Old 09-11-2001, 01:04 PM   #376
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Is the belt clicking or is it something else within the drivetrain? Does it click in the front of in the rear?
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 09-11-2001, 04:44 PM   #377
Trips's Avatar
Trader Rating: 16 (100%+)
ProRacer03--
Check to see if your spur gear is wobbling. I've seen one or two XXX-S's where the spur was wobbling and hitting the tensioner pulley once per revolution. That might cause a clicking sound...
Just pull the pinion off or remove the motor, and turn the drive train by rotating the wheels. Watch the spur and see if it touches the tensioner at any point in its revolution.
If that doesn't get it, you might check for a bound up CVD joint. I had to repair one when I worked in the hobby shop where the owner got a little too much threadlock in there and it bound the CVD up. That was clicking like crazy until I freed it up.
Hope that helped,
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 09-11-2001, 05:28 PM   #378
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i run the 41 tooth gear....
also i have been using the 4 deg assc. caster blocks.....i have bent 3 dogbones....all in the front..only one was from a really bad hit...
Matt M. is offline   Reply With Quote
Old 09-11-2001, 06:20 PM   #379
HarshGuy's Avatar
Hey thanks guys that might just be it, I am in fact running the 4 degree AE castor blocks. Actually, I tried the Losi 4 degrees and the "bump" in them rubs up against my shock springs so I went back to the AE ones.
rcspeed, I'm having a hard time visualizing your stop ...do you have a digicam can you snap off a pic and email to me? HarshGuy@rcracing.com ...or post the pic here?
Yea I couldn't believe how well it ran with 3 wheel drive. The car is awesome.
HarshGuy is offline   Reply With Quote
Old 09-11-2001, 08:27 PM   #380
Administrator
Matt M.'s Avatar
harsh guy...i agree....have any of you bent front bones????
Old 09-11-2001, 08:38 PM   #381
here's my fix for the problem with thre dogbones &cv's
rcspeed is offline   Reply With Quote
Old 09-11-2001, 08:39 PM   #382
one more pic
Old 09-11-2001, 09:32 PM   #383
Rocket Ronbo's Avatar
Send a message via AIM to Rocket Ronbo
ProRacer03
Check the hubs and spindles, when you install the camber ball it can push some plastic against the cvd causing a clicking sound.
Another location to look at is the front cvd's, if there is a bind they may click at low speed.
for a 8 turn i used a 18 to 20 depending on the track and how long i was gonna run 4 or 5 min. for a 9 I would try 1 tooth higher
i am running trinity 8 doubles
Ron
Rocket Ronbo is offline   Reply With Quote
Old 09-12-2001, 07:23 AM   #384
Administrator
Matt M.'s Avatar
rc....thank you...your car looks just about like mine....with the blue...i think i am going to get some of the francis line, then strip it....then go with plain alum......like my 414x.....
Old 09-12-2001, 09:37 AM   #385
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
Rocket Ronbo-
"beating youger drivers"...... lol .....
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 09-12-2001, 06:09 PM   #386
Well guys just got my graphite front and rear shocktowers and the graphite chassis installed. Car looks pretty trick with all that milling. Just wish Losi would have included a graphite cover piece for the belt along with the chassis. Looks kinda silly with all graphite underneath with a big black belt cover.
Schuie Driver is offline   Reply With Quote
Old 09-13-2001, 05:46 PM   #387
Yup.
More dough for the cover and battery stap. I think they are packaged together.
Tim Davis
Old 09-13-2001, 06:37 PM   #388
Actually I believe the belt cover and the rectangle piece that fits in the chassis up by the steering bellcranks are what are packaged together.
Going to be tough going to race this weekend with all of the tragic events of this week. Hopefully it will get my mind off it for a while.........
Old 09-13-2001, 07:04 PM   #389
Jared Kirkwood's Avatar
Send a message via AIM to Jared Kirkwood
Any one got a total graphite setup yet? If so did you weigh the car before and after the updates? How much did you loose?
Losi says you will loose once ounce if you add their chassis. They didn't say how much you would loose by replacing everything else.
Also, you guys doing the graphite, are you noticing any performance changes?
Jared Kirkwood is offline   Reply With Quote
Old 09-14-2001, 07:56 AM   #390
Default Which fron shocks?
I'm about to add threaded shocks to my XXX-s kit and I read that some people are using the short shocks from the cryul conversion kit for the street weapon.
So, has anyone tried using the short shocks in the front. What are the pros and cons.
meche is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
