Old 09-17-2002, 07:43 PM   #3796
Fire's Avatar
when i was running on carpet i found a mix of both tied up onto the rotating part
Fire is offline   Reply With Quote
Old 09-17-2002, 08:49 PM   #3797
shrekair's Avatar
Trader Rating: 9 (91%+)
rayhuang
with your setup i would do 3 things.
1. shorten your rear camber link, go to the #2 hole on the tower
2. stiffen your springs, go trinity congo blue (front), and losi black (rear) you could even go congo purple front, congo blue rear.
3. go to 10 wt heavier oil. run either 70 wt f/r 56 front piston 55 rear, or 56 pistons 70f/60r or possibly even 10 wt heavier 80/70
when on foams i run either underdriver 41/42 or standard 42/42
shrekair is offline   Reply With Quote
Old 09-17-2002, 09:26 PM   #3798
icon's Avatar
Send a message via AIM to icon
Default Re: Graphite XXX-S
Originally posted by T. Hodge
-chassis-The car uses the same chassis. We are changing the way it is milled out. Right now it is about 1/2 oz lighter than the original lightened chassis.
-Rear arms and hubs-The arms have a another hinge pin hole located .150" in from the outside hole. Then we have new hubs that are offset .150" wider. This is the rear end we ran on carpet with foam tires and worked well. We have also found it works well on apsphalt and rubber tires.
caster blocks-Yes they will work on the existing front arms.
Here are a few other details on the graphite XXX-S
-Full graphite components
-New stiffer foam bumpers
-New stiffer plastic bumpers for the front and rear. This helps relieve the flexing problems with the droop screws.
-Ball bearing steering
-New front bumper brace that does not affect the front sway bar.
-Team Losi 24mm mesh wheels
-New belt which is yellow
-New rear shock tower. This shock tower is the same as the exisiting shock tower. The only change is that is has 3 more optional lowered holes for the camber link.
-High and low roll center blocks.
-Aluminum CVD's with aluminum 8/32 low profile wheel nuts
-Lunsford Titanium Turnbuckles
-Team Losi Alfa Romeo Body with high downforce wing. This body/wing is awesome!!
Will the Trinity Matt Francis line of options fit the new car. I'm wondering about the rear hubs and arm carriers since the rear hub has been redesigned. Also does it include the short threaded shocks (part# A5081) or standard sized threaded shocks? Thanx in advance.
icon is offline   Reply With Quote
Old 09-17-2002, 11:25 PM   #3799
Sigearhead's Avatar
Trader Rating: 68 (100%+)
I've been told the front shocks are the short shocks and as far as the MF aluminum hubs they will work as long as you use the original outer holes on the arm and not the inner holes. Everything else should fit. The chassis is still the same just milled out differently to shave off more weight.
Sigearhead is offline   Reply With Quote
Old 09-17-2002, 11:49 PM   #3800
icon's Avatar
Thanx man. I havent played with electrics since my Pro 2 so i'm a newbie now . does anyone bash with this car? i'm planning to run a esc with reverse on it, but with the belt skipping under braking i dont know if this is such a good idea. the graphite ed. comes with a new belt that should eliminate the skipping right?
Old 09-17-2002, 11:53 PM   #3801
Sigearhead's Avatar
I doubt it will eliminate the skiping. That's just something you have to deal with when running this car. I never use breaks, so I never have to deal with it. The new belt should be more efficient while keeping the strength of the old one. You can try and tighten the belt a little and this might eliminate some skipping and since you say you're just bashing I'd play around with the tension of the belt. If you go from full throttle to reverse or brake the belt will skip, even the new one.
Old 09-18-2002, 01:51 AM   #3802
I really wish Losi will have a Graphite chassis WithOut Milling.
ongbenghui is offline   Reply With Quote
Old 09-18-2002, 04:30 AM   #3803
rayhuang's Avatar
Lightbulb Stuck XXXS!!
Hey guys,
Thanks for tips!! I will play with dampening for sure. Also-this car has diffs. 1/16 out on front and 1/8th out on rear.
Thanks agin,
Ray
Old 09-18-2002, 06:28 AM   #3804
black-knight's Avatar
R/C Tech Charter Subscriber
do the xxx-s drive shafts fit the old Street Weapon?
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 09-18-2002, 07:03 AM   #3805
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Icon, you can just adjust the tension of the belt to eliminate skipping.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-18-2002, 08:44 AM   #3806
Fire's Avatar
i believe neither the xxxs nor the street weapon uses a drive shaft......
if you are talking about the belt then xxxs uses 1 belt, street weapon uses 3 belts......
Old 09-18-2002, 10:50 AM   #3807
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I think he ment CVD's... Unfortunately i do not have an answer.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 09-18-2002, 10:59 AM   #3808
The Street Weapon rear CVD shafts are a little bit shorter then the XXX-S ones, I have a set on my car right know because I had them and they were alum. Using XXX-S ones on a SW may be an issue as they bottom out in the diff.
Chad
ChadK is offline   Reply With Quote
Old 09-18-2002, 06:46 PM   #3809
rayhuang's Avatar
Arrow Carpet set-up tips.
shrekair and everyone else-Thanks for tips for my car on carpet/foams. have increased the weight of oil front and rear, stood shocks up one hole and also went up in spring rate. I think it will all help tremendousely. I want to keep the steering, but lose the unpredictibility!!!
But this is a great start. I'd rather start the season with too much steering than be fighting a push!!!
Old 09-18-2002, 07:31 PM   #3810
STLNLST's Avatar
Trader Rating: 19 (100%+)
They should fit in the front because that's where I got my shinny CVD'S from. The street weapon front MIP cvd's fit but were a hair bit longer than the XXXS so I had to shave them a little but going from XXXS to street weapon shouldn't be a problem.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
