Old 10-28-2002, 03:19 PM   #4216
LouisB's Avatar
You're CRAZY if you do that then race in the rain
LouisB is offline   Reply With Quote
Old 10-28-2002, 03:25 PM   #4217
Most people think you Britt's are crazy for running in the rain. But I will agree that Kenny is crazy, but that is because I know and race with him from time to time.
Chad
ChadK is offline   Reply With Quote
Old 10-28-2002, 03:26 PM   #4218
Registered User
KeNelson03's Avatar
Send a message via AIM to KeNelson03
99% of what i do is carpet so its not an issue. But i am crazy.
KeNelson03 is offline   Reply With Quote
Old 10-28-2002, 03:41 PM   #4219
LouisB's Avatar
I'm crazy too, at least that's what the doctor says
There's nothing quite like watching spray coming off the tyres as you go round the track, and the smell of a blown speedo
Old 10-28-2002, 03:52 PM   #4220
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally posted by senna
I am racing on an asphalt track outdoors with poor traction and I am having some difficulties with the REAR being a bit loose (i.e. Oversteer off power) I think ...
The following is my setup for the LOSI :
Front:
Kick Up - 4 Deg
Caster - 0 Deg
Camber - 1 Deg
Camber Links - Long
Shocks - Red (Soft)
Shocks - Leaned
Rear:
Anti Squat - 0 Deg
Caster - 0 Deg
Camber - 1 Deg
Camber Links - Short
Shocks - Red (soft)
Shocks - Leaned
What can I do to improve rear traction on off power, i.e. while entering a corner without loosing steering?
make your rear camber links long and what do you mean by "leaned" on your shocks? Are they all the way in? What droop are you running front and rear?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 10-28-2002, 09:12 PM   #4221
Send a message via AIM to ZER01
Senna, what is your ride height for front and rear? What is the droop for front and rear? What tires and inserts are you using? Shock pistons? Shock oil? Are you running a front oneway? How much toe in/out is on the front? How much preload are on the shocks for front and rear? If you're using a diff for the front, which pulleys are you using for front and rear and how tight is the rear diff verse the front diff? Do you use tire additive before you race?
ZER01 is offline   Reply With Quote
Old 10-28-2002, 09:27 PM   #4222
srfreeman's Avatar
Nelson,
That chassis looks great! I thought about trying that too. Do you know about how much weight you cut? I also mine on carpet most of the time, how well does debris go through the tunnel? I was concerned about debris piling up in there. I thought about milling some holes in the bottom cover to give the debris some where to escape!
Stefan
srfreeman is offline   Reply With Quote
Old 10-28-2002, 09:32 PM   #4223
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I accually did some dremel work to a spare chassis of mine last weekend.
I took out some battery slots, and may take a little more off the tunnel once i get the right bit for my dremel.
It wieghs in at .245lbs, which brings me to this Q? What does the graphite chassis weigh? I do not have a "full" chassis to put on the scale.
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 10-28-2002, 10:07 PM   #4224
Registered User
KeNelson03's Avatar
I've run around 20 runs on my car since and i haven't seen a problem with debris build up yet. But it wouldn't be that hard to pull the cover off the bottom and blow it out with an aircompressor. I really don't know how much i took off. I did it inside a garbage can to save myself from cleaning up a mess and there was a bunch of junk in it in the end. My best guess would be around 1/5, that is how much i took off.
Old 10-28-2002, 10:39 PM   #4225
Just a note on "fans".
Many of you may not be old enough to have been around to remember this. About maybe twenty years ago a F1 Ferrarri driver named Nikki Lauda raced a Formula 1 car for part of a season. This car had a large fan that sucked the air out from under the car......read-it was trying hard to draw a vacume under the car. This sucker lost alittle straightaway speed.....but talk about being on rails in the corners, nothing could touch it. Needless to say, it was quickly banned.
One interesting note: The car picked up everything on the track. Pebbles, gravel, rocks, nuts, bolt, dirt....everything, and threw them straight back. When your doing 200+ and the rocks are hitting you....well you see the second reason why it was banned.
I have watched Kinwald closely for nearly 12 years now, I just marvel at the innovation and new things he is always trying. I was there many nights when he was running the the proto-type of the XXX-S.
Graphitedust is offline   Reply With Quote
Old 10-28-2002, 11:16 PM   #4226
Here's a pic of my XXXS with some custom milling only on the graphite battery strap.
Old 10-29-2002, 02:07 AM   #4227
senna's Avatar
Thanks guys for your help ...
- I am using same shock oil front/rear (30)
- Ride height same front/rear (5mm)
- Slightly more droop in front
- Rubber tyres with soft foam inserts
- no one ways
- diffs not very tight both sides
How will diff settings effect handling?
I moved the front shock locations to the inner holes (more straight position) and it improved little bit. Today I will try to use a bit harder springs on the front.
My main problem (for the moment) is that the back is a bit loose when entering or exiting the corners ...
Any comments or suggestions ?
senna is offline   Reply With Quote
Old 10-29-2002, 02:10 AM   #4228
Sigearhead's Avatar
Trader Rating: 68 (100%+)
Senna, run your camber links in the rear as long as you can. The longer the camber link the more traction you will have.
Sigearhead is offline   Reply With Quote
Old 10-29-2002, 07:16 AM   #4229
Default Setup Help
Hi I race my XXXS on a very long indoor track using carpet. For the rules of the latest championships we have to use PITD20s with no additive aswell as the Reedy 19t motor, however the building the track is based in gets VERY cold and finding grip is very difficult. It also has a tight infield with 3 right, and 2 left hairpins so acceleration is alos useful.
I have experimented alot with the setup including rear LRC mods, the shock mods and everything you guys have talked about (apart from milling, seems a little drastic...!) I still cant get great grip. The car is full graphite.
I was wondering if you guys could help me fing a great handling car. I have a smooth driving style and so a smooth car would be rewarding for me.
XXXS_Quality is offline   Reply With Quote
Old 10-29-2002, 08:09 AM   #4230
RCTech Member #2
TSR6's Avatar
I did the same. Great idea untill you stuff a pole once or twice. Batteries slide forward.
Quality - What are you running for springs / oil? Where are the shocks located?
Give us some setup info, and we should be able to give you a "try this, try that" list..
-Troy
Troy
RCTech Member #2
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
