Old 09-19-2001, 09:56 AM   #421
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by mr. losi
ya know...after i typed it in i saw where you are from....duuuuuhh
troy, if ya want....i see n need to change....mayby the 90 tooth...
ok..cool... im going to order the *2 & 4* castor blocks for the front... & threaded shocks
anything else you think i should throw in?
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 09-19-2001, 12:30 PM   #422
Ty
Ty's Avatar
Trader Rating: 25 (100%+)
What are the part numbers for the threaded shock bodies and how much do they sell for?
Also what about the Trinity shock collars, part number and price?
I read on Trinity Tech Talk in the ask Todd Hodge section that Losi was coming out with a shock front shock kit (bodies and shafts) is this true? Thanks
Ty is offline   Reply With Quote
Old 09-19-2001, 01:06 PM   #423
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
mike you mean short....bodys and shafts....yes that is what i heard.also the bodys are 20 bucks and are the same as the street weapon....8 bucks on the trinity parts.....tsr...that would be a good choice....
Matt M. is offline   Reply With Quote
Old 09-19-2001, 01:09 PM   #424
RCTech Member #2
TSR6's Avatar
I'll probably wait a week or two on the shocks... Just to see what comes out. I think a set of red anodised ones would be sweet.
Troy
RCTech Member #2
Old 09-19-2001, 05:49 PM   #425
JUNK............ JUNK................... JUNK
I for one am not real happy with the losi XXX-s
I like my TC3 better!!!!
Wolverine is offline   Reply With Quote
Old 09-19-2001, 05:58 PM   #426
RCTech Member #2
TSR6's Avatar
Your kidding right???
What do you not like about it? I'm very curious to hear....
Troy
RCTech Member #2
Old 09-19-2001, 07:36 PM   #427
Administrator
Matt M.'s Avatar
wolvorine...i have some stuff to trade for you xxx-s.... your xxxs.....
Old 09-19-2001, 10:15 PM   #428
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
Mike-
I bet the superglue/Dremel man in question to be Todd Lewis?
As for his intention with that mod, all it would do would be to lower the rear roll center. I think that the options that Losi gives are pretty much within the range that you should ever need, and the Low Roll center arm mounts will do nearly the same thing if you are looking for more rear traction.
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 09-20-2001, 12:04 AM   #429
well were to start........... it is slow!!!! even with it geared the same.......... and the same motor
I have broken 3 arm's......... 2 front, one rear
not counting the damage from the crash... ( girl watching )
the belt broke!!!!........ with a stock motor
I have had to rebuild 3 of the four shocks now........
it is just JUNK!!!!!!!
now my TC3 I have never broken any thing....... I have crashed it harder then the losi....
Now I have been a losi man for many years now...... but this is the first losi kit I am not happy with at all.......
even the kit it self, was bad.........
missing screws, broken o-rings, a lot of flashing to clean of the parts, a bad bearing...............
Old 09-20-2001, 01:15 AM   #430
R/C Tech Founder
R/C Tech Charter Subscriber
Sorry to say it Wolvy, but you must be doing something wrong...!
I've put the car through hellish crashes under race conditions and have not broken a thing. I'm not sure how the belt could break, unless it was too tight on the tensioner or had a manufacturing flaw.
As far as the speed, there's no way anybody can say the car is slower than its counterparts. My XXX-S has just as much straightaway speed as any other TC out there, including my Yokomo that I raced for 6 months. The cars regularly compete (if not beat) the fastest TC3s, Yokomos, Tamiyas and others at the tracks around here. If the car is slow, there's something wrong with it.
My first thought would be to make sure the diffs have not loosened up -- sometimes the Losi diffs, even when freshly rebuilt, will loosen up really quickly. Also, make sure none of the CVDs are bent or rubbing on the hub carriers, and make sure the suspension is not binding anywhere.
Anyway, not saying that the XXX-S is the best car out there or anything, just saying that it seems like you're having slightly atypical results from the rest of us. If you have any more specific questions I'd be happy to try and help...
futureal is offline   Reply With Quote
Old 09-20-2001, 04:56 AM   #431
RCTech Member #2
TSR6's Avatar
Yeah, the belt breaking surprises me. I have only heard of one breaking. I have hit pretty hard too... me & skip figured we would make a strightaway during practice a couple times. It survived that, and another pretty good slap during a heat, which only pop-ed a ballcup.
Troy
RCTech Member #2
Old 09-20-2001, 05:06 AM   #432
Trader Rating: 35 (100%+)
futureal: Have you considered/tried mounting the threaded shocks from your Yokomo on the Losi? I have a spare set of Yokomo threaded shocks, and I wonder if they would fit. I've been considering the Losi car for some indoor racing. If the Yokomo shocks will work, that's one less expense for me and one more pro for buying the XXX-S. Thanks
Geppetto is offline   Reply With Quote
Old 09-20-2001, 05:32 AM   #433
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Geppetto-
Do you race at The Track in MD?
Mike Webb
mike_Webb is offline   Reply With Quote
Old 09-20-2001, 06:19 AM   #434
Ty
Ty's Avatar
Geppetto:
I used to race a TC3 last season indoors on carpet in stock class. last weekend was my first test with the XXX-S. I was very impressed with the car and it was the same setup as the one on the Losi site of Andrew Gray ( carpet with foams ). The car was easier to drive and very smooth. It could have been stiffer to carry more corner speed, but so far I am very impressed with it.
If you run foams, make sure to use the TC3 wheel hexes because they do not let the wheels rub any where because they are slightly wider.
I ordered some springs, pistons, and castor blocks to try. Right now the car is bone stock, but I will probably get the threaded shock bodies when they come out. I also would like a set of composite CVD's if they ever make any. What I really want to try is sway bars.
Wolverine: You might as well stick with what you like. I tried a Schumacher Axis 2 and Yok Special after my TC3 and was just unhappy. I thought I would try the XXX-S and see how it went on carpet and I was happy.
Old 09-20-2001, 07:34 AM   #435
mike_Webb: Yes. I have raced 1/12th and a little TC at The Track. If I race this winter, it will be at The Track.
Ty: Thanks. I know Andrew Gray (he races at The Track), however, I have not had an opportunity to make it down to The Track to talk to him or the other local Losi sponsored driver (Todd Lewis). Kind of ironic since The Track is only 15 minutes away from my house, and even closer to my work.
I really don't care for TC racing on carpet! However, I was giving it serious consideration so I can maintain/increase my skills over the long winter months.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
