Old 12-17-2002, 05:00 PM   #4666
A wider front bumper is a very good idea. I'm using the kit bumper which is very soft and flexible. I have a blue Trinity bumper, I'll mount it up and see if that helps any. After reading over this thread it sounds as if the latest G+ kit is vastley different from the first run of cars over a year ago. I'm going to cut my losses and just buy a new kit.
I_GhostTown_I is offline   Reply With Quote
Old 12-17-2002, 05:08 PM   #4667
Send a message via AIM to Dave Kurschner
Ghosttown - aluminum is not a good idea for c-hubs. In your situation, they will be less durable than the updated graphite ones. Not only do they bend quite easily, but as said by others already, you will transfer the breakage to somewhere else.
If you are running with pvc, I'm surprised that you are breaking the way that you are. Are you not running a servo saver? Also check to see if your servo saver is really loose. This can allow your steering to overtravel too easily which is how c-hubs usually get damaged. Also, make sure that you have a good front bumper on the car like the newer stiff foam bumper from Los or the trinity red bumper. If you are on a full speed huge track clipping pipes at full throttle, then nothing may save your car from being damaged.
Kevin K - I'll be there at Trackside. Really looking forward to it.
Dave Kurschner is offline   Reply With Quote
Old 12-17-2002, 05:45 PM   #4668
There are other racers at my track that use aluminums and don't seem to have a problem (come to think of it, none of them made the A main though). The track is very short at the moment so speeds are low. I'm not subjecting the car to large impacts with the barriers or even other cars. I think I might give the graphites a try first since everyone seems to agree that the AL's are bad.
Old 12-17-2002, 06:26 PM   #4669
tufferwilde's Avatar
Kevin K - From what I hear, PL, BK, and hodge will be there for the weekend... not to mention countless others
Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 12-17-2002, 07:54 PM   #4670
KINGZJ's Avatar
Send a message via AIM to KINGZJ
I talked to Scotty tonight and their are a ton of Factory guys coming.
Kevin we got the hook up again this year we are all gonna be in skybox again. Just got to keep skip from droppin A$$ again and we will have it made.
KINGZJ is offline   Reply With Quote
Old 12-17-2002, 08:36 PM   #4671
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
If Skip starts to drop the bomb then we get Uncle Kenny and give him some Wendy's chillie and watch out clear the room.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-17-2002, 08:40 PM   #4672
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
boy am i glad i am pitting downstairs.......arg.peeeeeeuuuuuuuu
Matt M. is offline   Reply With Quote
Old 12-17-2002, 09:01 PM   #4673
R/C Tech Founder
R/C Tech Charter Subscriber
The more you guys talk about it, the more bummed I am about missing this year's Novak. If only Scotty hadn't moved up the date! haha
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 12-18-2002, 02:00 PM   #4674
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
get the brp front bumper. I used to have the same problem as you, but since I have had that bumper I haven't broken anything in the front. Also, ,see if someone can rig some BRP nerf wings to the vehicle as well. I have some on mine and they have saved the rear end except when i hit just right, like today
Old 12-18-2002, 02:07 PM   #4675
Tech Legend
Cain's Avatar
Hey All,
Did some driving today to get some more practice in. Broke a rear hub carrier (my fault) and figured since I got to take that apart I will look into trying new setups. I went ahead and bought some 60 weight oil and another set of black losi springs, so i am willing to try some new setups. here is what I have that I can use to setup my car:
Oils:
80,60,40,25
Springs: (pairs)
1 White Associated
2 Black Losi
2 Purple Losi
1 Blue? Associated
1 Silver Losi
1 Green? Associated
1 Purple Not sure what it is but they are short
1 Orange not sure again but they are short!
Stock Pistons
PRP Shock towers
Original Losi Hubs and Arms
HPI Alpha Romeo body and Losi XXX-S stock body
Purples and Plaids for Foams, TRC brand
Battery position always to the rear
Ok, from these items, I want my vehicle to be able to rotate the rear easier. Today when running my vehicle seemed to roll alittle too much in the turns so I am looking to running all black springs around.
Can Anyone give me a good setup that will work great on a tight track? I have looked at the losi setup sheets but I am lacking some parts there drivers use.
Finally, can someone give me a good answer on what lengthening the rear camber links vs shortening them does? Also, what does having the ball stud on the rear hub closer to the vehicle versus farther away do for you?
Thanks.
Old 12-18-2002, 02:22 PM   #4676
PW
PW's Avatar
Send a message via AIM to PW
Hey guys....I just wanted to stop by and let everyone know that Schumacher USA now has the Titanium Racing CVD's in stock for the Losi XXXS. Please check with your local dealer to see if they have them on order. They sell for $39.99 retail for a pair.
BTW, we also have screw kits, turnbuckles, hinge pins etc in stock. Team Losi's Factory Drivers are now using Titanium Racing products with great success.
Thanks for your time
PW is offline   Reply With Quote
Old 12-18-2002, 02:28 PM   #4677
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Freaking Bob or Charlie kept dropping bombs every day... They kept blaming it on me.. Bastards... If I had let one loose like that, I would have been claiming, and enjoying it...but I get the hell outa there..
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 12-18-2002, 03:10 PM   #4678
ijnek's Avatar
Send a message via ICQ to ijnek
Thanks.
sorrie,but i'm having problem accessing the website.i do remember tat you can access www.competitionx.com website for the info u need...
ijnek is offline   Reply With Quote
Old 12-18-2002, 10:51 PM   #4679
ottoman's Avatar
Hey guys... I just picked up a XXXS and it has a blue 64 pitch spur gear, but its not marked with the number of teeth. Its kinda hard to count in the car so anyone know how many teeth a blue spur has?
ottoman is offline   Reply With Quote
Old 12-18-2002, 11:23 PM   #4680
Send a message via Yahoo to Doug Gaut
128 teeth
Doug Gaut is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
