Old 12-16-2002, 08:05 PM   #4651
Send a message via Yahoo to Doug Gaut
What bottom retainers are you using for the Assoc. springs? I had the same thoughts on using the Assoc. springs till Losi comes out with theirs. Can you use the Assoc. lower retainers and maybe remove the paint? Would that help?
Doug Gaut is offline   Reply With Quote
Old 12-16-2002, 08:24 PM   #4652
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Default Custom Painted Alpha Body
Just thought I would post a link in case anyone is looking for a new body for their XXXS, sorry if this is against the rules?
Custom Painted Losi Alpha Body FS
Blakesrc is offline   Reply With Quote
Old 12-16-2002, 09:10 PM   #4653
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
it's more of the paint and threads it hangs on vs' the retainers. I used the RPM retainers.
If you are looking for the Congo springs and can wait a week for ship try www.sheldonshobbies.com (I posted this earlier) I just got two sets of Congo blue, puple and one yellow.
(200th Post)
ChristopherKee is offline   Reply With Quote
Old 12-16-2002, 10:17 PM   #4654
KINGZJ's Avatar
Send a message via AIM to KINGZJ
I am sure it is in this thread somewhere but I will most likely never find it. Does anyone have a complete listing of the losi shock springs for the xxxs. I have a bunch of them and have no idea how to put them in order of lightest to stifest.
thanks
Jesse
KINGZJ is offline   Reply With Quote
Old 12-16-2002, 10:36 PM   #4655
Ryan C's Avatar
Does anyone out there run sway bar kits on these xxxs
either front or rear?
am just wondering as was wondering if need to order them when i buy kit.
im running on asphalt good grip (lots)
Thanks Ryan
Ryan C is offline   Reply With Quote
Old 12-17-2002, 02:30 AM   #4656
Blakesrc's Avatar
KingZJ,
check out competitionx.com, I believe they have spring rates for all the major brands on there.
Blake
Old 12-17-2002, 04:59 AM   #4657
Send a message via AIM to Dave Kurschner
Ryan - its a good idea to get the front swaybar kit. I seem to use them almost all the time with good luck. You also might want to get a front one-way.
Kingzj - Here's the springrates for the Losi springs from softest to stiffest
WHITE = 7.6 LBS
ORANGE = 8.6 LBS
YELLOW = 9.6 LBS
PINK = 10.6 LBS
RED = 11.6 LBS
SILVER = 12.6 LBS
BLUE = 14.6 LBS
GREEN = 17.5 LBS
PURPLE = 20 LBS
BLACK = 25 LBS
TRINITY CONGO BLUE = 30 LBS
TRINITY CONGO PURPLE = 35 LBS
TRINITY CONGO YELLOW = 40 LBS
Losi is going to be releasing some new springs that are aproximately 30, 35 and 40 lbs with a slightly different spring rate progression than the Trinity springs are. Keep your eye out for those in the future if you ever race on foams.
Dave Kurschner is offline   Reply With Quote
Old 12-17-2002, 08:18 AM   #4658
KINGZJ's Avatar
Thanks Dave that is a big help I knew I could count on somebody.
Kevin I will put that setup on my car and try it out. I though everyone was running low roll center at scottys.
Jesse
Old 12-17-2002, 04:15 PM   #4659
To those of you that helped me with some tips on dialing out my off power oversteer last week, thanks a million. I qualified 3rd for the A main and my car handled flawlessly all weekend after I took the advice from this thread.
But.... I do have one great big gripe. I've broke 5 left front hub carriers in the last 12 runs or so. I'm constantly trying keep my corners nice and tight in the critical passing areas and every once in a while I'll tap a pipe with that corner of my car (since 85% of the turns are left handers). Now I know I'm not supposed to be "tapping" anything but these things are rediculous. Is there a recommended brand of aftermarket aluminum carriers that I should switch to?
Also, supposively my car was on the very first run of production line kits. I keep reading about "whole new chassis, shock towers, etc." Should I just get a G-Plus kit and bag trying to update this one...... ?
I_GhostTown_I is offline   Reply With Quote
Old 12-17-2002, 04:25 PM   #4660
Ghost- Are you breaking the spindle or the caster block(c-hub). If it is the caster block Losi has mad a running change to the parts, if you look on the bottom part were the king pin srew goes in this area is thicker. The other big part to breaking front end stuff is whether or not you are on throttle when you impact the pipe, you can hit things really hard and not break if you are off power but if you are still in the throttle it does not take much to break.
Chad
ChadK is offline   Reply With Quote
Old 12-17-2002, 04:33 PM   #4661
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Jesse.....The high RC has been working quite well for me give it a try.
How many of the Losi guys out here are going to be going to the US Touring Car Champs in Jan? It should be a good race and well attended by the factory boys.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-17-2002, 05:15 PM   #4662
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
Ghosttown- I ran a losi outdoors most of the summer and have 3 runs this winter on carpet with a G+ and haven't broken anything except one caster block outdoors. You're track probly has 2x4's? If you put aluminum on it, then some other part will just break instead, or the aluminum will probly end up bending. Try some of the new graphite blocks, like Chad said, they are thicker than the older ones. Good to hear your getting your car setup.
Kevin- That's in Chi-town this year, right? You got a site with some more info?
pimpedaccord is offline   Reply With Quote
Old 12-17-2002, 05:27 PM   #4663
It is the C shaped hub and its breaking at the hinge pin area every time. On this particular track there are only three spots where the throttle is let off to settle the car into the corners, every other tenth of a second is 100% on power. After breaking while leading on the third lap of the Main last weekend I'm definately switching to aluminum. Bend'em, Tweak'em, Scratch'em I don't care as long as I cross the finish line with four wheels instead of three.
Old 12-17-2002, 05:31 PM   #4664
Thanks Pimped,
The boarders are made with 2" pvc pipe thats duct taped together. Hence my frustration. Car is dialed though, I missed TQ by seven tenths.
Old 12-17-2002, 05:48 PM   #4665
Simon K's Avatar
Are you running a full width front foam bumper?
I'd read that some peeps changed to a Buds/BRP(Don't know which one, sorry)wider foam bumper and reduced the number of breakages on the original XXX-S.
G+ apparently has a wider standard foam bumper, standard. Hopefully this will do the trick on the new kit.
Simon K is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
