Losi XXX-S
#3301
Foam tires on asphalt?
Do you run foams on outdoor prepared asphalt tracks? If yes can you give me some setup tips? What should I change first on a good rubber tires setup to start with foams? Should I use a front one-way with foams?
The story is that on our track the foams work better than rubber tires on the very hot days in modified class. Some weeks before the best Xray drivers begin to use Ellegi foams (1/10 wide gas car front tires) 35/40 hardness, front one-way and a fixed rear diff. So absolutely no diffs on the car. Their car drives like a 1:8 scale big nitro car. Until that I had the track record with the Losi but they are now half second faster.
#3302
good point, i would also add though that i havent had any problems and i never remember which way my losi diff's go in
#3303
The second time, beats the piss outa me, it just happened.
-Troy
#3304
but there again, that could happen to anybody with any diff. i've just never had it happen. some shit's funny that way.
#3305
asphalt foam, and rubber carpet run similar as far as i know. a couple setups use a little heavier rear shock oil wt then front. the best advice i could give you is to put the foams on ur car as it is, and just drive it. then make changes accordingly. go up or down shock oil depending on how your car bites. w/o knowing more about ur situation, i'd try congo blue front springs and losi black rear springs. and something like 60wt rear and 50 wt front oil. try the one way, some people like it, some dont. i'd start at a 41/42 underdrive no oneway.
#3306
XXX-S breakages
Has anyone managed a foolproof way of not breaking the front C-hubs when clipping boards while racing. Mine seem to be breaking quite easily with only minor hits (basically rubbing) them.
I've tried using low-profile locknuts on the wheels to stop them catching but this doesn't seem to have fixed it. Would a wide bumper work - has anyone else had similr problems.
#3307
Regional Moderator
Craig C, BRP wide front bumper
#3308
why are u rubbin boards in the first place? boards are slow, unless ur a newbie or a sportsman, then i can see it. otherwise use a wide front bumper
#3309
differential adjustment........
I just built my XXX-S and I'm gonna track test it this afternoon. Much to my disappointment, the Losi manual is noticeably 'light' on instructions for adjusting the differentials. I could adjust the rear diff similar to my XXX-T by holding the right rear tire and spur gear while trying to rotate the left rear tire, but what are you supposed to do about the front diff???
Any help would be greatly appreciated.
#3310
if it's rubber, run a one-way, otherwise i just use a skinney standard screwdriver and spin the opposite wheel. which ever way the screwdriver fit is how i do it.
#3311
clarification
I'm confused about 'how tight' to adjust the diffs on the XXX-S
#3312
tightness of the diff is a handling adjustment. how do u wnat the car to handle? looser rear diff is more steering into, and smooth out, tighter diff is tight getting in, then it steers coming out. i think is the opposite for the front but i never messed w/ my front. just get them feeling the same, and to a point where they are smooth. the diff should move as freely as it can w/o slipping
#3313
Run the diffs just tight enough so they do not slip. Usually I run my front diff a little tighter then the rear. You may have to play with the tightness a little to get it wear you want it. The other way is to ask someone who has been running the car for a while to feel the diffs and give there opinion.
Chad
Chad
#3314
Re: clarification
