Old 07-05-2002, 12:00 AM   #3151
Rowdy's Avatar
Does anyone know what is used as a core material in the carbonfibre shock towers. I don't think they could be solid carbonfibre.
Rowdy is offline   Reply With Quote
Old 07-05-2002, 01:13 AM   #3152
Trips's Avatar
Trader Rating: 16 (100%+)
Originally posted by shrekair
TEAM PRP known for after market PRO3 chassis and top decks is going into the design phase to make a few products for the
XXX-S. we are currently thinking about an improved shocktower w/ more adjustment. possibly in the distant future a woven chassis w/ machined bulkheads and a a top brace. what would you like to see? any specific parts that could be made from woven graphite that u can dream up?
Input always appreciated
If you're going to do a carbon chassis, please do something about the droop system on the XXX-S. Try to come up with a better way. If I were doing it, I'd move the droop screws further outboard from the inner hinge pin, and make sure they're reasonably rigid in their mounting.
Thanks,
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 07-05-2002, 03:56 AM   #3153
OBY
OBY's Avatar
Default Re: e-clip for hinge pin
Originally posted by ongbenghui
Hi OBY,
what is the size of e-clip you use for hinge pin ?
i just used the hpi ones...i dont know the size sorrow. i dont need them now because the aluminium hubs have a grub screw...that works!!!!
i really should take the e clips off...
OBY is offline   Reply With Quote
Old 07-05-2002, 05:24 AM   #3154
Marvi:
well the last time i checked you were in my rear view mirrors. HE HE HE
rctech is offline   Reply With Quote
Old 07-05-2002, 05:54 AM   #3155
OBY
OBY's Avatar
Originally posted by Fire
2mm ones will fit~~
is there any special way or tips about building the shocks?? I can't get all the air out of the shocks and it keep making some squeeky sound
i had that problem...if you look at my pics you'll see i solved it, by using hpi shocks!
Old 07-05-2002, 06:34 AM   #3156
Send a message via AIM to ZER01
That's because the piston is riding on top of the oil and not in it.
ZER01 is offline   Reply With Quote
Old 07-05-2002, 07:15 AM   #3157
Default more chamber holes
Check this out...
ongbenghui is offline   Reply With Quote
Old 07-05-2002, 08:01 AM   #3158
Fire's Avatar
how to solve that problem??
Fire is offline   Reply With Quote
Old 07-05-2002, 02:05 PM   #3159
Fire, the rear stock shocks are okay, it's the front that need to be modified. For the front I used the .28" shock shafts with the .36" threaded shock bodies.
Old 07-05-2002, 03:34 PM   #3160
STLNLST's Avatar
Trader Rating: 19 (100%+)
Default Re: more chamber holes
[QUOTE]Originally posted by ongbenghui
[B]Check this out...
How do you use the other camber holes that seem to be the mounting points for the camber links?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 07-05-2002, 07:34 PM   #3161
yodace's Avatar
R/C Tech Charter Subscriber
when did losi make two holes for the steering rack? I saw a friends new XXXS graphite chasis and it had two holes for the post?
yodace is offline   Reply With Quote
Old 07-05-2002, 11:20 PM   #3162
shrekair's Avatar
Trader Rating: 9 (91%+)
thanks for the input
shrekair is offline   Reply With Quote
Old 07-05-2002, 11:50 PM   #3163
Fire's Avatar
oh~~~
i see what you mean now
the shock shafts are too long for the application
does the shorter shafts fit the rear too?? will that be too short?
Old 07-06-2002, 01:16 AM   #3164
Fire, yes the .28's fit in the rear but your gonna loose some droop.
Old 07-08-2002, 10:48 AM   #3165
Team Losi has released an Alpha? 156 touring car body? It's already been approved by ROAR. Anyone know where there's a pic of this on the web?
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
