Old 07-09-2002, 04:50 PM   #3181
Send a message via AIM to ZER01
Kansasracer, are there any limiters(spacers) inside the shock between the piston and the shock cartridge? If so, take them all out. Are you using the stock black shock collars that came with the threaded shock bodies? You might have to get the Trinity/Losi shock collars so you can get a little less ride height if 8mm ride height is the least you can get with the stock black collars loosened all the way up.
ZER01 is offline   Reply With Quote
Old 07-09-2002, 08:59 PM   #3182
Send a message via AIM to M Ignacio
Hey you guys. Does anyone have a pic or knows what is the cleanest way to set-up a XXX-S with an LRP V6? Thnx in advance.
M Ignacio is offline   Reply With Quote
Old 07-09-2002, 09:12 PM   #3183
Regional Moderator
kansasracer's Avatar
proudwinner:
Yeah, I am using the stock plastic collars...I'll get a set of the blue collars and give it a try...
BTW, I am not using any spacers in the shocks currently
kansasracer is offline   Reply With Quote
Old 07-09-2002, 10:09 PM   #3184
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
Kansas-
There just has to be something wrong. If you adjust the shock collars all the way up, the chassis should sit on the ground - 0 rideheight. I run the Losi shock adjustment nuts, with no problems, even with the longer 1.15 springs(blue and softer).
Can you push the car down by hand to where the chassis will bottom? maybe you have the shocks overfilled with oil? I just can't imagine your problem. 8mm of rideheight? You can just barely run the car that high on purpose with the .28 shafts.
If you thread the adjustment nuts all the way up, what is holding the rideheight up so high? Could you possibly have the lower spring retainers on upside down?
I just has to be something simple.
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 07-09-2002, 11:18 PM   #3185
Fire's Avatar
i guess what he meant was his car's front hub is sitting on the #8 position on the droop guage maybe?? too little ride height
Fire is offline   Reply With Quote
Old 07-09-2002, 11:27 PM   #3186
Regional Moderator
Sir speedy:
I know, I used to own a Losi before and didn;t have this problem...
It's got to be something simple.....I just got to find it...
Fire: I know the difference between a droop gauge and a ride height gauge
Old 07-09-2002, 11:36 PM   #3187
Regional Moderator
OK,
Well....
I rebuilt the shocks and adjusted the nuts all the way up and can get 4.5 on my ride height now. It is still a mystery why it came out like a 4X4 before...
I can live with 4.5....thanks for helping me work out the "gremlins"
Maybe that's why I got this car so cheap (bought it used)...maybe it's cursed...
I'm not a newbie, I'm not a newbie, I'm not a newbie, I'm not a newbie, I'm not a newbie, I'm not a newbie, I'm not a newbie, I'm not a newbie.....
Old 07-10-2002, 09:29 AM   #3188
shrekair's Avatar
Trader Rating: 9 (91%+)
bart simpson in detention.
NOT A NEWBIE
NOT A NEWBIE
NOT A NEWBIE
NOT A NEWBIE
shrekair is offline   Reply With Quote
Old 07-10-2002, 09:39 AM   #3189
rayhuang's Avatar
Shocks
Kansas Racer, I think its in the shock ball ends or the spring cups. maybe if you cut the ball cups down, the spring cups can sit lower and you will have more of a range to work with. I cant see any reason why the car wouldnt go to below 4.5mm!!!
If you remove the shocks from arms, the chassis plunks down onto the ground, right?? I know-I know-your not a newbie
Old 07-10-2002, 09:53 AM   #3190
Fire's Avatar
i thought you didn't have enough ride height~~
which part is preventing the car going down??
and your car has no suspension travel now??
Old 07-10-2002, 10:15 AM   #3191
newracer's Avatar
R/C Tech Charter Subscriber
kansasracer- does the car have the low roll center blocks on it? my car with the low roll center blocks won't go below 4.5mm in the front either.
newracer is offline   Reply With Quote
Old 07-10-2002, 10:58 AM   #3192
shrekair's Avatar
u dont need less then 5 mm ride height anyway. unless ur running foams, but they are a shorter tire so you'll have a lower ride height. but if u can get 5mm just make sure your suspension is fully operational and u have full travel and "wheel it" i love how my losi will still wheel even if i mess soemthing up
Old 07-10-2002, 12:18 PM   #3193
psycho's Avatar
Lower ride height = more downforce. That's what you want if you race on technical tracks. With the short front shock shafts, you can easily run at 4mm. I run the Losi threaded shock bodies with the Trinity blue collars. The thin profile of the Trinity collars make it really easy to set your ride height below 5mm.
psycho is offline   Reply With Quote
Old 07-10-2002, 01:38 PM   #3194
Regional Moderator
It probably is in the ball cups....I'll get the Trinity shock collars next time I go to the store...
I don't run electric foam class, so I wouldn't see a need to go lower than 5 mm anyway....
Old 07-10-2002, 10:46 PM   #3195
Kansaracer, what color are your inner pivot blocks in the front? Red, silver? Are they aluminum? If not and they are graphite or stiffenzell composite, have they been cut down? This might be your problem as someone mention above.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
