Old 10-02-2002, 10:22 AM   #3931
Big Pete's Avatar
Thumbs up
I've used stick radios since I cant remember! Got into racing using a 50 27mhz radio but found it very limiting so I upgraded to a 40mhz. This was a pistol type (KO Presto EX11) at around the 150 mark. I suffered far less glitching but couldn't get used to the layout. I had some extra money after doing a lot of overtime and bought the Exzes. I picked one up at the LHS and it just felt right in my hands(ooeerrr! ) , as stated it all comes down to personal preference and available monies!
I also think a lot comes down to regional preferences. We do have pistol type radios for sale this side of the pond but, as I've already said they just aren't that popular.
I use finger and thumb to control throttle and steering as I find it gives me better control but you must have a neck strap to use it like this, I wouldnt use my radio without one it cost too much to drop!
Later guys,
Pete.
Big Pete is offline   Reply With Quote
Old 10-02-2002, 10:42 AM   #3932
OBY
OBY's Avatar
BIG PETE:
oops caps, anyway, email me a list of parts at pyroheim@hotmail.com a thank you!
OBY is offline   Reply With Quote
Old 10-02-2002, 12:28 PM   #3933
LouisB's Avatar
I used to have a strap for my radio but a couple of months I took it off and found I got a little quicker and much more consistent laps I think it must have changed the way I held the Tx (or restricted blood flow to my brain) and it is definitely more comfortable now.
LouisB is offline   Reply With Quote
Old 10-03-2002, 03:50 AM   #3934
Big Pete's Avatar
Hi guys I thought I'd try and post some pics.
Here goes
no luck, i'll try again!
Old 10-03-2002, 04:25 AM   #3935
Big Pete's Avatar
Talking
Here goes nothing!
Ahh! for got to attatch the file the first time!
Ill post a link to the pics, they are too small to see properly!!
Here goes:
The chassis, full graphite
http://photos.yahoo.com/bc/tc3pete/v...iew=t&.hires=t
Can you say spares?!!
Thought you might want to see the body
Specs for those who want to know!
Full graphite chassis, ally front CVD's, full alluminium from Fasttrax, Quantum competition esc, Delrin front diff outdrives, ally support fitted to rear outdrives Orion Chrome Stock running 27/90 gearing, short shocks on front threaded all round with the nitride shafts,overdriven front diff...... erm thats I can think of at the moment!
All that and the huge amount of spares! I'm going to build a complete spare chassis and probably keep the rest for just in case
For the more curious, thats a NTC3 and a HPI SUper nitro in the back ground!
Enjoy!!
Pete.
Old 10-03-2002, 04:49 AM   #3936
Default Re: Graphite XXX-S
Here are a few other details on the graphite XXX-S
--New belt which is yellow
Hi Todd, you mention the graphite XXX-S will come out with a new belt which is yellow in color. How different the yellow belt with the original blue belt in terms of their performance ? Would the yellow one skip ?
My original blue belt skipped several times during the race and it was frustrating. I managed to tighten the tension, but it still skipped.
Any advise to avoid it ? (I dont use reverse nor break).
Thanks,
Jeomii is offline   Reply With Quote
Old 10-03-2002, 09:19 AM   #3937
LouisB's Avatar
Jeomii, It's normal for the belt to skip about 4 clicks when slowing down, you say you don't use the brakes but do you have any drag brake set up, that may be the cause? Check your drive train for binding, just make sure nothing's rubbing and that the bearings are OK.
Old 10-03-2002, 11:27 AM   #3938
ijnek's Avatar
Send a message via ICQ to ijnek
Default problem with xxx-s
need help.
i have this problem recently...
on the straight,the car perform as normal,but when i steer either left or right direction,there is a funny binding sound coming from my car.i rebuilt the CVD,but the problem is still there...any1 can advice?...
thanks
ijnek is offline   Reply With Quote
Old 10-03-2002, 11:43 AM   #3939
Send a message via AIM to ZER01
IJnek, I beleive futureal knows how to solve the problem-LOL! Actually, I think there is no way to fix the problem with the stock and Losi Aluminum CVD's. I haven't really seen anyway it affects performance though. http://www.rctech.net/forum/showthre...0642#post20642
ZER01 is offline   Reply With Quote
Old 10-03-2002, 11:50 AM   #3940
LouisB's Avatar
My car does that too but I don't worry about it
Old 10-03-2002, 12:57 PM   #3941
shrekair's Avatar
Trader Rating: 9 (91%+)
add a washer on the knuckle to eliminate stering throw, this nalso fixes that problem
shrekair is offline   Reply With Quote
Old 10-03-2002, 01:25 PM   #3942
senna's Avatar
Can you order the "red" hop ups for the LOSI XXX-S online on the internet and where?
Is it possible to find "lightweight" locknuts to secure the wheels?
Are there more efficient belts than the standard "blue" one?
What do you think about the .28" titanium threaded shocks? Are they too short or good enough?
Thanks again for your help.
Regards,
Mark
senna is offline   Reply With Quote
Old 10-03-2002, 02:01 PM   #3943
shrekair, addind washers on the front carriers only solves wheel bouncing from side-to-side(horizontally) when turning. Losi's street weapon was bad about this. The XXXS doesn't have that problem, this problem lies in the cvd's when fully angled-they bind(vertically). Most of this is due to the fact the way the cvd's are angled to the rear more than perpendicular to the chassis. The only some what fix I have found is that you can space your front arms most furthest forward to eliminate the binding, this will help make them more perpendicular to the chassis. That an eliminate some servo throw. I'm on a mission now though
Old 10-03-2002, 02:04 PM   #3944
Senna, I beleive Losi's new yellow belt will be more efficient than their blue belt but it is dedicated to stock racing and might wear out more quicker with mod. The new Losi graphite kits will come equiped with these.
Old 10-03-2002, 09:23 PM   #3945
ijnek's Avatar
but the sound was really loud!!!...
so from wat i gather here is i should move my arms position 2 the most forward position n also change away the stock CVD...
wat is a gd replacement for the stock CVD and where can i get it online???...i'm still new 2 this car...in fact,jus got it and the sound occur on my 1st run n i stop running the car...
sure there's no problem even if i run my car with the funny sound?...
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
