Old 01-08-2003, 06:35 AM   #4891
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
The G+ bumpers are much thicker and stronger.
Jeff the only reason he gave me his Enid setup if cause he wants my Comp setup. He already asked me for it. lol
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 01-08-2003, 07:26 AM   #4892
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Originally posted by JitsuGuy
Hey all, what's the difference between a CVD and a dogbone? I want to upgrade the things that go from the outdrives to the hub... I know Losi makes them in aluminum, but are they CVD's or Dogbones? I'm confused.
Thanks,
Jits
John already answered this.. but here is a way to remember.
They are called dogbones because they are shaped like.... "dogbones"
ChristopherKee is offline   Reply With Quote
Old 01-08-2003, 07:42 AM   #4893
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally posted by sleek the elite
also, are there any online shops that have plaids purples cyans and magentas all in stock ?
We are expecting our shipment of tires today.
Even if you don't drill out the shock piston Andrew's setup would be a good one to use. I don't know exactly what he meant but he might have taken a specific piston and just ran a drill bit (Numbered the same) through it to make sure it was sized correctly. I could be wrong though.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-08-2003, 11:14 AM   #4894
Send a message via AIM to TeamRoy
A drilled piston is a #60 piston drilled out to the specific size listed. The purpose of this, is getting a piston hole size in between the two stock pistons. Such as a "drilled 56" will have slighly smaller holes then a stock 56 piston but larger then a stock 57, because of the material that cannot be removed completely with the drill bit. Hope that makes since.
TeamRoy is offline   Reply With Quote
Old 01-08-2003, 12:13 PM   #4895
Send a message via Yahoo to hicheef
Default Aluminum wheel hexes
Is anyone aware of a company that makes locking aluminum wheel hexes for the XXX-s? I'm tired of chasing that plastic piece around the woork bench every time I change wheels. Any input is appreciated
Kevin
hicheef is offline   Reply With Quote
Old 01-08-2003, 12:23 PM   #4896
Matt Howard's Avatar
Trinity make some in their Matt Francis line of aluminum parts
Matt Howard is offline   Reply With Quote
Old 01-08-2003, 07:11 PM   #4897
Yokomo makes them for the TC3, they will fit the XXXS.
eklips is offline   Reply With Quote
Old 01-08-2003, 09:16 PM   #4898
Oasis's Avatar
Trader Rating: 36 (100%+)
Dynamite makes the best wheel adapters for the losi,once you put them on they dont come off unless you want them off,part# dyn6812
Oasis is offline   Reply With Quote
Old 01-09-2003, 02:41 AM   #4899
Default don't like dynamite wheel hex
Hi,
I personally don't like and don't recommend dynamite wheel hex.
Dynamite wheel hex uses a thin o-hole to secure the pin. I have so far broken 2 o-holes already.
However, my o-hole type for my Yokomo MR4 don't have the similar problem as dynamite.
I have since switch to Trinity screw type of wheel hex. Which seems better.
ongbenghui is offline   Reply With Quote
Old 01-09-2003, 03:29 AM   #4900
Does this mean you don't have to worry about the limiters ? My bumpers have still got a bit of flex in them. ( DUH !! they're bumpers)
What about the difference in front shock length between the original and the GP ? Does this matter ?
sleek the elite is offline   Reply With Quote
Old 01-09-2003, 03:55 AM   #4901
Default Re: don't like dynamite wheel hex
Originally posted by ongbenghui
Hi,
anytime an o-ring fails it is due to an installation error, a small cut in the o-ring during installation...... especially when it is in a low pressure situation like the wheels hexes we use.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 01-09-2003, 04:43 AM   #4902
I must be missing something here...an o-ring to hold on a wheel hex... WHAT THE ???
Old 01-09-2003, 05:00 AM   #4903
sosidge's Avatar
The O-ring fits around the hex to hold the pin in place.
Old 01-09-2003, 07:21 AM   #4904
The bumpers are still gonna flex cause they are plastic. But in the G+ the bottom of the bumper where the droop screw sits is thicker.
In the pre-G+ days people ran the yokomo TC3 wheel hexs cause it made the wheelbase wider. The ones with the screw are better then the o-ring IMO, just don't tighter the screw down real hard.
Whats a good starting gearing for a 19t with a 90 spur with rubber tires on a 84 x 48 track?
Old 01-09-2003, 07:27 AM   #4905
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Thicker, and I think they also changed the compound a little bit to make it stiffer also..
The shocks in the rear are still the .36 shafts and bodies, while the shocks in the front are the .28 shafts and bodies.
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
