Old 10-16-2002, 06:07 PM   #4126
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I came from a Pro2, and the nitro world, so i guess i don't count do i?
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 10-16-2002, 07:06 PM   #4127
ijnek's Avatar
Send a message via ICQ to ijnek
i used to have a 414m(for keeps) and have another 04r running now with my 3xs.
in terms of tuning,the 3xs is as good as the 414m,this is where the 04r is lacking.
not tat the 04r is not gd,but these r 2 complete different level cars...
the 3xs felt gd and stable compare to my 04r,...but feel tat my 04r had a harder acceleration compare to the 3xs...
jus my feelings,....
feelings,...nothing more than feelings...
ijnek is offline   Reply With Quote
Old 10-16-2002, 08:06 PM   #4128
rayhuang's Avatar
I would try going to 60 pistons in the front with 50wt. I remember that being a huge change on the cars last year at Cleveland. It prevented the car from dumping over the front. To help your car on the exit try moving your rear arms and front arms all the way forward. This will help the forward drive issue that you are having.
Thats what I am going to do on the shocks then. My #60 pistons should be here this week.
I have front and rear arms forward already and liked that change, but my car still over rotates on exit. I wonder if thats too much exit steering for ME in stock. Its just might be a preference thing. I am going to take out the neg. kick-up on that car next practice session. If its becomes too aggressive again on turn in, I'll run a stiffer front spring or play with Caster some more.
I have my Mod Losi car set-up with the negative kick-up in front and I know thats gonna help as that car pushes out on exit (as mod cars will do!!).
Thanks Todd,
Ray
Old 10-16-2002, 08:38 PM   #4129
shrekair's Avatar
Trader Rating: 9 (91%+)
ray- try reducing rear droop.
shrekair is offline   Reply With Quote
Old 10-16-2002, 09:25 PM   #4130
Default Does anyone have....
the new part numbers for the new rear shock tower and other updated parts? I read in the new Graphite plus edition it comes with the new updated parts. Any pics would be nice also. Thanks.
Nightbreed is offline   Reply With Quote
Old 10-16-2002, 09:45 PM   #4131
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
No new part numbers as of yet.
I do believe that the rear shock tower will be a running change so that means no part numbers. The same can be said for the rear arms. The rear hubs on the other hand will have a new part number. Todd H. believes they should be available around the Cleveland race.
Just wanted to let everyone know that we got in a shipment of Losi XXX-S parts. We are also expecting more in next week (they have to ship cross the country).
Highlights include the Aluminum Dog Bones, 6 degree blocks. Stop on over and take a look, KT Hobbies.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 10-16-2002, 10:03 PM   #4132
ijnek's Avatar
Default carbon shock towers
this has got 2 be the koolest carbon shock towers for ths 3XS.
from PRP...
take a look at the hole available for tuning,...no less than the Xray T1 evo2!!!
Old 10-16-2002, 10:12 PM   #4133
Send a message via Yahoo to Doug Gaut
I have a set on my car!! They are sweeeeet! Ran them all last weekend with no problems. Gonna try some new camber positions this weekend. They are a great addition.
Doug Gaut is offline   Reply With Quote
Old 10-16-2002, 10:16 PM   #4134
ijnek's Avatar
u know where i can get them online and pay through credit cards???...i'm having trouble finding a website which allows mi to do this...btw,wat does PRP stands for?...
Old 10-17-2002, 10:45 AM   #4135
senna's Avatar
Are the Losi threaded shock bodies good enough? Why it seems that many people are using shocks of other rc cars? Do they really leak (loose oil) a lot?
senna is offline   Reply With Quote
Old 10-17-2002, 11:04 AM   #4136
rayhuang's Avatar
Default Shocks
My rear shocks are quite good. For some reason my front short shocks with Nitride shafts build beautifully then the next day-squeek, squeek!!! I dont know why??? Some friends with XXXS report eame issue with front shocks. But there is no evidence of leaking oil anywhere.
Weird , eh?
Old 10-17-2002, 02:10 PM   #4137
psycho's Avatar
My shocks definitely leak air. They don't leak oil, though. I usually just stick them in the shock pump and top them off before each race day and they are fine.
psycho is offline   Reply With Quote
Old 10-17-2002, 02:24 PM   #4138
RCTech Member #2
TSR6's Avatar
The losi shocks are designed to have some air in them. If they did not have air in them, then it wouldn't compress. When you first build them, yes they might not have air in them. They will pull air around the seals, as when you first build and bleed, they will have a vaccume in the shocks. Then when it equalizes, thats when you have a ''perfect shock''
Troy
RCTech Member #2
Old 10-17-2002, 05:01 PM   #4139
Send a message via ICQ to kentot Send a message via Yahoo to kentot
does anyone know if losi made a composite or graphite low roll adapter for xxxs losi? please post the part number if there is one.
thanks
kentot is offline   Reply With Quote
Old 10-17-2002, 06:53 PM   #4140
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
kentot: uy may balak ang isa djan! hehehe dami mo nababasa dito tunkol sa low, mid at hi roll noh? may negative anti dive pa o say mo? ever! hehehe pero pare, walang lumabas na graphite. lalabas pa lang with the relaese ng graphite plus kit sa november!
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
