Old 07-24-2002, 10:46 AM   #3271
Trader Rating: 71 (100%+)
So what is the latest carpet set up with foams? Anybody have a good one?
RCAmerica - Xray - Hudy - ProLevelRC - R1Wurks - BSR Racing Tires
RBLove is offline   Reply With Quote
Old 07-24-2002, 03:51 PM   #3272
anyone know when they are going to have a special edition?
LIke maybe a kinwald or a factory team?
teamAE is offline   Reply With Quote
Old 07-24-2002, 07:16 PM   #3273
Fire's Avatar
Originally posted by shrekair
dont waste ur time with them.
yeah
Fire is offline   Reply With Quote
Old 07-24-2002, 08:47 PM   #3274
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
nope..i have heard of no special additions.....i am sure it will happen though....
Matt M. is offline   Reply With Quote
Old 07-25-2002, 02:03 PM   #3275
Hope so
Old 07-25-2002, 03:56 PM   #3276
Fire's Avatar
it will come for sure
or you can just build one using options
Old 07-27-2002, 12:10 AM   #3277
Default battery flip off
Hi,
I find that my battery often flip off after a knock. I find that there isn't a lot of plastic to support the battery, unlike my mr4tc. Any suggestion ??
ongbenghui is offline   Reply With Quote
Old 07-27-2002, 05:09 AM   #3278
Trader Rating: 62 (100%+)
try slipping a strip of foam tire insert in between the battery holder and the battery. im using SMH batteries which are slightly smaller than sanyos and the insert holds them securely through crashes.
marvi is offline   Reply With Quote
Old 07-27-2002, 09:29 AM   #3279
losiracer's Avatar
Anyone have any info on the Nats and how losi is doing
Thanks,
Mike
losiracer is offline   Reply With Quote
Old 07-27-2002, 12:24 PM   #3280
R/C Tech Founder
R/C Tech Charter Subscriber
You can check out the track's results page here: http://www.mhorrc.com
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 07-27-2002, 10:16 PM   #3281
onaMISSION's Avatar
thanks for the news
onaMISSION is offline   Reply With Quote
Old 07-28-2002, 07:02 AM   #3282
does losi mke low roll center blocks and could someone give me the part numbers for the front and rear
sportracer is offline   Reply With Quote
Old 07-28-2002, 08:46 AM   #3283
onaMISSION's Avatar
Not sure on the part #'s for the matt francis ones, but you can do it your self very easy. Just cut the blocks down flat and run them in the lower hole still at 0R.
Old 07-28-2002, 10:11 AM   #3284
yodace's Avatar
Raced the losi this weekend. I could not get the rear of the planted. Does anybody have a setup, for rough bumpy track. Or know of anything I could change that would help like tires, etc.
yodace is offline   Reply With Quote
Old 07-28-2002, 11:37 AM   #3285
Fire's Avatar
use a little more droop in the rear end and use foam insert instead of molded insert for tires
also you can use inner holes for the front shocks (lean them inward) to reduce steering
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
