Old 08-07-2002, 12:15 PM   #3361
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
LouisB :: I thought the opposite about lowering the hinge pin.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 08-07-2002, 12:38 PM   #3362
shrekair's Avatar
Trader Rating: 9 (91%+)
louis B
LIST THEM PLEASE
shrekair is offline   Reply With Quote
Old 08-07-2002, 01:18 PM   #3363
rayhuang's Avatar
Default Roll center
I've taken 3mm off the front and rear pivot blocks to lower the roll-center. I haven't driven the car yet but what handling differences should I expect?
When you do this you have actually raised the roll center, but Losi calls Low Roll Center when you lower the bottom hingepins-which is wrong.
Old 08-07-2002, 01:19 PM   #3364
LouisB's Avatar
shrekair
Which ones do you want? the carpet+rubber is with T27s (treaded)
LouisB is offline   Reply With Quote
Old 08-07-2002, 01:25 PM   #3365
LouisB's Avatar
OK now I think about it, it does raise the center of rotation
but still, what will it do to my car (or will I have to wait until my sunday race)
Old 08-07-2002, 01:30 PM   #3366
Send a message via AIM to ZER01
The lower the plates are to the chassis the more roll that end of the car will have.
ZER01 is offline   Reply With Quote
Old 08-07-2002, 01:33 PM   #3367
shrekair's Avatar
just list all three setups
Old 08-07-2002, 01:35 PM   #3368
shrekair's Avatar
moving the hingepins closer to the chassis lowers roll center. in general lower roll center is more steering off the corner, higher roll center is more steering into the corner.
Old 08-07-2002, 01:46 PM   #3369
Fire's Avatar
isn't it the other way around?
by rising the hinge pins away from the chassis you can still have the same ride height but the suspension not as compressed as before so the suspension works better?
Fire is offline   Reply With Quote
Old 08-07-2002, 01:51 PM   #3370
LouisB's Avatar
Default Carpet + Foam
Andy Moore's foam on carpet set-up
Open track
Front
toe in: 0.5 degrees
Ride height: 4.5mm
camber: -1 left -0.5 right
caster: 4 degrees
roll bar: None
droop height: 3
arm spacing: forward
front differential
pivot blocks: lowered 3mm
camber link: pos. 3
washers under spindle: 1.5mm
Front Shocks
oil: 70wt
piston: 57 (black)
spring: black
length: 61mm
pos. : mount position 3
Rear
toe in: 2 deg.
ride height; 5mm
camber: -1 right -1.5 left
roll bar: none
droop height: 5
arm spacing: back
inner camber link: pos. 2
outside camber link: pos. B w/ 1mm washer
Rear Shocks
oil: 50wt
piston: 56 (red)
spring: black
length: 65.8mm
mounting position : pos. 3
wishbone pos: outside
Notes:
Front tyre: TRC Plaid
Rear tyre: TRC Purple
front additive: up to join
Rear additive: full
Tyre diameter: 59mm
Battery: forward
Motor: P94 12x2
pinion: 30
Spur: 108
Bodyshell: P.form Stratus
Bodyshell height: as low as possible
That took a long time
Old 08-07-2002, 01:54 PM   #3371
shrekair's Avatar
works better? raising the pins raises roll center it doesnt affect compression in that way
Old 08-07-2002, 02:24 PM   #3372
Also, if anyone is interested, a UK mag has printed up the set-ups of three of the Losi team drivers. One is foam on carpet, one is rubber on carpet and the other is rubber on asphalt. If anyone would like me to put them up here just ask
They are all race winning set-ups
Hey Louis, the lower the hinge pins are to the chassis the more roll that end of the car will have. As you go up(pivot blocks), roll is decreased. It's just like camber links, the higher the inside pivot point of a camber link(usaually on the shock tower) will give that end more roll-visaversa for lower camber links.
Louis, could you please post the rubber on asphalt setup. I'm dying to see something new. Thanks-Ralph
Old 08-07-2002, 02:25 PM   #3373
LouisB's Avatar
Default rubber on asphalt
Westley Payne's set-up
open track
Front
toe out: 0.5 degrees
Ride height: 5mm
camber: -1 degree
caster: 4 degrees
roll bar: None
droop height: 3
one way differential
camber link: pos. 3
Front Shocks
oil: 50wt
piston: 57 (black)
spring: blue
length: 61mm
Rear
toe in: 2 deg.
ride height; 5.5mm
camber: -0.5 degrees
roll bar: none
droop height: 5
arm spacing: back
Rear Shocks
oil: 50wt
piston: 56 (red)
spring: green
length: 65.8mm
wishbone pos: inside
Notes:
Tyres: Take Off CS22
Insert: Pit Shimizu Medium
Battery: forward
Motor: P94 12x2
pinion: 27
Spur: 88
Bodyshell: Protoform Vauxhall Vectra
Old 08-07-2002, 02:26 PM   #3374
Man that was quick!-Thanks
Old 08-07-2002, 02:34 PM   #3375
I wonder what degree the track was for that setup(Westly Payne's rubber on asphalt)?
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
