Old 08-19-2002, 05:19 PM   #3511
Send a message via AIM to LosiXXXSRacer
Hey guys i have a xxx-s on teh way and just wondering if there are any tips yall can help me with. I am drag racing when i get it (sunday). And after that ill be racing other places.....touring asphalt, maybe a lil oval (for fun), and carpet.
So any tips i would love.
THANKS
Michael
LosiXXXSRacer is offline   Reply With Quote
Old 08-19-2002, 07:00 PM   #3512
thanks Sydewynder,
I agree on the tensioner pulley washer issue...I dropped the washer as well....doesn't really need it.
My issue was less one of rubbing (like proudwinner, I have run my 118 spur anyway, even with the runout issue) and more one of quality control at Losi...3 spurs purchased - 3 spurs with problems. Maybe they need to retool their molds for their spur gears
I've been running the MF gear adapter with kawada spurs, and they work fine. I did notice this week that my belt got a bit slack at the end of the day...not sure if it was the pulley, or a loose screw on the tensioner...
Cheers,
Rich
boykster is offline   Reply With Quote
Old 08-19-2002, 07:54 PM   #3513
I have not had any problems with my spurs. I did have a problem with the MF adaptor something rubbing. I do think losi is coming out with new spur gears. I saw bk testing some also some new belts
teamAE is offline   Reply With Quote
Old 08-19-2002, 08:20 PM   #3514
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
They have been working on a "yellow" belt, which i am told will be aimed more twards stock racers.
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 08-19-2002, 09:23 PM   #3515
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
has anyone else had this problem with the tensioner??
I believe that the white plastic piece gets a little loose on the bearing which causes the white piece to shift around during a race. This happened to me over the weekend and caused my belt to eat itself getting caught between the tensioner and the spur. I check the screws on both the tensioner ....one that holds the bearing on....and the screw that holds the tensioner in place and they were both tight.
Just curious if anyone else has had this happen and if so what did you do to fix it?
BHenderson is offline   Reply With Quote
Old 08-19-2002, 11:40 PM   #3516
TeamPRP's Avatar
Default Shock towers
A quick update, rear shock tower design is coming along quite nicely- it will make the back of the car very adjustable Hoping to have some in racers hands within 3 weeks. If they prove themselves on the track, we'll have our first batch done before OktoberFAST(the first race in the USTC series, the first weekend of october)
I have a question- Do you have something that you'd really like in the front tower, please let me know. Feel free to email me at, teamprp@attbi.com
Thanks guys!
Ben, Team PRP
TeamPRP is offline   Reply With Quote
Old 08-19-2002, 11:57 PM   #3517
Fire's Avatar
how about some camber holes at different height?
Fire is offline   Reply With Quote
Old 08-20-2002, 07:43 AM   #3518
ChadK,
What roll center setting are you running with the setup you posted on the previous page?
Dave
racerdave is offline   Reply With Quote
Old 08-20-2002, 07:58 AM   #3519
shrekair's Avatar
Trader Rating: 9 (91%+)
ben,
for the front i'm thinking doubles. there isint as much room up there
shrekair is offline   Reply With Quote
Old 08-20-2002, 09:25 AM   #3520
racerdave-That was high roll center both front and rear. On asphalt I have always liked high roll center.
Chad
ChadK is offline   Reply With Quote
Old 08-20-2002, 11:28 AM   #3521
Evil_S10's Avatar
Send a message via AIM to Evil_S10
yeah, some different camber holes will help a lot of us out. And one question, how much will you guys be selling the rear and front shock towers?
Evil_S10 is offline   Reply With Quote
Old 08-20-2002, 11:39 AM   #3522
shrekair's Avatar
Old 08-20-2002, 12:26 PM   #3523
Chad or anyone,
How do you know when to change to a low roll center?
All else being equal, how do the two settings differ, how do they feel? I know that this probably covered a few hundreded pages back, but I am lazy!
Thank you.
Old 08-20-2002, 12:35 PM   #3524
shrekair you have a pm
racerdave- for roll center I found running low in the rear only makes your laps a little fast. I have run this for a while and never change it. If you want to change it raising the front in relation to the rear will gove more mid coner steering and exit and vise versa when lowering the front.
Old 08-20-2002, 12:41 PM   #3525
shrekair's Avatar
blanket statement but isint always true as any statement.
HRC (high roll center) more turn in
LRC (low roll center) more steering from apex off.
low roll center softens the suspension, so to achieve the same handeling, stiffen your springs one step f/r.
if u break it down to "how does just front HRC affect the car vs. LRC?" it's still the same. high roll center in the front only will still be more turn in, less turn off. and same with the rear. higher is more turn in and less turn off. i was thinking about this myself and thats exactly how is worked in my car.
THE BIG shrekair
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
