
Send a message via AIM to munrath
Ray,
Check your email or PM. Call me. It's easier to explain over the phone then in writting. But here goes.
Pour some oil in the cartridge or disassemble and soak everything down and put back together.
Fill shock to 3 -5 threads above the bottom thread
Screw the cartridge in until the is barely a gap.
Snap the bottom of the spring collar on and compress the piston down.
Tighten with a 7/16 wrench or pilers.
Should be in good shape and will last. I can't take credit for this as I had the same problem. (Thanks Todd L.)
Mark.
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 01-23-2003, 11:36 AM   #5045
rayhuang's Avatar
Mark,
I totally 100% understand your explanation!!! Clear, concise post
Thanks,
Ray
Old 01-23-2003, 12:15 PM   #5046
R/C Tech Founder
R/C Tech Charter Subscriber
My Losi shocks often end up squeaking a little bit, and I have never worried too much about it. The action is good and they work well on the track.
Then again, maybe I'm missing out. Who knows. Perhaps I'll try one of these other methods...
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 01-23-2003, 12:25 PM   #5047
Send a message via AIM to TeamRoy
Go to skipgear.com and under the "tech section" there are tips on building losi shocks. If you follow everything that is listed, your socks should be super smooth.
TeamRoy is offline   Reply With Quote
Old 01-23-2003, 12:57 PM   #5048
Send a message via AIM to Dave Kurschner
Tufferwilde - When you use a spool, you will have more of a feeling of pulling the car through a corner. In most cases, you'll experience some push upon corner entrance. Then when you give it some juice, hang on for the tow-rope effect. Usually, to compensate for a spool, you use one step softer front spring on the car. But it depends on the rest of your setup and the tires and track you race on. I've driven some spools setups that have quite a bit of steering all around.
Use the plastice outdrives. If you want some insurance, get the Trinity aluminum outdrive savers. You'll have to file a little bit off the bottom of the front shock tower that sits close to the outdrive as it will rub with the savers on there.
Your car may make more noise going through the corner which is usually your belt skipping. Run the belt a little tighter than you do with a diff or oneway.
Dave Kurschner is offline   Reply With Quote
Old 01-23-2003, 01:02 PM   #5049
Jared Kirkwood's Avatar
Send a message via AIM to Jared Kirkwood
Originally posted by harris
I am using it Cain and it is very easy to install.... but the problem is that i cannot find it anywhere...
Take a look at http://main.SkipGear.com. He is selling the caged thrust bearings. I think he will ship out of the US. Scroll half way down on the home page.
Jared Kirkwood is offline   Reply With Quote
Old 01-23-2003, 02:25 PM   #5050
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
My shocks aren't squeaky all you have to do is work them some and they smooth up.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 01-23-2003, 04:44 PM   #5051
rayhuang's Avatar
Me squeak no more!!!! Thanks for the tips guys!! I came right home from work-tried Todd/Mark's system and shocks came out beautiful!!! YESSS!!!
Thats why I love these forums!! The exchange of info and especially the tips are the greatest!!!
Old 01-24-2003, 09:30 AM   #5052
Default Graphite Plus?
I'm curious if any of you guys that have been running the xxx-s have switched to the new graphite plus. I have been running my car since they came out. I've converted everything to graphite, threaded shocks, mip axles, etc. But obviously, I've got some slop in things over time.
Is it worth it to just get the whole new car. I really want the new front bumper which I have not been able to find. It sounds like the new rear hub is mostly for carpet, which I do not run on.
So are there really any other reasons to step up to the new car?
timc is offline   Reply With Quote
Old 01-24-2003, 10:08 AM   #5053
rayhuang's Avatar
Default Graphite upgrade vs. G+
Chassis is a lot lighter!!! Thats good. Yellow belt and new stiffer rear bumper as well. New stiffer front foam bumper and foam bumper brace.
I had two upgraded XXXs and sold them both to buy this one car and I am happy I did.Oh yeah-and a new rear shock tower with a new row of camber link locations.
Keep your old style rear hubs-this car comes with new offset hubs.
Old 01-24-2003, 10:12 AM   #5054
With the new hubs can be chaged on the arm.
teamAE is offline   Reply With Quote
Old 01-24-2003, 10:25 AM   #5055
Regional Moderator
hey guys can you help me out here i just bought a xxxsGP from a member that said this car has been ran once on carpet for testing only not raced how is it a sealed drive train has a diff that looks that this in it the car was this way
Ko Racer is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
