Old 11-04-2002, 07:30 AM   #4261
senna's Avatar
Is the front one way for the LOSI useful to have more acceleration out of the corners?
Is the standard differential lighter than the one way?
senna is offline   Reply With Quote
Old 11-04-2002, 07:40 AM   #4262
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
The oneway generally improves enter and mid corner speed. The oneway alows the wheels to freewheel, instead of "scrubbing" like they would with a diff.
Scrubbing = loosing traction = you must slow down more to turn.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 11-04-2002, 07:54 AM   #4263
ttr
ttr's Avatar
To improve acceleration try to reduce
drag (most important factor)
- un-grease the bearings and use light oil to lube,
- find and replace any binding bearings and CVDs
- loosen the belt tension until it skips a little bit at hard braking (a little skipping will not hurt)
- use high quality spur and pinion gears, set correct mesh
rotating mass (much more important than overall weight)
- use alu CVD bones
- use alu pinion gears (Losi pinions are extremly heavy)
BTW: the easy way is to run a brand new motor with brand new high voltage matched battery
ttr is offline   Reply With Quote
Old 11-04-2002, 08:41 AM   #4264
sixandeightstri's Avatar
I don't know of any, but the standard rules apply:
Reduce friction
Reduce rotating mass
Reduce weight
sixandeightstri is offline   Reply With Quote
Old 11-04-2002, 01:35 PM   #4265
STLNLST's Avatar
Trader Rating: 19 (100%+)
the tighter the belt the more accelleration.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 11-04-2002, 02:19 PM   #4266
Tech Legend
Cain's Avatar
Trader Rating: 220 (100%+)
Lightbulb The new XXX-S Graphite Edition
Hey all,
been awhile since I been back to the board, school can take up a lot of time!
Anyway, I see that the graphite edition of the XXX-S will be available soon (no one can give me a date though) and I am thinking of getting one. Reason is that I want to upgrade my stock XXX-S to graphite and threaded shocks and it seems cheaper just to buy the new kit, sell my old (or let the wife drive it and go from there.
Few questions:
1) what parts specifically are being changed in the new kit and what exactly will the changes do performance/toughness/whatever wise?
2) I currently run the BRP front bumper on my XXX-S, will this still work on the new bumper (PS- I know they redesigned the bumper, but I like the strength of the BRP)
3) I have brp nerf wings mounted on the side of my chassis to protect the rear arms and carriers, and it works well by the way, but I want to know has the new graphite chassis side wall area changed at all from the way the stock one is done (ie- stiffezel chassis) since these are mounted by drilling the chassis and attaching them.
4) Have they solved the issue of the stick pack flying out of the car yet? we had to modify the chassis to put up blockers (RPM Servo mounts) to prevent the pack from coming out. Have they made some form of a side wall to hold them in? (NOTE: we are not allowed to run packs that are matched and are in side x side configuration, sucks, but thats the rules)
5) how hard is it to drill the graphite chassis? about the same as the stock material one?
6) where is the cheapest place you have seen the kit for mail order?
7) what heatsink do you guys recommend for the vehicle? I know that trinity I think makes one that sort of hands about the motor. Any ideas?
8) I noticed that on my current XXX-S that when I run with a similar gearing to another racer with the XXX-S my motor gets too hot while he is doing fine. I heard it may be my diffs are too tight, what should they feel like?
Well, I think that about does it. If someone can tell me when the kit will be available for mail order that would be great. I am considering putting in a preorder with kthobbies if the shipping is free, just need to know when the kit will come however.
Later guys, will come back with more racing questions once I get back to the track. I am happy however with my XXX-S, just need lighten the load and I want to be current on the parts on my car without buying all the parts seperate.
Thanks again,
Cain
Old 11-04-2002, 02:57 PM   #4267
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
1. From the best of my knowledge they have added an additional rear hub carrier hole on the arm. What this does is it moves the pivot point of the rear carrier closer to the center of the car. They compensate then with new hub carriers to handle the additional off-set. I will let someone else comment on what this does.
They have gone back to the chassis and found a different way to cut it to make it lighter than the current one but still retain its strength and rigidity.
You get a new rear shock tower with different camber link adjustments thus opening up the tuning options.
2. I believe the brp bumper will fit as it is a direct bolt on to our existing cars.
3. I donít think you should have any problems mounting the wings on the chassis. I donít think they changed the sides all that much.
4. Sorry, cannot help on that one.
5. I donít think the chassis material has changed.
6. ?
7. Personally, I donít like heat sinks. The reason being unless you have a solid connection with the motor with heat sink paste between the two you are not going to be conducting heat but just keeping it in.
8. Check to make sure your bearings are free and that there is no binding. I clean out mine with motor spray after removing the shields. It is a time consuming process but it is worth it.
I have set my differentials so that when I hold both sides I cannot spin the gear. Then if need be when I get to the track I fine tune it for the track conditions as needed.
As for availability, it was believed to be the end of this month.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-04-2002, 03:16 PM   #4268
Tech Legend
Cain's Avatar
thanks Kraig. I am thinking of going with you guys by the way for my order. Will you recieve enough vehicles to cover all preorders?
Old 11-04-2002, 03:31 PM   #4269
Super Moderator
Kraig's Avatar
Cain, it all depends on how many they ship to us. Hopefully, they will be nice and fill our order completely.
Old 11-04-2002, 03:35 PM   #4270
Tech Legend
Cain's Avatar
I went to the website to see how much shipping is but there is no option for the free shipping, how is that handled? How much weight difference is there between the aluminum belt cover and the graphite one? I am considering getting one of these.
Old 11-04-2002, 03:40 PM   #4271
Tech Legend
Cain's Avatar
about how many preorders you have already?
How close are you to Menomenie (excuse the spelling)
Old 11-04-2002, 08:23 PM   #4272
Registered User
KeNelson03's Avatar
Send a message via AIM to KeNelson03
from the info i've gathered the chassis for the graphite edition is milled out different than that of the regular graphite chassis, its supposed to be lighter. The new holes on the a-arms changes the way the car rolls. Using the new holes would make the car rotate more in the corner. The team guys like the hole. and then there are 3 new camber link positions on the rear tower. There are pictures of the car on losi's site under the new tuning guide.
KeNelson03 is offline   Reply With Quote
Old 11-05-2002, 12:15 AM   #4273
Sigearhead's Avatar
Trader Rating: 68 (100%+)
build a better motor and get higher voltage batteries that's how.
For right now I wouldn't worry about acceleration, they key to faster laptimes is cornerspeed.
Sigearhead is offline   Reply With Quote
Old 11-05-2002, 05:07 AM   #4274
senna's Avatar
What will be the internal ratio if the 41 tooth pulley is used both front & rear (instead of the normal 42 tooth) ?
Besides the internal ratio, how will it effect the car ?
Old 11-05-2002, 06:56 AM   #4275
Super Moderator
Kraig's Avatar
Cain, we were offering free shipping on orders over $100.00 a couple of months ago. Currently we are not offering that special right now,sorry.
We are about 4 hours away from Menomonie.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
