Old 09-15-2002, 01:34 AM   #3766
shrekair's Avatar
Trader Rating: 9 (91%+)
brianj
just ran mod saturday night and made the following changes:
shocks in hole #3 on tower f/r
low roll center f/r
camber link #3 hole in front #2 hole in rear
sway bars smallest in front, second smallest in rear.
thinking about dropping shock oil 10wt untill traction comes up for oktoberfast.
standard 42tooth diff upfront
shrekair is offline   Reply With Quote
Old 09-15-2002, 11:39 AM   #3767
Evil_S10's Avatar
Send a message via AIM to Evil_S10
hey Sigearhead, what time will the races start on the 26th? I am probably going to come, but probably to watch. I am not the best of racers, but I would just love to see some pros go at it.
Evil_S10 is offline   Reply With Quote
Old 09-15-2002, 01:08 PM   #3768
TLRacing
Todd Hodge's Avatar
Default XXX-S Setups
ongbenghui-I am going to try and get together with the webmaster this week to get some new setups on the website. Sorry this has not been updated but it has been really hectic at Team Losi.
TeamPRP-Those are some cool towers you are making! How has the lowered/raise shock holes worked out on the track?
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 09-15-2002, 02:46 PM   #3769
OBY
OBY's Avatar
from early indications i've shaved about 170g off the weight of my losi...down from 1660g to 1490! wahey!
OBY is offline   Reply With Quote
Old 09-15-2002, 03:11 PM   #3770
ttr
ttr's Avatar
Let me know the details, mine weights also about 1630g. I have already the titanium hinges and turnbuckles.
ttr is offline   Reply With Quote
Old 09-15-2002, 03:19 PM   #3771
ttr
ttr's Avatar
Default Ball bearings
My wheel hub bearings are worn out after about 60 packs and I think it was way too early, my previous HPI cars had much longer lasting bearings. I used to wash out and oil the bearings after each outing, so I think I had taken care on them as much as possible.
I plan to get the dynamite red sealed ball bearing set. Is that better quality than the stock bearings? Do I have to take out the grease and use oil in it, or do they have some light grease in them? What would you suggest?
Old 09-15-2002, 03:35 PM   #3772
LouisB's Avatar
Sweet, is that just the graphite kit or something else? I just checked and the minimum weight for TCs at my club is 1500g, but they never check so 1490g should do nicely
I found my Core 12x1 high speed a little slow in a straight line in the final, but that could be because I was racing someone with 2400's and it was at the beginning of the race when they are at their peak voltage I'm going to gear it up a little and get some Sanyo 3300HV cells when they come out I'm getting much quicker now, and would be high up in the championship if it wasn't for 2 DNFs, I'll try and get another 3rd place next race
LouisB is offline   Reply With Quote
Old 09-15-2002, 04:49 PM   #3773
rayhuang's Avatar
Default Teflon bearings
I was looking for better, more efficient bearings for the XXXS also and came-up with a set from RCBoyz, who sells a ton on e-bay. They are teflon sealed ABEC rated bearings for $29.00 plus shipping I think. GIve or take a few bucks. Thats a whole bearing kit too. I bought the one for the TC3 from them, and it was quite a good bearing set.
Old 09-15-2002, 05:15 PM   #3774
shrekair's Avatar
t.hodge and anxious losi drivers
i was out on the proto type towers saturday night and so far so good. they have rows that are a perfect match for stock then the rear has adjustments on both sided and the front has an upper camberlink row aswell. it's nice because all i had to do to change camberlink was take the nut off the back of the ball stud pull the ball stud right out and place it in the next hole and screw the nut back on with a nut driver and it takes maybe 30 seconds.
we are hoping to have production runs out w/in 2 weeks.
Old 09-15-2002, 05:18 PM   #3775
Sigearhead's Avatar
Trader Rating: 68 (100%+)
Evil_s10: Racing starts at 2pm. Come out and race, don't worry about skill level, we have all levels and besides only real race time will give you experience and improve your skills.
Sigearhead is offline   Reply With Quote
Old 09-16-2002, 08:12 AM   #3776
rayhuang's Avatar
Default Sway bar Part numbers, etc.
Actually, I am wondering if the rear and front sway bars for the XXXS are interchangeable? I dont know if they are different shape or not.
Thanks,
Ray
Old 09-16-2002, 09:00 AM   #3777
Default Re: Sway bar Part numbers, etc.
I don't think they are interchangeable,
The Length and Bend angle of the sway bars is different.
ongbenghui is offline   Reply With Quote
Old 09-16-2002, 02:08 PM   #3778
Evil_S10's Avatar
Sigearhead,
I dont think I am going to be able to just do to the fact that I broke a couple parts for the Losi the other day and since I am going to be out of money for a while (due to school) I might not be able to. This is a real bummer for me considering this might have been my first real race I have participated in. I might still try and get in it once my batteries and charger arrive. But no matter what, I am still going to go watch.
Old 09-16-2002, 04:43 PM   #3779
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
The War Report:
Well, the weekends racing has passed. And I know what must be done. Time to go shopping I attempted to work my setup so I could be able to rotate tires by using purple compounds front and rear. But it was just too much tweaking for me to get the car to handle so I am going to start over. From what people run at the track, purples in the rear and plaids or double purples upfront work great. I am leaning towards the plaids. Also, the stock setup with black springs up front seem to be the hot ticket. Anyone recommend which setup on the Losi website to try first?
I noticed that smc and promatch have very different charging recommendations for the new 3300 GPs. Anyone have experiences on what they are charging at? The packs were slammin during the race. Really a lot of punch
I am going to tear down my car as well and rebuild her, clean her up good. What do you recommend as far as bearing and diff cleaning / rebuilding?
Finally, I run a chameleon 2 motor, what brushes will work well? I am buying a new arm for it when I order my tires.
Later,
Cain
Old 09-16-2002, 05:12 PM   #3780
Fire's Avatar
i guess if you just ran on carpet all you need to do is to pull out all the "hair" get stuck on the bearing shields, maybe add a drop or 2 bearing oil. i use trinity's
great to hear that the GP 3300 works
i guess for settings just run the stock setting with the tires you choose, then start from there. should be able to reach a set up that you feel comfortable with
Fire is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
