Old 12-12-2002, 04:51 AM   #4606
Default Blue Servo posts & Blue motor clamp
Hi guys, can you help me find blue servo posts and a blue motor clamp??? i need a shop that is through internet....
Thanks guys...
harris is offline   Reply With Quote
Old 12-12-2002, 06:38 AM   #4607
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Harris
Search for XXX-S on E-bay and you will find about 50 Blue Aluminum THings for the XXX-S.
mike_Webb is offline   Reply With Quote
Old 12-12-2002, 07:03 AM   #4608
rayhuang's Avatar
Do you think that if they have the same final drive ratio, they will produce same acceleration and top speed?
senna-I have been going back and forth between my TC3 and XXXS with the same motors, rollouts, tires, speed controls, servo, RX!!! Only thing different is the chassis!! And I can tell you the lap times are very similar-but they "look" totally differnet on the track. The TC3 Looks WAY quicker, but I can stay with all the TC3 I used to stay with with my TC3. SO I am theorizing that the Losi carries a little more speed and accelerates smoother, but hits the same terminal speed. The TC# is a tad slower in the corners, but accelrates better to catch the Losi.
Also-my big buck-graphite, carbon fiber Losi is over 2 oz. heavier than my stock FTTC3!!! MY TC3 is 50oz. exactly!!!! Losi-52.3 oz.
One thing for sure right now-the same rollout in my Losi gets motor much hotter than in my TC3!!! If thats set-up or drivetrain-I am not 100% sure yet. I am going to have to put a fan in my already heavier Losi to combat that!!!
I am blabbing-but I think if I get a better set-up on car that allows me to be on throttle less in corners, but still carry the speed-maybe motor wont be as hot.
Old 12-12-2002, 08:27 AM   #4609
Default Re: Foam tire help
Originally posted by Doug Gaut
Having not ran foams before, what is the chance of tearing up a tire? I would assume the fronts would be more suseptable to chunking. Would a spare set of fronts only be advisable if you were on a budget?
Before your run the tires make sure you thoroughly coat the sidewalls of all four with CA. I use a medium viscosity so it doesn't run all over place. This is the only method that has worked for me, if I don't do it I'll chunk a tire to pieces in one qualifier. The fronts and rears are both suseptable. Maybe the fronts take a little bit more but not much. The chances increase with a tighter track and higher number of hack drivers hehe..
I_GhostTown_I is offline   Reply With Quote
Old 12-12-2002, 08:59 AM   #4610
psycho's Avatar
I_GhostTown_I
Are you putting a good bevel on the edges of your tires? I rarely chunk tires and don't do anything special to them other than cutting them down and bevelling the edges. I've had this experience with electric and nitro sedans.
psycho is offline   Reply With Quote
Old 12-12-2002, 09:10 AM   #4611
rayhuang's Avatar
I_ghosttown_I-- The CA trick works great and also-be aware that your body often times cuts the tire, then it gets ripped off later. So make sure you cut body out well so it doesnt ruin all your tires!!!
Old 12-12-2002, 09:16 AM   #4612
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
hmmm.... we spend all this time and money dremeling, drilling, sanding, purchasing the newest lightest pieces just to put CA all over the tires and increase rotating mass
I agree with rayhuang... true the tires to at least 60mm and bevel those edges. Make sure your wheel wells are sanded and smooth with enought clearance... and you gold..
Well, unless you have hacks that tear your foam apart with there 2 ft body posts and cracked front bumpers ...
ChristopherKee is offline   Reply With Quote
Old 12-12-2002, 08:22 PM   #4613
Simon K's Avatar
Keep an eye on the camber.
Too little negative camber can render the tyre vulnerable to chunking. On asphalt we usually run about 2 degrees, I'm don't know how much you'd run on carpet.
Rear tyres tend to chunk more, usually due to a combo of inadequate camber and clipping kerbs/Barriers etc. The cars tend to slide around more, hence clipping the barriers
Frewer included a set of stick on sidewall protecters with the foam tyres he was shipping, Ellegi donuts also have them.
Simon K is offline   Reply With Quote
Old 12-12-2002, 09:14 PM   #4614
JimmyMac's Avatar
I'll have to do some of my own testing with my TC3 vs my XXX-S G+. So far my TC3 has the edge over my 414M2. Perhaps this weekend I can get some test laps in with the G+.
JimmyMac is offline   Reply With Quote
Old 12-13-2002, 05:44 AM   #4615
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
I've been racing TC's for a few years, mostly asphalt, all on foams and have only chunked one tire. It was from the body hitting it...
But I've seen other pretty fast guys chunk tires all day long... I guess it's your driving style. I would just trim the body good and see what happens for you.
Tru the tire down to 59 if your on carpet, but leave it full height outdoors on asphalt. It'll last longer and roll the corners better.
pimpedaccord is offline   Reply With Quote
Old 12-13-2002, 01:22 PM   #4616
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I found that the new TRC foams are around 64mm when new. I true them down to start at 62mm. If I'm going to chunk a tire it will happen when my tires are about 61mm. After I get below 61 to 57mm my foams never chunk. My car is also faster after the first week of 62mm. I loose a 1mm a week with 3 practice runs, 3 heats and the main. I then true them even and at they should be at 61mm. If I lost more than that my car is not working right. If you are chunking it is normally from flipping or smacking the walls and then flipping. Keep to a negative camber from -1 to -2 seems to be good. I normally run -1 in the front and -1.5 to -2 depending how my foams are wearing.
I run foams on indoor asphalt and in the summer I normally run outside on asphalt as well. I'm not too experianced with with rubber tires as I run them maybe once a year or so. I like foams because they are faster and for me I normally get 4 to 5 weeks from and set and they are fast from new til the end of their life. Bad thing for me is the ride height and gearing changes all the time. I use roll out so gearing is not a problem and I check the ride height often.
Old 12-13-2002, 06:22 PM   #4617
Send a message via Yahoo to Doug Gaut
Thanks for all the great info!!!!!!!!!!!! This is the reason I frequent this site. It is so nice to be able to obtain info without being flamed. Losi racers rule.
Doug Gaut is offline   Reply With Quote
Old 12-14-2002, 07:52 AM   #4618
Tech Legend
Cain's Avatar
Trader Rating: 223 (100%+)
As for the motor mount, you can find it on ebay sold by a guy called serpentvector. Its a combo motor mount heatsink.
Anyone with setup suggestions on the PRP shock towers? What will I notice running the bottom most holes vesus the upper most holes, etc, for the camber rods, shocks, etc.
Old 12-14-2002, 08:12 AM   #4619
Oasis's Avatar
Trader Rating: 36 (100%+)
What differance does the new rear A arms & rear hubs make ?Would it make that big of a change in the car?I'm new to touring cars,not new to rc racing.And should I run the sway bars?The track I race at is a tight,smooth, med. traction track. Was not sure if I need sway bars.
Oasis is offline   Reply With Quote
Old 12-14-2002, 08:14 AM   #4620
ijnek's Avatar
Send a message via ICQ to ijnek
check tis website...it explains lots of stuffs
www.competitionx.com
ijnek is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
