Old 11-08-2002, 12:45 AM   #4306
Sigearhead's Avatar
Trader Rating: 68 (100%+)
the one way is heavier than the standard diff.
All of the bearings will be light, relatively the same weight. If you have one of the newer kits, then you have steel shielded bearings and they are as good as any unless you wanna go ahead and spend $100 USD on a set of ceramic ball bearings.
Senna: just some advice: I think you are concerning too much with some things that really will improve your performance very little. The track you talk about seems to be very large where acceleration out of corners should not be a concern but your biggest concern should be keeping the speed that you have and carrying through those big turns and that big track that you talk about. We have many drivers at our track of all skill levels and we all interact with one another and share information (for the most part) and I will tell you that even with the same equipment, same cars, same setup, all things being equal, I can give my car to one of the less experienced racers and I can drive his and I will still be faster than he is. Once you become a better drive then it is when you might want to search for every possible edge possible. Right now, you should just practice, practice, practice.
Sigearhead is offline   Reply With Quote
Old 11-08-2002, 04:35 AM   #4307
STLNLST's Avatar
Trader Rating: 19 (100%+)
ditto
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 11-08-2002, 05:28 AM   #4308
senna's Avatar
Thanks Sigearhead for the info ...
Where can I buy the ceramic ball bearings ? Do the company selling them provide a whole set of bearings for the LOSI XXX-S ?
Thanks again ...
senna is offline   Reply With Quote
Old 11-08-2002, 08:38 AM   #4309
shrekair's Avatar
Trader Rating: 9 (91%+)
just drive the car!
shrekair is offline   Reply With Quote
Old 11-08-2002, 08:46 AM   #4310
I know the bearings that come with it are fine. I fyou want to change them go ahead but you will not notice a diff on the track. Mabey .010 of a sec a lap but then you have to keep them cleaner then the stock ones.
teamAE is offline   Reply With Quote
Old 11-08-2002, 01:07 PM   #4311
Eric Swanson's Avatar
Shrekair just NAILED the answer to everyones R/C queries right on the head!!!!!!!!
Eric Swanson is offline   Reply With Quote
Old 11-08-2002, 04:52 PM   #4312
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Default Setup Help
Hey guys, maybe one or some of you can help me out a bit. I purchased my first sedan 2 months ago, a XXX-S. I am very happy with the car and have won my last 4 races in a row but I feel like the cars handling could be better. I am running the stock setup with 60wt oil and this weekend I tried the rear camber link in the A-2 position but the car still feels "LAZY" to me. After the main last week I switched cars with another XXXS driver and his car seemed to be much more responsive than mine. The only thing different on his car is that he has a graphite chassis and uses a trinity reference body, I still have the stock one. Both of us are using an airtronics 94757 servo, Sorex 36's, titanium turnbuckles and threaded shocks. I just really would like the car to feel more aggresive to me rather than it feels now, like its just floating around the track. Unfortunatly there is only myself and one other person at my local track running this car so I dont really have anyone else to rely on here. Any info would be greatly appreciated.
Blake
Blakesrc is offline   Reply With Quote
Old 11-08-2002, 05:14 PM   #4313
shrekair's Avatar
soften shock oil 10 wt.
stand shocks up onw hole
shorten camber links f/r
take a little kick up out of the front
........ and drive it
Old 11-08-2002, 05:14 PM   #4314
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
The graphite chassis will add to the responsiveness of the car and the Trinity body will as well depending on what body it is. If its the asphalt stratus that will make the car more responsive.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 11-08-2002, 05:18 PM   #4315
Blakesrc's Avatar
Kevin and Shrekair, thanks for the info. I dont want to purchase a graphite chassis just yet, its possible I will get one for christmas. I have seen pictures of kinwalds car and all of the dremel/mill work he did to his graphite chassis, would it be ok if I did that to my stock chassis or will it cause a lot of unwanted flex?
Blake
Old 11-08-2002, 05:20 PM   #4316
shrekair's Avatar
leave the chassis as they are, they are built like that for a reason.
Old 11-08-2002, 05:39 PM   #4317
Blakesrc's Avatar
Shrekair, what about the body situation. I was thinking of picking up a new one, possible the protoform stratus 2 unless you guys can recomend something better. Also, I have my droop set at 4 in the front and rear, is that ok or should I try something else?
Blake
Old 11-08-2002, 06:13 PM   #4318
Send a message via AIM to Dave Kurschner
Blake - couple of things. If you are looking for a body, try the new Losi Alpha body. It is VERY light and also a quite responsive body in my opinion.
But there are other key elements to handling that I'd look to before trying to tune with bodies or grinding away your chassis. Shrekair has some good advice that is more worth your time. When running the plastic car, there are several differences. One of the biggest being the weight of your car. Also, if you run plastic components like hubs, arms, shock towers, etc...these components all have more flex and can give your car a softer more lazy feeling.
Definitely the lighter oil will make your car more responsive. Try like 50 front / 40 rear. You can also experiment with your wheelbase, put your rear arms forward as opposed to the middle. You can also try to increase your droop settings in the rear of the car. Put a stiffer spring in the rear may help as well. Have you tried a one-way? There's tons of things you can do but that's a few more to experiment with.
Dave Kurschner is offline   Reply With Quote
Old 11-08-2002, 06:23 PM   #4319
Send a message via Yahoo to Doug Gaut
Dave, do you know how long the Alfa will be backordered? I have had a couple on order at my local shop for 2 weeks.
Doug Gaut is offline   Reply With Quote
Old 11-08-2002, 07:56 PM   #4320
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
kthobbies.com has some.....
Matt M. is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
