Old 08-23-2002, 12:00 PM   #3556
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Louis, yes I can. I just need to know what you were thinking of ordering so I calculate shipping. Send me a pm or an email at [email protected]
I agree with shrekair.
If you want to keep your motor cool then get some of those bags that you can freeze and put it them in the freezer with a motor can so that it will freeze into that shape. Then just take it to the track with you in a cooller. Did that make sense?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 08-23-2002, 12:36 PM   #3557
LouisB's Avatar
Thanks Kraig, I haven't thought of a list yet, but when I do I'll e-mail you
LouisB is offline   Reply With Quote
Old 08-23-2002, 03:06 PM   #3558
OBY
OBY's Avatar
sorry..i was fifth! my mistake!
Round 7 Scottish RRCi Championship
thats the only results i can find published, there should (eventually) be one with car, speedo, cells, motor etc...
missed fourth by a quarter of a second!
note:
1: sponsered by modeltec and rc labs, corally etc.
2: sponsered by hpi, HB, nosram, orion...
3: sponsered by losi and trinity...
4: sponsered by modeltec and rc labs, corally etc.
5 (Me): sponsered by my old bloody back pocket!!! (companies take note!)
OBY is offline   Reply With Quote
Old 08-23-2002, 04:02 PM   #3559
LouisB's Avatar
Can u do the same thing in the dry? If you did i'd think you'd get sponsorship for sure
Does the width of the XXX-S go above 190mm when using TC3 hexes and 26mm wheels?
Old 08-23-2002, 04:03 PM   #3560
Good job
Havew you looked into the smaller companys to run for them? They should be willing to do something like that.
Good Luck
teamAE is offline   Reply With Quote
Old 08-23-2002, 04:05 PM   #3561
OBY are you running a xxx-s?
Old 08-23-2002, 04:09 PM   #3562
LouisB's Avatar
teamAE, OBY runs a XXX-S, his wet set-up is a couple of pages back.
Old 08-23-2002, 07:51 PM   #3563
I found a really nice setup for high bite ashpult if you would like to give it a try
I use the stock setup except for:
Works for mod and stock.
#2 on shocks front and rear
out on rear
50wt in front
40wt in rear
red pistion
#3 and b camber link for rear
and blue spring rear
green front
Also used a one way
stock setup everthing else
Its mostly the springs I feel made a diffrence
try and give some feed back if you like.
Old 08-24-2002, 01:45 AM   #3564
shrekair's Avatar
Trader Rating: 9 (91%+)
Default 55446
what do you think of those motor socks? the yellow ones with holes in them, u can leave the dry or ever make the damp.
shrekair is offline   Reply With Quote
Old 08-24-2002, 09:45 AM   #3565
motor socks?
Old 08-24-2002, 11:14 AM   #3566
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
aka dypers.
I accually have a set that i won as a door prize type thing. I had it on a motor to try in practice, but ended up switching motors.
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 08-24-2002, 04:34 PM   #3567
Evil_S10's Avatar
Send a message via AIM to Evil_S10
I was going to get the graphite conversion kit, but I finally realized that I probably wont use most of the parts. I have 0,2,4,and 6 degree front spindles and carriers 0,1/2, and 1 degree rear hubs, and graphite a-arms all around. But when you buy the graphite conversion kit, you dont get the higher degree hubs and spindles/carriers. Just my 2 cents.
Evil_S10 is offline   Reply With Quote
Old 08-24-2002, 05:58 PM   #3568
RCTech Member #2
TSR6's Avatar
Always can use spare parts. Just my 2 cents.
Troy
RCTech Member #2
Old 08-25-2002, 12:16 PM   #3569
OBY
OBY's Avatar
Originally posted by teamAE
Good job
Good Luck
i got offered an xray/peak drive a year or two ago but turned it down cos it wasnt a full drive and meant new car, motors, cells, speedo...etc etc, wheras i could have raced my pro2 at the time with only new cells and motors.
i'm not fussed about sponsership, i dont spend too much on the car and love beating sponsered drivers, makes it much more enjoyable!!!
Old 08-25-2002, 04:05 PM   #3570
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
well guys, here is the latest war report:
Heat 1#
Placed first but pack felt alittle flat towards the end. I don't know about these peak performance Maxx Packs (we can only run unmatched stick packs at our track). Everyone else though had plenty of run time left and I was UNDERGEARED!!!! Check out my other thread if you can help.
Heat 2#
Placed second this time. went up one pinion tooth and she ran great. The fast guy was UNBELIEVABLY FAST. He was running foams and matched 2400s (owner not too happy about that) and a stock motor (we run Chameleons) and he was gone. It was nice however to see that XXX-S Go! Bone stock.
Main #
Placed 3 overall. F***ing pack dumped on me with about 1 minute to go. It was flat for about 2 more minutes. Everyone else of course was still messing around afterwards for about 6 minutes
All in all not a bad race day. But I need to do something about my packs and look into setting my Cyclone Purple edition to something other than the drag racing brake setting (I like the drag brake though ) I am thinking of running foams, our track is really rough but the fast guys were tearing it up with those foams, my slicks seem to let the rear drift alittle too much compared to the "foam" guys.
So, here is what advise I need. I am planning on skipping next week racing a tearing town my car to tune it up. What are some of the things I should look into doing to make the car smoother? (I don't want to say faster because I know the response, drive better, but I drive a great line already, just dump too quick). I am considering rebuilding the diffs, any recommendations on what to use to rebuild them, and the CVDs. Also, may get the following:
1) Graphite Chassis
2) titanium turnbuckles
3) titanium hingepins
4) Graphite shock towers (speed tech models probably any installation issues?)
5) Speed tech steering bellcranks
6) RPM ball cups
Finally, how have you guys removed all the slop in the steering? mine feels sloppy. I have the shim and slop removal kit for my street weapon that I never used, so I got bunches of shims, washers, etc. Other than that I think I should be set.
My equipment:
1) MRC 959 Superbrain charger
2) XR3 FM Radio
3) Novak Cyclone Purple Edition (not C2)
4) Chameleon 2 motor
5) Hitec MG925 servo (that very fast one, i think thats it)
6) 2400s Peak performance Maxx packs
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
