Old 10-14-2002, 06:33 AM   #4066
ijnek's Avatar
Send a message via ICQ to ijnek
i had no problem throwing my 3xs around corners as long as i keep my cool...
any1 experience with overdrive yet?...
my feeling is tat overdrive will make the car feel more like forward wheels driven and underdrive will make it behave like a rear wheels driven car,...any1 done any testing on this yet?...
ijnek is offline   Reply With Quote
Old 10-14-2002, 08:09 AM   #4067
senna's Avatar
Referring to your previous replies ... it seems that the .28 shock shafts are used only on the front !
What is the best shock shaft for rear ? (0.36) ?
senna is offline   Reply With Quote
Old 10-14-2002, 08:20 AM   #4068
LouisB's Avatar
senna, stay with .36 for the rear, .28 is too short
ijnek, I've run both over and underdriven set-ups. Overdrive pulls the front wheels round the corner under power and gives more steering on power but less off power. I also found that it kept the rear in line and stopped it from breaking loose, it just followed the front round the corner
I sacrificed some old Pro-10 rear tires to stop the battery pack from falling out of my car, it happened twice in one race!
LouisB is offline   Reply With Quote
Old 10-14-2002, 09:09 AM   #4069
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Oneways: What do you guys do for maintenance?
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 10-14-2002, 09:36 AM   #4070
TSR6- For oneway maintenance, I just run the crap out of it and then buy a new one at the begining of the next season. It may be sad to say but when I have tried to clean and relube oneways they have allways felt poor after, so I just spend the money.
Chad
ChadK is offline   Reply With Quote
Old 10-14-2002, 10:52 AM   #4071
Default Spring Rates
Hi Guys
Thank you for the replies. Yes I noticed most people use different springs than Losi, especially Trinity.
Thank you again for your help
PaulP is offline   Reply With Quote
Old 10-14-2002, 11:01 AM   #4072
For my one way I used to spray and the berings with motor spray then run Assoc. black greese in the one way it self. It felts stiff for a while then frees up after one run.
teamAE is offline   Reply With Quote
Old 10-14-2002, 02:34 PM   #4073
psycho's Avatar
I lube my one-ways with HPI ceramic grease. It's a silver color and comes in a small blue jar thingy that's about the size of a bottle cap. I just scrape out a small amount with an x-acto blade and put it on a couple of the rollers in the bearing and it works like a champ.
psycho is offline   Reply With Quote
Old 10-14-2002, 03:45 PM   #4074
RCTech Member #2
TSR6's Avatar
Thanks for the replies.. I just know my oneway is not as smooth, and free rolling as before.
I'll spray it out, and use some Team1 fluid on it..
-Troy
Troy
RCTech Member #2
Old 10-14-2002, 04:46 PM   #4075
Anyone tried overdrive or underdrive with one-way ?
ongbenghui is offline   Reply With Quote
Old 10-14-2002, 05:17 PM   #4076
ijnek's Avatar
wat do u mean by "I sacrificed some old Pro-10 rear tires to stop the battery pack from falling out of my car, it happened twice in one race! "...
seems let overdrive is interesting n really makes my theory make sense tat overdrive will b inducing forward wheels driven effect!!!...
Old 10-14-2002, 07:58 PM   #4077
Company Representative
What is the final drive ratio of the XXX-S? Thanks.
Gary F.
Gary Fliegel is offline   Reply With Quote
Old 10-14-2002, 08:20 PM   #4078
ijnek's Avatar
i remember tat the internal drive ratio is like 1.883 rite?...
have 2 check the menu 4 the exact value...
as 4 ur question.i guess tat depends on how u gear ur car rite?...
1'm running 88spur on 25 pinion for stock...
Old 10-14-2002, 08:45 PM   #4079
RCTech Member #2
TSR6's Avatar
Gary F.
1.83, assuming you mean internal. Final depends on too many variables for me to answer that for you.
Troy
RCTech Member #2
Old 10-14-2002, 09:06 PM   #4080
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Hi everyone! Just wanted to let you know that we got in some of the XXX-S Titanium Screw kits and Ball Studs. We are also expecting in a shipment of Losi stuff this week as well. There will be 6 degree blocks in there as well.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
