Old 09-22-2002, 05:40 PM   #3856
R/C Tech Founder
R/C Tech Charter Subscriber
Often times, people will "over drive" a track, trying to cut everything as close as possible. It's important to remember that the shortest run line is not necessarily the best run line, and that is especially true in tracks with wider lanes and fewer 180-degree corners. Plus, there are benefits of taking a less dangerous path around the track...
The key is to find the line that will let your car flow through a corner without scrubbing much speed, and that line changes depending on your setup. If your car is set up "tight" with a lot of steering, you're going to want to turn in sharply and hit the "back" of the corner. If your car is a little loose, you'll want to take the corner a little wider so you won't scrub off as much speed -- taking tight corners with a loose suspension will cause your rear tires to break traction, resulting in speed loss.
It's not always noticable on a fast track, so it's important to keep in mind what you're doing, and always check your lap times afterwards. If lap times aren't available, see how you do relative to some of the faster drivers at the track.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 09-22-2002, 06:31 PM   #3857
Fire's Avatar
exactly, treat the track at a whole instead of individual coners, always set up for relatively long straight
Fire is offline   Reply With Quote
Old 09-22-2002, 06:33 PM   #3858
TRF414M's Avatar
I used 86/31 for my gear ratio. It should be 5.08 instead of 5.2. My friend told me to use 115/39 which is 5.38. The speed is excellent and run time is more than 10min. with Panasonic (Black).
As far as durability wise, You either use the BRP Front Bumper to help protect the A-arms or just stock tons of A-arms.
TRF414M is offline   Reply With Quote
Old 09-23-2002, 12:52 AM   #3859
Trader Rating: 55 (100%+)
oby- are you running a one-way? what's your setup like? i find the losi to be awesome on such tracks..
smooth steering controll is important too, rather than going from full lock to no lock repeatedly through the corner which will scrub off speed not to mention unsettle the car.
tones is offline   Reply With Quote
Old 09-23-2002, 04:45 AM   #3860
OBY
OBY's Avatar
arent running a one way, i'll post the setup i have a little later, its kinda complicated...you'll see what i mean.
OBY is offline   Reply With Quote
Old 09-23-2002, 11:29 AM   #3861
LouisB's Avatar
OBY, I'm going to order some of those ING tyres (the special 3 full sets for 30) One person at the club tried some and he said they were pretty good
I would try the one-way for all those big Scottish tracks, do you know of anybody who's tried the apex one-way. It looks pretty good but I'm not sure about the wear rate on the metal outdrives
LouisB is offline   Reply With Quote
Old 09-23-2002, 02:53 PM   #3862
Tech Legend
Cain's Avatar
Trader Rating: 220 (100%+)
The best way I have found to save my parts is to buy the BRP front bumper, custom fit BRP nerf wings to the side, and just leave off the aluminium. THe BRP stuff works wonders!!
Old 09-23-2002, 03:43 PM   #3863
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
.. i personally prefer the "not hitting stuff" method.
Sometimes it fails though.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 09-23-2002, 03:54 PM   #3864
shrekair's Avatar
Trader Rating: 9 (91%+)
what do you guys run for droop? its one tuning tool i've never used but i know its there. i've always run 2mm less infront then the rear. either 2/4 or 3/5 . what does changing this ratio do like running 5/5 or 4/4 or 4/2???
shrekair is offline   Reply With Quote
Old 09-23-2002, 05:36 PM   #3865
try 2 kimbro spur gears glued together. this puts it a 10mm. Kinwald runs this and you can change it for diffrent tires.
teamAE is offline   Reply With Quote
Old 09-23-2002, 06:11 PM   #3866
shrekair's Avatar
yeah, but how does changing the droop ration effect my car, what will mroe or less do?
Old 09-23-2002, 06:54 PM   #3867
Send a message via Yahoo to Doug Gaut
What is the current preference on the new bodies out right now? Protoform Stratus 2.0, Losi Alfa, Trinity Reference or Yokomo Stratus
Doug Gaut is offline   Reply With Quote
Old 09-23-2002, 07:42 PM   #3868
TC3MIKE's Avatar
Send a message via Yahoo to TC3MIKE
More droop = more traction front or rear. Too much will slow you down.
TC3MIKE is offline   Reply With Quote
Old 09-23-2002, 07:45 PM   #3869
shrekair's Avatar
how will it slow me down?
Old 09-23-2002, 07:46 PM   #3870
TC3MIKE's Avatar
I use the Stratus 2.0 on my losi and I cant feel no difference versus the older stratus.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
