Old 12-23-2002, 10:10 PM   #4726
Oasis's Avatar
Trader Rating: 36 (100%+)
They might work somewhere,but not on the track I race at.(outdoor asphalt,tight,smooth)Kit tires are for play,if you race just buy your fav. tire/insert/rim combo and be done with it.
Oasis is offline   Reply With Quote
Old 12-23-2002, 10:18 PM   #4727
STLNLST's Avatar
Trader Rating: 19 (100%+)
I haven't stumbled across a set up sheet that you can type on as of yet. There is one in the works right now. If you see a post from Bigdog on here click on to one of his links (I think it's MSR racing) or something to that effect. They are working on a new set up sheet for the graphite plus.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-23-2002, 10:20 PM   #4728
STLNLST's Avatar
Originally posted by Simon K
Does the G+ come with "Usable" tyres and inserts?
I've got a pile of dodgy kit tyres from many, many cars and I'm hoping to actually use some, rather than instantly bin them...
These are the tire's that I throw in when I sell one of my kits.
Old 12-23-2002, 11:19 PM   #4729
kulasracing's Avatar
Wink cain
glad you took first in the amain cain i know it wasn't easy i just wish i was there to see it practice on off days has helped and that was one off the hardest layouts 25 laps 5:06.56 is realy good keep up the good work
kulasracing is offline   Reply With Quote
Old 12-24-2002, 12:33 AM   #4730
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Arrow TO MY FELLOW XXXS BROTHERS! MERRY CHIRSTMAS TO YOU ALL! LETS RIP THE TRACKS IN 2003!
from Gerry
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 12-24-2002, 11:16 AM   #4731
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Editable setup sheet......What I do for my own use is take the setup sheets off of the Losi page in the JPG format and save them to my desk top and then save them as a BMP then you can open them in MS paint and edit all you want.....its hard to print them from paint but you can keep track of your setups on your PC.
Merry Christams everyone
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-24-2002, 09:48 PM   #4732
Simon K's Avatar
Originally posted by ixlr8nz
Gidday Simon,
Are you planning on racing at the nats?
cya
Mike
I contacted HD about when the kit will hopefully be here, approx mid next month. It could arrive before(yay) or after the nats(Boo)
I can't afford to go anyway so it's a moot point anyhoo
Merry Xmas Mike, have a good one
XXXKat,
Reason I asked was that the original XXXS had some dodgy, cheap looking treaded tyres in the kit. The promos for the G+ showed a slick(I was hoping a Yellow compound slick and med insert )and it would be cool if I could just glue them up and race stock at my local track for club stuff(Cheap option).
I'll be running foam in mod, on asphalt otherwise so it's no real biggie.
Simon K is offline   Reply With Quote
Old 12-25-2002, 01:25 AM   #4733
Default Setup suggestions for carpet?
I seem to have the car as good as its going to get. Fixed the diffs, I had to take another screw and work the threads. I still don't have much clearance from the tire to the shock spring, but I'll try it anyway.
Need a setup for a tight, ozite carpet track. I'm running foams and a oneway.
What should I use for front/rear blocks, caster, springs, shock oil, etc, etc?
Nightbreed is offline   Reply With Quote
Old 12-25-2002, 07:03 AM   #4734
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I don't run foams, But I've found the setups on the Losi website to be a good starting point.
Merry Christmas
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 12-25-2002, 07:22 AM   #4735
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Run 0 squat front and rear
Purple rear tires
Plaid fronts
Black front springs 80 wt oil
purple rear springs 70 wt oil
roll bar front and rear- 1st bar
caster -1
ride height 5 mm front
4mm rear
u will have to play with some other things such as roll centers but this will get u going fairly fast.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 12-25-2002, 10:14 AM   #4736
Tech Legend
Cain's Avatar
Trader Rating: 230 (100%+)
Wink kulasracing
The track was tough, but I really liked the layout better than that one where on the first and last turns you have that one barrier sticking out where you can break stuff. The new shock tower really did the trick. The car can now turn very easily.
I will definitely look into sway bars and see if my local hobby shop can get me a set for the front and rear. There is someone at our track who uses them on his XXX-S and they seem to help his car alot.
Kulasracing, do you know when the new track will be up and running for this sunday? I want to see if I can get in a practice some.
Old 12-26-2002, 07:24 PM   #4737
rayhuang's Avatar
Default Losi and Associated CVD's
hey guys and hey Todd,
I am wondering if theres any reason why you cannot run Associated TC3 CVD Bones in the rear of the Losi?? My Losi parts are on order, but they wont arrive in time for this Sundays racing. Please help!!! I have lots of Associated axles!!
Our LHS's are sadly deficient on XXXS parts.
Thanks,
Ray
Old 12-26-2002, 08:17 PM   #4738
Default cain
bill setsup the track and is ready by 9.00 am
Old 12-26-2002, 10:45 PM   #4739
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
Ray- The bones are pretty much the same length, but the ends are WAY too small for the outdrives.
pimpedaccord is offline   Reply With Quote
Old 12-27-2002, 12:43 AM   #4740
Wheel Chatter
Yeah, yeah, I've know I've seen this come up on this thread before but I REALLY don't want to go through them all for one question.
Our track just doubled in size and normally being a mod guy I finally get to put the crappy stockers back in their coffin and install some power to my new favorite Losi.
Holy @#$% does this make a world of difference! Touring Cars have finally become race cars instead of "an R/C novelty for the winter" in my world. This car is sick fast and major fun on our ozite track now except do to all of the new found speed, I've notice a terrible wheel chatter when left underpower. Again, what was the fix for this? A couple of other guys at the track have noticed this too. Thanks for the help.
I_GhostTown_I is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
