Old 09-18-2002, 10:07 PM   #3811
shrekair's Avatar
Trader Rating: 9 (91%+)
rayhuang - try andrew gray's foam setup for the xxx-s. it is listed on the losi site and works well here in minnesota
shrekair is offline   Reply With Quote
Old 09-19-2002, 12:06 AM   #3812
TeamPRP's Avatar
Default Shock towers
The Team PRP XXXS shock towers are in production and we are now accepting Pre-orders on them. Please check out our site for all of the information including our pre-order deal, http://home.attbi.com/~teamprp/
T. Hodge- send me an email, I can send a pair out to you this week if you'd like to mess around with them before OktoberFAST. teamprp@attbi.com
Thanks much!
Ben
TeamPRP is offline   Reply With Quote
Old 09-19-2002, 04:54 AM   #3813
black-knight's Avatar
R/C Tech Charter Subscriber
Originally posted by black-knight
do the xxx-s drive shafts fit the old Street Weapon?
yes i was talking about CVD's
thanks for the tips and info guys!....
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 09-19-2002, 10:46 AM   #3814
Default Front Shocks
I have a XXXs that I bought second hand, the guy I bought it from said it has front shock shafts for carpet racing ie .28 in a standard threaded shock body. I have had a look and they are a gold colour but how do I tell if they are standard length or the .28 version?? What does the .28 refer to ??? Can I measure them if so what size should they be?
Bosscat is offline   Reply With Quote
Old 09-19-2002, 12:01 PM   #3815
rayhuang's Avatar
Arrow shock shaft info.
0.28 refers to the amount the shock shaft moves in and out of body (the throw as it were). I think you could measure that no problem. Should ne 0.28" or 7.1mm I think!!!
Also-if the front shock bodies are shorter than the rear bodies-you have got the short front shock kit on the car. The gold color is a nitride coating to make it harder and smoother. Losi makes a short shock kit that includes those shock shafts and the threaded bodies. I think you are good to go!!! If not-you can buy the bodies. Part #A-5027
To measure-I would put a thin black line on shock shaft at full compressed with a thin Sharpie. Then fully extend it and make another mark. Measure the distance between marks. Lets hope it either 0.28 or 0.36.
If not-sorry!!
Old 09-19-2002, 01:46 PM   #3816
Thanks very much I'll give it a try, I presume then that .28 is the one to go for as I race mostly on carpet
Old 09-19-2002, 02:41 PM   #3817
Default question
What have you guys seen being uesd to layout a track on carpet?
Are 2x4's or some type of PVC pipe being used? what works best, any ideas are welcome.
Eric
ErikF-Fike is offline   Reply With Quote
Old 09-19-2002, 05:20 PM   #3818
tufferwilde's Avatar
Hmmm.... Looks like someone is doing a little bit of research for a nice pretty new track in Tucson...
What up Mr Fike (as in Nike) - how are things going in Tucson??
The wonderful state of Kentucky is... well.... very green... and wet compared to the desert!!!
Any news on the opening of the carpet track?? Or are you going to continue to race at the glitch box?
Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 09-19-2002, 05:35 PM   #3819
Wilde (are those banjos I hear???:P)
I've been told (heard) that it's expected to be the trhird week of October... and yes I will most likely continue to race at HappyTown. The new asphalt is real nice and smooth mucho, mucho traction. I also hear that the off road is pretty nice... no rocks....
Eric
Old 09-19-2002, 05:57 PM   #3820
Moderator
Speedo's Avatar
Default Re: shock shaft info.
That would be the hard way
Measure the shock when it is fully extended, then again when it is fully compressed. Digital calipers are nice for this Obviously you would then subtract the shorter measurement from the larger to get the ammount of travel.
Speedo is offline   Reply With Quote
Old 09-20-2002, 09:14 AM   #3821
Trader Rating: 27 (100%+)
Send a message via AIM to John Stranahan
Default course design
Eric F-Don't know if you got an answer to course design already. Your e-mail is turned off. Send me an e-mail for a little description of the pipes to use. John Stranahan@aol.com. Use 2" PVC with oversize 2"2 inch wood internally with countersunk screws to make the joints. Use 1.5 inch flexible silastic pipe for the curves.
John Stranahan is offline   Reply With Quote
Old 09-20-2002, 09:14 AM   #3822
Registered User
Default Re: question
Eric
Ae the Stockton track, site of the 2002 ROAR Carpet Nats, they used plastic downspouts with velcro. It provides more give than a 2x4.
thatdog is offline   Reply With Quote
Old 09-20-2002, 09:35 AM   #3823
Velcro... that seems like a good idea, but what does it do to the carpet in the long run? Also does it withstand the impact from the cars?
John, I'll email you later today.
Eric
Old 09-20-2002, 11:48 AM   #3824
psycho's Avatar
What they do at Stockton is mount square pieces of wood inside the downspout to connect pieces together. The velcro only holds the assembled track layout to the carpet. There are large pieces of velcro hooks all along the bottom of each piece and they do hold in place very well. After each race, the marshals have to move the heavily hit sections of track back in place, but that's pretty standard.
psycho is offline   Reply With Quote
Old 09-20-2002, 01:10 PM   #3825
OBY
OBY's Avatar
TSR6: mmmm hairy bearings!!
OBY is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
