Old 09-10-2001, 05:58 PM   #361
Originally posted by YokGuy
Wolverine,
About your post...
"I ran the xxx-s in a race today........ it was slow even geared the same as my TC3........... "
Did you gear it with the same in pinion or ratio. If you just move the motor over with the same pinion you used on the TC3 you're over geared for the XXX-S, wrong FDR. Gear it 2 tooth down from TC3 and you'll be fine. If you're running the same FDR then it could be a weight issue between the two chassis.
I ran it with the same gear ratio.............
and it was slow... slow...... slow compared to my TC3..........
My TC3 is bone stock........ it is a racer version......
the cheap one with none of the cool hop up parts...
My XXX-s is all so bone stock.......
Wolverine is offline   Reply With Quote
Old 09-10-2001, 06:01 PM   #362
Originally posted by mr. losi
street wheels....what do you want?????nice illegal.motor....no wonder why you would winn....
He wants you to talk to him...........
Old 09-10-2001, 07:28 PM   #363
Trader Rating: 19 (100%+)
This should spark some conversation.....
MDawson is offline   Reply With Quote
Old 09-10-2001, 07:40 PM   #364
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
haha... Yeah, I almost took a couple pictures of it as a joke, but i had to save space on the digicam for other images. It is just there to show off the belt system.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 09-10-2001, 08:49 PM   #365
Administrator
Matt M.'s Avatar
Trader Rating: 25 (100%+)
actually it is the new stealth car...it is so clear so your competition does not see you.......there for you win...
Matt M. is offline   Reply With Quote
Old 09-10-2001, 09:43 PM   #366
Jared Kirkwood's Avatar
Send a message via AIM to Jared Kirkwood
You could use OFNA's clear wheels with that. Then maybe just white silicone tires, a clear body. You could be the ghost car! HEHE. Just joking.
Jared Kirkwood is offline   Reply With Quote
Old 09-10-2001, 09:54 PM   #367
The stealth idea has some possibilities.
Note to self. I must be really bored, would Saturday please come soon so I can run my car!!!!
Old 09-10-2001, 11:34 PM   #368
Send a message via AIM to ProRacer03
Hey fellows, I ran my losi today and it seems to be really really noisy. I have this annoying clicking noise coming out of it also. I am missing 2 balls in the differential could this be the problem? The clicking noise only occurs when throttle is first given. It seems like the belt is skipping but I don't know what could be causing this. It's really loud and skips. What kind of information do i need to know to troubleshoot this problem. Thanks for any help.
ProRacer03 is offline   Reply With Quote
Old 09-11-2001, 06:33 AM   #369
Administrator
Matt M.'s Avatar
tighten the belt....
Old 09-11-2001, 07:13 AM   #370
HarshGuy's Avatar
Has anyone had problems with the aluminum CVD's tearing the little pin out of the dogbone? This has happened to 2 different people at my track (me being one of them). I don't think I hit anything at least I don't remember hitting a board or car and if I did it was so monir as to not be memorable.
now the "funny" part of the story...I could tell this happaned early on in my qualifier as the car started to handle like crap and one wheel was "break dancing" when I turned right ...hehe I still ran 2nd in that qualifier, with a 3 wheel drive car!!
HarshGuy is offline   Reply With Quote
Old 09-11-2001, 07:15 AM   #371
Bobby Z's Avatar
Hey guys
I have a handling problem with my car that maybe one of you can help me out with. The car is handling great except for high speed entry into corners. The car tends to wash out at the apex of the corner and slides through the corner. Any suggestions on what would fix this?
Bob
Bobby Z is offline   Reply With Quote
Old 09-11-2001, 07:28 AM   #372
Trader Rating: 82 (100%+)
I would suggest trying different tires on the car before you get to caught up in the "perfect set-up" game. Ask the people that you race with and see what they have had good luck with and then go from there.
What surface are you running on?
dan-o is offline   Reply With Quote
Old 09-11-2001, 09:10 AM   #373
Harshguy, I had this problem even with the steel ones what I found was that tc3 caster blocks (if that is what your using) need to have a stop made, the inside wheel of the direction of the turn will flop about 3/8 " and open the cv to a critical angel. I used a 4/40 set screw in the spindle where it comes to rest against the caster block, the great thing is u can ajust it. Hope this helps.
Oh and the car still runs 3 wheel quite well don't u think? The car is just awsome!!!!!!!!!!!!!!
rcspeed is offline   Reply With Quote
Old 09-11-2001, 10:01 AM   #374
If you do run the AE castor blocks, be aware that they are narrower and will create more throw in the steering. That extra throw may create problems for you in the cvds.
Old 09-11-2001, 02:00 PM   #375
I tightened the belt but that did not help. The clicking is still there. Is there any other possible reason this would happen?
How many of you guys use the 41 tooth diff in the rear?
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
