Old 09-23-2002, 08:48 PM   #3871
stefan's Avatar
Send a message via AIM to stefan
Default Re-entry :-)
Hi guys,
I haven't run my XXX-s since the snowbirds.Now it's time to dust it off and prepare it for racing again.
Have there been any setup revolutions lately?
I checked Losi's site for new setups, duuuh.
Also, did they come out with stronger bumpers that hold a droop setting yet?
stefan is offline   Reply With Quote
Old 09-23-2002, 08:53 PM   #3872
TC3MIKE's Avatar
Send a message via Yahoo to TC3MIKE
As you raise one end or corner of the car up weight is tranfered to the opposite end or corner of the car . The higher you lift that end or corner of the car the more weight is transfered to the opposite end. Anyways, too much droop could make your car push in a corner or make you loose.
TC3MIKE is offline   Reply With Quote
Old 09-23-2002, 09:27 PM   #3873
rayhuang's Avatar
Default Parma X20 190mm!!!
What is the current preference on the new bodies out right now? Protoform Stratus 2.0, Losi Alfa, Trinity Reference or Yokomo Stratus
I think a lot of people are going to be suprised by this body!!! It has been tested by several World and National Champs in sevral countries and to a man they said-more planted than a Stratus and could turn more, and faster laps in 5 minutes than the PF Stratus. The only bad thing some sad was that there sponsorships precluded them from running one!!!! Mike Lufaso, Eli Ezrow, Rob Love, etc . all can run any body they want and run the X20 by choice. Expect to see it a lot this coming winter.
Old 09-23-2002, 10:18 PM   #3874
TRF414M's Avatar
I prefer Protoform 2.0 because it is average all around and cheaper than Yokomo.
TRF414M is offline   Reply With Quote
Old 09-23-2002, 10:27 PM   #3875
AllPimpRacing's Avatar
Send a message via ICQ to AllPimpRacing Send a message via AIM to AllPimpRacing
Finally I made the switch to the Losi. I picked up the graphite convertion kit and a brp front bumper, but what other hop-ups would be ideal for a asphalt track with medimum straights, couple of 90's and a few sweepers? I'm planning on getting the threaded shocks, but looking for anything else!
AllPimpRacing is offline   Reply With Quote
Old 09-24-2002, 06:40 AM   #3876
TC3MIKE's Avatar
Pimp, where did you find that Brp losi bumper?
Old 09-24-2002, 06:55 AM   #3877
Mike, I had to special order it from my LHS. I'll try to find the part no. for you if you want!
Old 09-24-2002, 07:00 AM   #3878
Here's the part no. 6226 - Wide Front Bumper. You can order it direct from BRP or could get it from your LHS!
Hopes this helps!
Old 09-24-2002, 08:00 AM   #3879
TC3MIKE's Avatar
Thanks Pimp
Old 09-24-2002, 08:41 AM   #3880
rayhuang's Avatar
Default BUmpers
As a matter of fact they did!!! On the plus side is they will hold a droop seting, but on the negative is I doubt you'll be able to bend them down to replace the hingepin blocks. Not a huge deal, but still, who wants to take more off the car then you need to!!!
There is not a part numbers for it yet. Todd Hodge said that it WILL have a different part number than the regular one, so you can choose.
Old 09-24-2002, 08:55 AM   #3881
Originally posted by mmmm
i have a new losi xxx-s kit. what parts should i stock ? what parts break easily? does the stock main and inner pivot block mounts break easily? do i really need to upgrade to a graphite chassis?
mmmm is offline   Reply With Quote
Old 09-24-2002, 09:28 AM   #3882
stefan's Avatar
Default Thanks Ray,
now that I got rid of my NTC3, I have time for my other cars again
Old 09-24-2002, 11:03 AM   #3883
rayhuang's Avatar
Default Some answers
mmmm, thats a tough question as we can give you the all out racing answer or the $$$ answer!!! Your choice!!!
If you are going to race and try to be ultra competitive, the answer is you have to get the Graphite kit!!! No questions asked. I personally dont thnk the hingepin blocks are an issue.
On breakage, I dont know that the XXXS has a particular weak spot, but front and rear arms, front hub carriers and steering blocks are always a smart investment before any racing event.
For tuning, get all the springs, including the Trinity Congo line, 2,4 degree caster blocks and the different rear toe in blocks (1/2 and 1 degree) and any optional hingepin blocks.
The rest depends on asphalt, carpet, rubber tires or foam tires!!!
Old 09-24-2002, 01:12 PM   #3884
OBY
OBY's Avatar
Originally posted by LouisB
OBY, I'm going to order some of those ING tyres (the special 3 full sets for 30) One person at the club tried some and he said they were pretty good
I would try the one-way for all those big Scottish tracks, do you know of anybody who's tried the apex one-way. It looks pretty good but I'm not sure about the wear rate on the metal outdrives
tyres arent a problem....had our last outdoor meeting this year so i'll see how the tyre war is come next year.
apex one way - never seen it in any car...i'd prefer the losi one.
plus the tracks arent that big for a one way!
OBY is offline   Reply With Quote
Old 09-24-2002, 01:59 PM   #3885
LouisB's Avatar
OBY: Are other cars using one-ways? I would have thought that you'd be running on big tracks if they were for nitros, and Eurpean tracks are in general bigger than US ones.
I would go for the Losi one-way too, it looks much lighter and better designed than the Apex version.
LouisB is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
