Old 08-20-2002, 01:51 PM   #3526
RBLove's Avatar
Trader Rating: 72 (100%+)
Shrekair, I need some confirmation on roll center. When running the arms lower to the chassis is? And vice versa?
I have been running the car pretty soft on carpet with foams. I also run the arms lowered front and rear. A lot of us here in Ohio have experimented with springs and we are finding that a softer spring frees up the car some in the corners. I ran Losi purple up front and Losi blue in the rear with thick sway bars all the way around the car was just awesome.
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, BSR Racing Tires
RBLove is offline   Reply With Quote
Old 08-20-2002, 02:28 PM   #3527
shrekair's Avatar
Trader Rating: 9 (91%+)
LRC is with the arms closer to the chassis, however, the chassis will roll more.
i always run w/o sway bars, thats why my springs are heavier. maybe i need to invest in some HQ (high quality) sway bars? i like running heavier springs and laying the shocks down more on average. some guys like softer springs? i'm more consistant with "heavier" setup.
shrekair is offline   Reply With Quote
Old 08-20-2002, 02:35 PM   #3528
HRC vs LCR changes the roll characteristics of the car, so it is vevy driver and setup dependent. You could have 1 person running HRC and another running LRC with the same lap times. It's something you have to play with. Currently I am running mid-roll center up front and LRC in the rear on carpet with rubber tires and like it the best.
Chad
ChadK is offline   Reply With Quote
Old 08-20-2002, 02:39 PM   #3529
Thanks for the quick responses. I appreciate the help.
racerdave
racerdave is offline   Reply With Quote
Old 08-21-2002, 11:25 AM   #3530
RBLove's Avatar
Shrekair, Thanks. That is what I call LRC as well. Seems that everyone has a different view of LRC and HRC. I might look to you for some set up tips for the first USTC race. I am sure you will have your car dialed in (home track).
Take care,
Rob Love
Old 08-21-2002, 02:17 PM   #3531
OBY
OBY's Avatar
*tempts you all by saying he's getting a titanium bottom chassis plate...*
OBY is offline   Reply With Quote
Old 08-21-2002, 02:29 PM   #3532
OBY
OBY's Avatar
oh aye i forgot to ask...
the rear hubs are 0degree right?
the rear bar thing sets the toe in?
but i have been told the bars arent too accurate, is this true? i was told aluminium ones would cure it.
Old 08-21-2002, 04:11 PM   #3533
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
how much slop is removed when using aluminum steering bellcranks?
Old 08-21-2002, 09:11 PM   #3534
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
stock, the XXX-S has 4 degrees of toe. The stock rear hubs niether add, no decrease toe.
1 degree hubs, put on to thier labeled sides ( left hub on the left side, right hub on the right side ) will add 2*toe ( one* per side ) to the 4 total
Putting 1 degree hubs on backwards ( left on the right, right on the left ) will remove 2*toe ( one* per side ) from the 4 total.
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 08-21-2002, 09:16 PM   #3535
Trader Rating: 23 (100%+)
2 degrees per side is stock.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 08-21-2002, 09:28 PM   #3536
RCTech Member #2
TSR6's Avatar
I guess i should have clarified... 4* total...not per side.
Troy
RCTech Member #2
Old 08-21-2002, 11:55 PM   #3537
shrekair's Avatar
graphite bell cranks are the best, the aluminum can bend where as graphite will snap although i havent had one snap yet. aluminum is only good for knuckles, steering brace, and LRC blocks on the losi *in my opnion*
rob - i'm thinking congo blue front springs and losi black's in the rear and sway bars
Old 08-21-2002, 11:59 PM   #3538
Fire's Avatar
i would like to get the alloy LRC block, but i haven't seen any around here
Fire is offline   Reply With Quote
Old 08-22-2002, 12:06 AM   #3539
RCTech Member #2
TSR6's Avatar
who makes them? Losi? I have not seen, or heard of them before.
As far as i knew, it was Losi Stock, Trinity, Speedtech, Dynamite, or some english company blue. ones
ill end this now before i lose power again... screen blipping
Troy
RCTech Member #2
Old 08-22-2002, 05:54 AM   #3540
STLNLST's Avatar
Trader Rating: 21 (100%+)
I woulr rather break a graphite piece and replace it rather than bend the aluminum piece that stays bent and can change the way the car handles. Especially aluminum knuckles. This is just my opinion.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
