Losi XXX-S
#4996
I forgot ...
REAR Diff is with 41 tooth pulley too (like front) !
I race on asphalt track outdoors.
#4997
R/C Tech Founder
I am getting my Graphite Plus car this evening, so look for an "official" R/C Tech review up on the main site soon. Better late than never, eh?
#4998
Originally posted by senna
How will the rear diff. effect handling going into corners?
#5000
Hi Kraig ...
In our local championship we use the Corally Street Racer 21 turn STOCK motor. Our final overall gear ratio is usually around 4.50! We have a huge asphalt track outdoors.
I tried almost every combination of setup ... however now that I think about it ... I never adjusted the rear diff. It was always a bit loose.
I also spoke to Matt Francis and like guy (TeamRoy) on this thread, suggested that a tighter rear diff. can help. I will try to tighten a bit my rear diff. next time I go to the track hoping I solve this problem.
Apart from this problem ... the LOSI is great! We have quite a good selection of cars in Malta, TC3 Factory Team, Yokomo, X-Ray, etc. and I still manage to make some of the best lap times ... although I feel that I can still improve!
Thanks guys for your support!
#5001
Senna - you didn't list what roll center blocks you are running. You've listed 2 deg castor blocks and the 0F pivot block for 0 deg of kickup? About the diff, I wouldn't suggest making it much tighter or you'll end up magnifying the problem. Do it in small steps. A looser diff allows you to corner faster. But you have to make sure that your chassis' weight transfer is right first.
After looking at your setup, I still think you should move your rear arms all the way forward. I think you'd be surprised at how much that one little adjustment changes your car's handling. Move your front camber link in to the #2 hole. Try 60wt oil in the front and 40wt in the back. I'd also consider increasing your castor on an outdoor track.
#5002
Hi Dave ...
I use the Trinity (red) high roll centre blocks (front / rear) ... like the standard plastic ones (I think).
As regarding my rear diff, if I keep both diff. halves firm I can still turn the pulley with my thumb (with bit difficulty). Do you think it is loose?
I will try to make the adjustments you mentioned too and see the results.
Thanks again man!
Thanks again man!
#5003
Senna - with a properly built diff, you can run it quite loose without being able to turn the center pulley. I guess it depends how hard you are cranking on it. Remeber that a newly built diff can slip a bit till you break it in some. Just set it so that you can't really turn the center pulley while holding the outdrives.
#5004
Senna,
Where do you run the battery pack? Forward or back?
#5005
Just wanted to publically thank Kraig from KT Hobbies for his help at the Novak TC Champs. He "loaned" me some Losi rear hubs and dynoed a couple of motors for me that he neither built nor sold. Thanks again and "Buy from KT!"
#5006
Has anybody noticed all these posts about XXX-S versus every other car out there?? Let them compare, we know what we have!!
#5007
back to page 1
#5008
well I don't cause I still haven't had the chance to race mine against anyone yet (GP) .... 900 kms return is just slightly too far for tuesday night racing.
#5009
does the g+ version come with the spool , what are the part numbers or is that an after market option .
