Old 12-15-2002, 06:55 PM   #4636
Tech Legend
Cain's Avatar
Trader Rating: 230 (100%+)
I had the battery flying out the side problem with stick packs (we are only allowed to run those). We modified the chassis with some RPM servo mounts to hold the batteries in. My new chassis has the mounts setup counter sunk. It works great.
I went to that competitionx website but when clicking a link it keeps trying to refresh it over and over and over . . .
So, anyone using the PRP shock towers? from what I understand, if you mount on the lowest set of holes for the camber links, the car is freer in the rear, helping the car turn on a dime? Anyone verify this?
What will mounting the shocks say higher or lower on the tower do?
I am putting all this stuff in a faq for reference, anyone else doing this?
Old 12-15-2002, 07:06 PM   #4637
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
Do any of you guys have any Trinity Congo Blue springs you want to sell?? I can't find them anywhere and despirately need some! Thanks.
xxcr2@yahoo.com
pimpedaccord is offline   Reply With Quote
Old 12-15-2002, 07:14 PM   #4638
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Even side by side packs would slide out a little bit, upsetting the car's balance. I don't think I've ever had a pack come completely out, but I have had it come out and rest against the "tub edge" or whatever you want to call it, a couple times.
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 12-15-2002, 07:37 PM   #4639
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
xxcr2@yahoo.com
They take forever but sheldonhobbies has them in stock... Good luck
ChristopherKee is offline   Reply With Quote
Old 12-15-2002, 08:03 PM   #4640
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Cain if you move your camber link up on the tower it will loosen your car up a little and let it rotate quicker in the corners. I'm trying it this week since the Graphite Plus car has a little different rear end setup. I have my car really good the rear end needs to loosen up just a little. I moved up the rear camber link since the new graphite tower has upper camber link mounts.
Old 12-15-2002, 08:16 PM   #4641
STLNLST's Avatar
Trader Rating: 19 (100%+)
I thought that the higher up the link was the higher the traction???That's why the new Losi tower has a lower set of holes to free the rear end up a little by taking away some traction.
Anyone else know if this is true?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-15-2002, 09:23 PM   #4642
wyd
Tech Legend
wyd's Avatar
My buddy emailed Todd Hodge of Losi and he said that when he runs carpet he moves the rear camber link up on the new shock tower. Stock position on the new car is bottom holes and the longest setting on the tower. I just moved mine up to the top inner most hole. Todd told us that it would help the car rotate quicker in the corners. They do this when running carpet since the new car setup makes alot of rear traction. I'm going to try it this weekend as my only change to the car and see what happens. If it sucks I will just move it back and try again.
It could still give more bite by moving it up but I guess it still could let the car rotate better. I think it will give more forward traction but less side bite traction when you move the camber link up.
Old 12-16-2002, 04:33 AM   #4643
STLNLST's Avatar
stock position on the new car may be the bottoom holes but the regular position from the old towers are the upper holes. So placing the camberlinks to the upper inner hole is basically what most people are running their cars at now. Holes 1-4 are the current holes and the bottom row are the new holes Losi added.
Old 12-16-2002, 04:57 AM   #4644
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
i was also under the impression that the new lower holes in the rear tower (the upper holes are the same as the ones on the old tower) were there to free up the rear end more so it rotates better through the turn. i believe that was one of the main things they wanted to achieve with the new rear towers and offset rear arms/hub carriers - so that the car could be set up to turn on a dime if the driver so wished. hmmmmm ...... time to post a question to todd hodge over at trinity tech talk to clear this up.....
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 12-16-2002, 05:24 AM   #4645
senna's Avatar
Hi everyone ...
Last Sunday we had the 5th race of the National Championship here in Malta. I raced with my LOSI XXX-S (graphite, etc) and came 1st in both races of STOCK B and (I think) finished 2nd overall in the STOCK class.
The car is looking good and I am sure I can get better results once I practise a bit more!
According to Matt Francis ... the new YELLOW BELT can help both as regarding acceleration and top speed, especially in STOCK. Do you know of someone in EUROPE who already has this belt in stock?
Thanks everyone!
senna is offline   Reply With Quote
Old 12-16-2002, 01:58 PM   #4646
Tech Legend
Cain's Avatar
I think great lakes hobbies has the congo springs in stock. There prices are not that bad either. What pound rating are the congo springs and what is so good about them?
From what I heard, using the lower hole positions is supposed to allow "turning on a dime". I will look into setting up my car when I go to practice wednesday with the new towers. (been too busy programming Java).
Later!
Old 12-16-2002, 02:35 PM   #4647
Yellow - 40
Purple - 35
Blue - 30
The great thing about them is at present.. Losi does not make springs at these rates (stops at 25). They should be out soon is the word.
High traction indoor carpet on foam need stiff springs to keep you from traction rolling and scrubin speed.
Old 12-16-2002, 03:29 PM   #4648
Tech Legend
Cain's Avatar
Guys at my track are running TC3 springs for those weights. (I got a pair of 40 pounders when I was running purples all around) They seem to work well.
Old 12-16-2002, 03:44 PM   #4649
Send a message via Yahoo to Doug Gaut
So , with the new car out and all, has anybody had a chance to try the forward steering position on the new chassis? If so, what characteristic does the car exhibit with them in the forward position?
Doug Gaut is offline   Reply With Quote
Old 12-16-2002, 06:40 PM   #4650
The AE springs tend to bind up for me.... throws the car off when it happens.
The front steering position makes the car more agressive.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
