Old 08-15-2002, 03:53 PM   #3451
Core Creations's Avatar
Trader Rating: 93 (100%+)
Send a message via AIM to Core Creations
I would use more droop. Maybe go to a 2 or 4 degree castor block and maybe some antidive and kickup. Heres my bumpy track setup:
Front
40wt
-1.0 camber
blue or green spring
stock pistons
#2 shock tower
#2 camber link
2f front kickup
3mm droop
Rear
40wt
-1.0 camber
silver spring
#4 rear antidive
stock pistons
#2 shock tower
#1 camber link
outside hole on arm
B hole on hub
Middle chassis length
Batteries forward
Take off 27-32 with atock insert.......this is a setup for stock and works well on a large bumpy track. If u want a quicker reaction for a smaller track got to #3 or #4 on the front shock tower
Core Creations is offline   Reply With Quote
Old 08-15-2002, 09:27 PM   #3452
Trader Rating: 69 (100%+)
where can I buy a one-way for my XXX-S?
Thanks.
Markus is offline   Reply With Quote
Old 08-15-2002, 09:40 PM   #3453
WARNING TO ALL DO NOT DO ANY TRADES WITH LITO R (MTX2) HE HAS BEEN KICKED OF OF RCRACING.COM FOR BAD TRADES ON AT LEAST TWO GUYS!! HE IS A LIER AND SHOULD NOT BEEN TRUSTED BY ANYONE STLNLST WHOM MOST OF YOU KNOW WILL TESTIFY ON THIS ONE!! FOR YOUR OWN GOOD STAY AWAY FROM HIM AT ALL COST!!!!!!!!!!!!
bigdog is offline   Reply With Quote
Old 08-15-2002, 10:30 PM   #3454
One ways at any hobby shop that has XXX-s stuff
teamAE is offline   Reply With Quote
Old 08-15-2002, 10:49 PM   #3455
Send a message via AIM to ZER01
Thanks.
KT Hobbies has a good price on them.
KT Hobbies.COM
ZER01 is offline   Reply With Quote
Old 08-15-2002, 10:52 PM   #3456
Thanks, I'll check them out.
Old 08-15-2002, 11:22 PM   #3457
Fire's Avatar
so the low roll center pivot block is shorter than the orginal one?
Fire is offline   Reply With Quote
Old 08-16-2002, 03:24 AM   #3458
Trader Rating: 62 (100%+)
does a locked front diff have the same characteristics as a front one-way? im using the xxx-s in a large track with sweeping turns. i barely use brakes and i think a one-way might give me more steering and faster corner speed. but the one-way is a bit expensive and i was wondering if i can get the same advantage with a locked front diff. thanks for any info
marvi is offline   Reply With Quote
Old 08-16-2002, 06:30 AM   #3459
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Fire, that is correct. If you use the low roll center, you will have to shave down some of the chassis to get the front and rear arms to have the full range of motion for the suspension.
We should have one-ways back in stock by Monday.
Kraig O'Brien
KT Hobbies
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 08-16-2002, 06:54 AM   #3460
NO! A locked front diff is a locked front diff. The purpose of a oneway is to have the wheels "freespin" while you're "off-power".
Old 08-16-2002, 07:12 AM   #3461
shrekair's Avatar
Trader Rating: 9 (91%+)
it's worth the $40
shrekair is offline   Reply With Quote
Old 08-16-2002, 11:58 AM   #3462
LouisB's Avatar
What winds and gearing do u guys run on parking-lot tracks, do u gear up or down from the manual? The tracks I run on are a similar size to the Hitec challenge track
LouisB is offline   Reply With Quote
Old 08-16-2002, 12:10 PM   #3463
shrekair's Avatar
how long is the straightaway? is it technical ot not? every wind, turn motor is different for gearing, like a 10x2 p-94 and a 10x2 ti are geared much different, TI's ahve power lower in their power band, trinity mods have power higher up in the power band
Old 08-16-2002, 12:27 PM   #3464
LouisB's Avatar
We have different track layouts and venues every week, it's normally very technical and there are a couple of short straights. I run orion motors, between 11 and 12, single to triple.
Old 08-16-2002, 12:44 PM   #3465
shrekair's Avatar
11 triple - 12 single is a pretty big gap. try a 8.5 to 9.0 final drive.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
