Old 08-27-2002, 01:39 PM   #3586
Trader Rating: 71 (100%+)
Correction. A bunch of us run it here
RBLove is offline   Reply With Quote
Old 08-27-2002, 01:53 PM   #3587
SpeedTech's Avatar
Hi Guys,
We got more Titanium Racing screw kits in for the XXX-S, available now.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 08-27-2002, 02:18 PM   #3588
Evil_S10's Avatar
Send a message via AIM to Evil_S10
got a quick question for you guys, I just bought the threaded shock bodies, will I need the shorter shock shafts as well?
Evil_S10 is offline   Reply With Quote
Old 08-27-2002, 02:36 PM   #3589
RB/Chad - I found that I had to back out the eyelet a little if I used
the 0 deg front kickup. The prob may be worse with LRC and
0 deg kickup?
rainblows is offline   Reply With Quote
Old 08-27-2002, 03:04 PM   #3590
Evil_S10-I my opinion you should run the std .36 shocks in the rear(both shafts and bodies), and run the short .28 in the front. For the fronts the cheapest way to get this is to buy the A-5081 .28 set.
Chad
ChadK is offline   Reply With Quote
Old 08-27-2002, 03:37 PM   #3591
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I attempted to install both the short .28 shafts, and short .28 shock bodies in the front after converting to the LRC, but could not get anything lower than about 6-8 for droop. ( i forget which, but it was pretty rediculous. )
I fixed the problem by going back to the .36 bodies, with the .28 shafts.
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 08-27-2002, 04:20 PM   #3592
That is strange, like I said I have no issues with the .28 shocks and 4 or 5 other people I know do not have problems.
Old 08-27-2002, 05:35 PM   #3593
RCTech Member #2
TSR6's Avatar
Yeah, the shocks were definately bottoming out. I removed the droop screws, and i was about to whittle away more of the bumper, and then i noticed that nothing was really touching, i removed the shocks... and whammo... the arms droped like bricks.
I put the .36 bodies back on, and had no problems.
What are those 4-5 other people running for droop? ...hehe..
-Troy
Troy
RCTech Member #2
Old 08-27-2002, 07:31 PM   #3594
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
You guys must be running rubber tires-
With 2.25" foams and .28 bodies, to get down to 3 or less on the droop guage, you a have to unthread the ends a about .100" over half the threads. I run .36 bodies with .28 shafts. When I run rubber tires i just cut half the shock end off to get uptravel....just like we all did when the car first came out and there were no .28 shocks.
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 08-27-2002, 07:43 PM   #3595
STLNLST's Avatar
Trader Rating: 19 (100%+)
Even with rubber tire's I can get the droop where I want it with the LRC blocks on. I have the short shock bodies and shafts on my car.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 08-27-2002, 08:46 PM   #3596
007yoshi's Avatar
Is the LRC that necessary?!?!?!??!!
007yoshi is offline   Reply With Quote
Old 08-27-2002, 08:59 PM   #3597
Pembalap's Avatar
Unhappy Roll Center
I still have problems understanding roll center, is there any literature that I can read regarding this topic?
Most people at my track run Tamiya 414M2, and all of them are using HRC.
I myself converted to LRC after reading the posts in RCtech
Pembalap is offline   Reply With Quote
Old 08-27-2002, 10:27 PM   #3598
hey guys, i just got a XXXS. Pretty hopped up with graphite conversion and and all MF hopups.
Right now i have a Yellow Spur Gear in the car i also have the red one and orange one. Does anyone know if this is Stock Spur? Its a Bright Yellow kinda looks greenish but when i look in the magazines the Stock spur is Bright green limish.
Does anyone know a good gearing to run for this Yellow Spur? I believe its 48pitch. Im mainly looking for Top end and top acceleration.
thanks
Got Rice? is offline   Reply With Quote
Old 08-27-2002, 11:40 PM   #3599
the yellow one is stock. I would go out and get a 128 blue spur gear 64p, why you ask I think its why better for helping you out in the gearing department. I would start out with 128/39 gear down form there do not go up more then one tooth
teamAE is offline   Reply With Quote
Old 08-28-2002, 04:09 AM   #3600
Sigearhead's Avatar
Trader Rating: 68 (100%+)
GotRice?
The Spur gear you have (the flourescent yellow one) is the stock spur which you were correct in stating it's 48 pitch and it's 88 tooth. The Orange spur is the 90 tooth, and the red one is the 86 tooth. With a stock motor and the 88 tooth spur you can start out with a 26 pinion and go up if you need more top speed or down one if you need more acceleration.
I have never had problems with ride height and low roll center, neither has anyone else I know so I can't offer any help on this matter. I use the short bodies and short shafts up front with no problems.
Pembalap: Low rollcenter allows the car to rotate the middle of the turn much harder allowing you to hold your line through turns much tighter, thus increasing corner speed.
Sigearhead is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
