Old 12-27-2002, 02:20 PM   #4756
Send a message via AIM to Dave Kurschner
Cain - yes that can be your belt skipping even without puting on the brakes. If you are running a standard front diff or a locked front diff, this is more likely than if you run a front oneway. When your car gets good and hooked up, and you take a turn. The front and rear wheels want to spin at different speeds. This is most noticeable with a front spool. So since each end of the car wants to spin at different speeds, something has to give. So either the front tires will have to lose traction and push, or tension will be put on the belt. If the belt is loose enough, it'll make a sort of clicking sound in some of the turns. Just try snugging up your belt tension a bit and that sound should go away.
Ghosttown - just for future reference, there's a really easy search function on these forums. Just type something like "chatter" or "wheel chatter" and it'll bring the information right to you instead of having to look all over for it.
Dave Kurschner is offline   Reply With Quote
Old 12-27-2002, 02:32 PM   #4757
Oh man!! Hey Thanks!
I_GhostTown_I is offline   Reply With Quote
Old 12-27-2002, 03:35 PM   #4758
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Im gonna wait untill they have enough colors to form Super Mega Voltron.....yeah thats the ticket
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-27-2002, 04:10 PM   #4759
Regional Moderator
R/C Tech Charter Subscriber
Originally posted by STLNLST
The yellow belt is the newer belt for the XXXS. It shouldn't need to be broken in like theblue one did. Losi now has a green (off road) blue (on road) yellow (on road) belt. Two more colors and we can form Voltron...lol
thank you for the info im looking forward to Voltron
Ko Racer is offline   Reply With Quote
Old 12-27-2002, 04:37 PM   #4760
R/C Tech Founder
The Losi XXX-S, Defender of the Universe
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 12-27-2002, 04:38 PM   #4761
Regional Moderator
hey guys whats the best online shop to get parts form for the xxxs? sorry for the silly question but losi is new to me
Old 12-27-2002, 04:42 PM   #4762
Go to the links page, you'll swim in ocean of losi parts suppliers.
Old 12-28-2002, 08:09 AM   #4763
Regional Moderator
thank you all for the info again
Old 12-29-2002, 04:33 AM   #4764
ijnek's Avatar
Send a message via ICQ to ijnek
hmmm,...
jus saw a mag tomolo which feature a carbon fibre chassis from IRS for the TC3,looks sweeetieee n KOOL...
how come there isn't 1 for the xxxs???
hmmm,...thinking abt xxxs chassis design,which is pretty unique...
ijnek is offline   Reply With Quote
Old 12-29-2002, 01:12 PM   #4765
well then you would need some extra bits to hold the spur, belt tensioner and motor clamp, as well as some thing to stop the diffs from falling out that would also need to hold the shocktowers up.
Why bother ?? there are plenty of cars that already come with plate chassis. Plate chassis were what was used before designers had the freedom to design molded chassis without losing rigidity, so to me, a molded chassis looks better. more advanced.
Not that there is anything wrong with plate chassis !!! And carbon fibre does look pretty cool, just not as much after you've had about 10 cars that have them.
sleek the elite is offline   Reply With Quote
Old 12-29-2002, 06:27 PM   #4766
Default carbon fiber over existing chassis
oh I hate those milling holes on the left side of the chassis. I put velcros on chassis to attach the receiver and ESC, and those hole affect the effectiveness of the velcros.
Planning to get the graphite chassis and cover the "holes" with carbon fiber cloth,
any thoughts ?
ongbenghui is offline   Reply With Quote
Old 12-29-2002, 06:31 PM   #4767
Default ultimate cool
I thought the ultimate cool factor is to mill out part of the chassis (like kinwald) and cover the exposed with carbon fiber cloth.
Old 12-29-2002, 07:58 PM   #4768
Jared Kirkwood's Avatar
Send a message via AIM to Jared Kirkwood
Link to my setup (in MS Word):
SETUP
I don't race touring much. I based this setup off of what Hodge and a few others have been running. There was a fairly fast guy at the track this weekend so I got to judge my setup to someome else's (he was driving a tc3). Where my car always seems to struggle is the tight parts of the track. There is a section in this layout that has 3 tight 180s in a row and it's killing my laptimes. I turned the fastest lap all weekend but I know it could be better if my car flowed through this section better. It seems to me the car is the 180s wants to push mid corner a bit. I have to wait to long to get back on the thottle to make these turns. The car is worse with a stock motor than in mod. It seems in mod I have enough momentum for the rear to kinda "pivot" more in the tight turns. In stock the rear is just to locked.
The rest of the track the car is pretty much dailed. I wouldn't normally be to concerned about 3 turns but this section makes up half the track.
I was wondering if anyone has any experience with tighter tracks that is similar to the one I race on that we could bounce some ideas back and forth. The ozite carpet track is 60'x35'.
Here's some things I've thought about trying next time out:
- 6 deg front spindle carriers.
- Move the front arms back from current location by .050".
- Move the rear arms back to middle location and then in the far back position.
- 2 deg rear anti squat.
- Try 1/2 deg AND 1 deg rear hubs in reverse for less rear toe-in.
Any suggestions or feedback welcome. Thanks in advanced.
Jared Kirkwood is offline   Reply With Quote
Old 12-29-2002, 08:07 PM   #4769
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
www.kthobbies.com
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 12-29-2002, 08:12 PM   #4770
KINGZJ's Avatar
Send a message via AIM to KINGZJ
Jared,
Allot of us that run on a fairly tight ozite track are running Paul L. setup from the carpet nats. Its pretty close may need to adjust slightly from their.
KINGZJ is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
