Old 01-09-2003, 07:34 AM   #4906
rayhuang's Avatar
Default Wheel hexes
I just use the Graphite ones out of my many FTTC3 kits I have had. They work great are light and never come off when I pull the wheels off. But I use Jaco and TRC foam tires. Maybe some of the rubber tire or Euro brand rims fit tighter on the hex.But having said that-I used to have the O-ring ones on a MR4 and they were awesome!!!!
Ray
Old 01-09-2003, 11:59 AM   #4907
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I run blue Associated TC3 alum. hexes on my new G Plus. They don't have the o ring setup to hold the pin. They are more like the stock plastic ones but once I tighten them rim on once they never come off. I think they press themselves on tight and with a medium tap on the axle I can get them loose. They seem to work very well and I'm happy with them. Plus I like the blue alum. over the red stuff but it is just preferance as I like blue better.
Old 01-09-2003, 12:07 PM   #4908
Suspended
maxboost's Avatar
Send a message via ICQ to maxboost
i have problems with my shock on my GP. here it goes.... when i fully compress the shocks, it bounces back, when i extend them, it goes back to the middle. i followed the manual on shock assembly. is this normal? my droop is no use coz the shocks doesnt fully extend when i lift the car.
maxboost is offline   Reply With Quote
Old 01-09-2003, 12:59 PM   #4909
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Are you saying the weigh of the A-Arm and tire is not sufficient to extend the shock to the proper length? Are you sure you don't have the .28's on the rear? If it's moving to far in... move it up and down a few times. Should settle at about 1/4 in.
My shocks perform the same way. To my knowledge this is how the Losi shocks should perform (suck back in).
ChristopherKee is offline   Reply With Quote
Old 01-09-2003, 01:07 PM   #4910
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Thats how you know you built the shock right, when it sucks back in. But there is no reason why the weight of the arm shouldn't pull the shock back down to set the droop.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 01-09-2003, 01:10 PM   #4911
Suspended
maxboost's Avatar
ok the manual says "there should be no air in the shocks". thats what i did. when i fully compress the shock, it has this pressure inside that makes it bounces back. and when i stretch it out, it has this pressure to go back in the middle.
Old 01-09-2003, 01:16 PM   #4912
ASM
ASM's Avatar
Trader Rating: 19 (100%+)
Dave, a 24 tooth pinion ought to be pretty close if I am correct in assuming you're talking 48 pitch.
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 01-09-2003, 01:21 PM   #4913
Suspended
maxboost's Avatar
im using 24 pinion with the stock 90 teeth 48 pitch spur w/ monster pro. this is perfect for my track. it doesnt get real hot.
Old 01-09-2003, 01:28 PM   #4914
Yes sir, 48 pitch. I've yet to dip into the fancy gear world yet. lol
Old 01-09-2003, 01:35 PM   #4915
ASM
ASM's Avatar
Just got off a carpet track this week-end in prep. for Snowbirds. We were running 19t foams.......the gearing for 19t foams or rubbers is basically identical to stock. TC3's were running 25 and 26 tooth pinions on a track very similar in dimensions. That's exactly how you would gear a stock TC3 too. Two guys were running as high as 27 teeth on TC3's. A 24 - 25 tooth is a good starting point for the losi with rubbers.
Scott Meeks
USVTA Member #116
Old 01-09-2003, 02:04 PM   #4916
ASM
ASM's Avatar
I should state the 27 teeth guys were on foams at about 2.27" to 2.30" in diameter.
Scott Meeks
USVTA Member #116
Old 01-09-2003, 02:38 PM   #4917
Suspended
maxboost's Avatar
motor rpm plays an important role in gearing.
Old 01-09-2003, 02:47 PM   #4918
ASM
ASM's Avatar
Of course it does, that's why I only suggested a starting point. Layout, freeness of the chassis, tire diameter, torque and RPM all factor in. That's all a given.
Scott Meeks
USVTA Member #116
Old 01-09-2003, 06:18 PM   #4919
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
I run foams and with the two 19T motors I have had I have only been able to go up to around 24 tooth pinion (stock 88 spur, 48 pitch) without overheating the motor. My drivetrain is very free, but I have heard from others using trinity chameleon motors that you have to find a sweet spot for the motor. right now, on tighter tracks, I run about 21 tooth or 22. seems to work the best.
What performance difference will I notice with the new yellow belt?
Old 01-09-2003, 06:47 PM   #4920
Send a message via Yahoo to Doug Gaut
Cain, the new belt is sweeeet! You will be able to run it much looser than the old blue belt without the belt skipping. I was able to run mine set to the tension I ran for stock motors while running a 10x1 D5 last weekend with no skipping at all under braking. The whole drivetrain feels smoother and should be even more efficient.
Doug Gaut is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
