Old 08-07-2002, 02:34 PM   #3376
LouisB's Avatar
Default rubber on carpet
Glenn Doman, rubber on carpet with T27 treaded tyres.
Tight carpet track
Front
toe in/out: Pparallel
Ride height: 4.5mm
camber: -1 degree
kick up: -1 degree
caster: 2 degrees
roll bar: None
arm spacing: forward
one way differential
pivot blocks: lowered 1.4mm
camber link: pos. 3
Front Shocks
oil: 80wt
piston: 56 (red)
spring: green
length: 61mm
pos. : mount position 2
Rear
toe in: 2.5 deg.
ride height: 5mm
camber: 0.5 deg.
roll bar: none
pivot blocks: matt francis
pivot support: 0R
inner camber link: pos. 2
outside camber link: pos. A
Rear Shocks
oil: 70wt
piston: 55 (orange)
spring: green
length: 65.5mm
mounting position : pos. 1
wishbone pos: outside
Notes:
Tyres: T27
Insert: trick bits green
Battery: forward
Motor: P94 12x2
pinion: 30
Spur: 118
Bodyshell: Stratusphear
Bodyshell height: 120mm
LouisB is offline   Reply With Quote
Old 08-07-2002, 02:43 PM   #3377
LouisB's Avatar
Must be cold, it always (normally) is in England The tire choice for that race was open so he probably went for max grip, but still probably the right tire for the temperature
After looking at the pics, there are a couple of mistakes on the set-up sheets (not me) the foam on carpet should have a fat front roll bar and the asphalt set-up should have purple front springs
I might try both front and rear arms spaced forwards for the next race, haven't tried that combo.
Old 08-07-2002, 02:58 PM   #3378
Send a message via AIM to ZER01
Cool Louis, thanks for the corrections on the springs
ZER01 is offline   Reply With Quote
Old 08-07-2002, 03:10 PM   #3379
LouisB's Avatar
no probs
The Magazine is RC car Racer and has loads of XXX-S stuff in it, probably because David Spashett writes some articles for it. He wrote an article on one-ways, radio programming and they had last years euro set-up
Old 08-07-2002, 04:47 PM   #3380
Hi all,
Has anybody experimented with adding washers under the front spindle ball stud? If so, what effect did this give?
Another thing, many people (not only here, but magazine articles etc) talk about increasing rotation in the rear of the car during cornering to gain 'cornering speed'. How is this different from oversteer, or is there just a very fine line between the two?
nzxxxs is offline   Reply With Quote
Old 08-07-2002, 04:53 PM   #3381
I think its the pictures that dont corispond with the setups as i race at macclesfield regually and there is no way you cud run a one way around the track no matter what the car is. Go by the setup and not the pictures. Rick
Rick Draper is offline   Reply With Quote
Old 08-07-2002, 05:29 PM   #3382
Fire's Avatar
i think to make the rear rotate is to make the rear follow the front end when turning instead of the front turns and the rear keep pushing straight forward. Oversteer occurs when the rear doesn't have enough traction and spin out or get out of shape~
Fire is offline   Reply With Quote
Old 08-08-2002, 01:48 AM   #3383
ttr
ttr's Avatar
Default Re: Roll center
Looks like roll center settings are confusing, some seem to think about it as center of gravity.
Losi is right with the Low and High names.
"High" is the standard set-up what you get in the car. High roll center gives less chassis roll.
"Low" is the modificated setting (you cut 3mm off the inner blocks). Low roll center gives more chassis roll.
If more or less chassis roll is better is up to you and the track conditions.
To make the theory more clear you may want to read one of the best free set-up book on the net: http://home.tiscali.be/heremanss/c2/index.htm
ttr is offline   Reply With Quote
Old 08-08-2002, 02:15 AM   #3384
TTR, Your definately right about Losi being right and like I've been saying, the lower the hinge pin is to the chassis the more roll that end of the car will have-
Old 08-08-2002, 02:23 AM   #3385
LouisB's Avatar
I think you're right Rick, they probably just brought along the set-up sheets and whatever setup they had on their cars, but Andy Moore's foam on carpet set-up for the Macclesfield track is run with a front diff
Old 08-08-2002, 02:31 AM   #3386
Default RC Racer UK
Hi,
I can't get RC Racer UK in Singapore here, and wonder if anyone could post the setup and maybe the articles on XXX-S online ?
ongbenghui is offline   Reply With Quote
Old 08-08-2002, 03:04 AM   #3387
LouisB's Avatar
You may be able to subscribe to it by going to the website Racer
What set-up do you want? I posted all of the new ones
Old 08-08-2002, 09:04 AM   #3388
Fire's Avatar
oh man
it's consfunsing now
so adjusting the camber rod length can get the same result as adjusting the pivot blocks' height?
also how come low roll center kits tamiya and hpi made both put spacers between the chassis and the hinge pins??
Old 08-08-2002, 10:04 AM   #3389
Fire, Yes! Camber link angles will alter the roll centers of that end of the car also. The higher the inner pivot point of the camber link, the more roll it will have for that end of the car. The lower the inner pivot point of the camber link, the less roll it will have for that end of the car. You can also raise the outer part of the links(hubs) and that will decrease chassis roll also.
Old 08-08-2002, 10:05 AM   #3390
shrekair's Avatar
Trader Rating: 9 (91%+)
ask them??
low roll center squares up the arm with the camber link. by doing so the chassis will roll more to reach the same compression point as regular roll center. if you put a set of tires on the car and set it on a table and compress it untill the LR corner of the chassis touches the table, then put low roll center in and do the same test, the a-arm will have a greater agle to it w/ the low roll center then w/ the regular roll center. then u can apply this dynamically to see how the car will respond differently through the corner. by increasing roll (LRC) u gain more steerign out of the corner because it soften the suspension slightly, and w/ HRC the car will turn in harder but you will have less steering off. did i manage to confuse you? test it for yourself on ur kitchen table.
shrekair is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
